Question about Toshiba Canvio 500 GB USB 20 Portable External for Mac E05A050MAU2XW (Infinite White) Hard Drive
Toshiba canvio 1 tb is displaying red where it used to be blue when I click Computer and it's drives.
    Master:
  • Toshiba Master
  • 496 Answers
It sounds like the drive could be full? Right click the drive and select properties. It will show you how much of the drive is used up
Posted on Apr 19, 2014
puertobori
  • 7733 Answers
SOURCE: How can i format 1TB Toshiba Canvio portable hard
Right Click on your new drive in the Computer
Choose a File System (NTFS is ideal most cases) and give the new volume a name if you choose. You might like to call it something like "Portable Drive," or "Removeable Drive." If not, just take the defaults and click "OK."
You will get one last warning that you are about to format your drive and erase all data. Click OK to proceed. When you see the process has reached 100%, you are done and you're new external hard drive is ready to use!
Posted on Oct 28, 2010
SOURCE: I pluged my Toshiba Canvio Plus 750gb External HD
Download and Install SwissKnife!
(Unzip the file you just downloaded)
Plug in the external HDD ,run SwissKnife and select the format option!
Posted on Dec 15, 2010
Crankstart
  • 696 Answers
Sounds like a 2 part question.
Part 1, how do you use the drive on the computer to watch recorded shows from you DVR, simple install EX for windows which will allow your computer to access Linux formatted drives.
Part 2, how do you retrieve the files that were on it before, that depends how many new files you've put on it since. When the DVR formatted the drive it didn't erase the old files and they could easily be found again with a very inexpensive program. Each show you've recorded since will have overwritten some of the files. I will give you a link below for a review I wrote of such a program. Don't buy it right away, download the trial and scan the Toshiba, the program will show you a list of files it can recover then if you think it's worthwhile for the files it shows, only then pay for the program and recover the files.
Link for EX?
http://www.fs-driver.org/download.html
The author provides this driver for free but asks you donate to show your appreciation.
Data recovery software:
http://www.aitsavemyfiles.com/reviewfilerecoverybypctools.php
Hope this helps FixYa,
Chris
Posted on Dec 23, 2010
  • 240 Answers
SOURCE: I have a toshiba canvio 320GB external hard drive
Hi. Thanks for your question.
  • Here's what else you can do.
  1. Check the USB cable. Make sure it's connected securely. to make sure test with other device or computer to determine that cable is OK.
  2. Once you know you are using good cable you need to make sure that Hard Drive isn't at fault. Trying to use it in other PC is the best method of making sure that everything is OK with it.
Do not hesitate to come back and ask more if none of these solutions helped you. I am sure one of FixYa expert's will be able to help you.
Thank You for using FixYa.
Posted on Jan 17, 2011
  • 7 Answers
SOURCE: How to format a Toshiba
Just make sure you have any and all data that you want saved moved elsewhere before proceeding.
Posted on May 06, 2011
Toshiba HDD not recognized
Could you be more specific ?
on which computer?
which system?
Do you hear any noise?
USB, USB2 or USB3
Jun 15, 2015 | Toshiba Canvio 1.0 TB USB 3.0 Portable...
Can I hook to Samsung TV and play my movies I have down loaded on drive ?
if TV has a usb port just plug it in if not you need another type adapter
Mar 15, 2015 | Toshiba Canvio Slim 1 TB External Hard...
How do I save files to my Toshiba canvio slim 11 portable external hard drive
you should find someone local to help you out with that, its a little complicated to explain via text. its not a complicated process, there are just a few different ways to do it, depending on how many files you need to back up.
1. find the file you want to copy (this could be a folder, too).
2. right click and select "copy"
3. go to "computer" or "my computer" and double click the toshiba drive.
4. right click and select "paste" and that will copy it.
as i said, there are other ways of copying files, but that's probably the simplest way, although not necessarily the easiest, if you have a lot of files.
Jan 21, 2015 | Toshiba Canvio 500 GB USB 20 Portable...
How do I retrieve my files from Canvio Basics 3.0?
The usual way to back up files is to just open my computer and open the drive that is the external hard disk and just drag and copy the files over. You would then do the same this king to drag the files back to your computer. I am assuming you did not do this and usedsome software that came wwith the drive. In that case I would still open the drive in my computer to see if its there or otherwise u need to use the same software u used to backup the files to recoverthem. If you ccan't figure it out I would redo saving the files the normal way like I explained before . An internal hard drive or even external storage device like USB thumb drive simply shows upas a new drive when plugged in. Do not use an software to save files as usually they are proprietary and use compression which is iinconvenient or makes it difficult to recover
Jul 24, 2014 | Toshiba 1TB CANVIO BASICS EXTERNAL USB 3.0...
I cannot drag files in the Toshiba Canvio Basics 2,0 TB
Please test it by cutting a data file and pasting it in this hard drive. If it is success, then probably the type of your data is different and it is not freely moveable, or you it is possible that you tried to move the files to the same folder (it happens when the user opens many Windows Explorer/File Manager).
Mar 03, 2014 | Toshiba Canvio Computers & Internet
How to password protect a simpletech 96300 41001-073
Yes it can, using an encryption application such as VeraCrypt.
(https://veracrypt.codeplex.com)
Feb 13, 2014 | Toshiba Canvio 1.0 TB USB 3.0 Portable...
Rename hard drive
Right click on "My Computer" (WinXP) or "Computer" (Windows 7/8) . Click on Manage. In the left window, click Disk Management. In the middle window, right click on the drive that you want to re-name, Click Properties. Above the Type: section there is a box that you can type in. Type in the name of the drive that you want to rename.
Jan 28, 2014 | Toshiba Canvio 500 GB USB 3.0 Portable...
Computer won't recognize external usb hard drive
Format drive NTFS sounds like its corrupt, use mini partition wizard...
may also need 3TB Unlocker from manufacturer of Hdd
Dec 27, 2012 | Toshiba HDWC130XK3J1 Hard Drive - Canvio 3...
E05A100PBU3XS toshiba hard drive no longer recognized
For internal hard-drive:
There's a possibility that the hard drive is cooked. Try running a hard-drive self test by accessing the BIOS screen of your laptop. If the test fails, the your hard-drive is already broken.
Try re-seating your hard-drive. Take it out then put it back in again. If it doesn't work, the hard-drive is broken. If you have a similar drive available, try replacing the drive that displays the error. If the extra drive works without any problems, the old drive is broken.
Consult a local technician. They should be able to assist you in resolving problems like this. They might also be able to help you retrieve important data from the broken drive.
You can also call your computer's manufacturer for troubleshooting or replacements.
For external drives.
Fixes:
1. Plug the hard-drive into another port. 2. Plug the hard-drive to another computer. If you get the same error, the drive is no longer usable.
Sep 21, 2011 | Toshiba Notebooks Canvio E05a100pbu3xs 1...
My asus oplay air didnt recognizes the canvio USB 3.0 neither cinema tube mini
try to partition it and format in differant filesystem eg. ntfs or fat32
Feb 23, 2011 | Toshiba 10TB Canvio 30 Plus USB 30...
Toshiba Canvio 500 GB USB 20 Portable External for Mac E05A050MAU2XW (Infinite White) Hard Drive Logo
91 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
