Question about WISE 2086 Electronic Professional Tension Head
Tension is not consistent
The tension will vary after once the string is stretched.
Belt keeps slipping on treadmill
Adjusting Tension on a Treadmill Running Belt It is necessary to properly tension a treadmill belt when it is replaced. After time, a belt can stretch and may begin to slip. When this happens, it is necessary to adjust the tension of the running belt to stop it from slipping. Manufacturers of treadmills generally agree on one of three procedures for how to tension a treadmill running belt.
  1. Adjust for no slippage of the treadmill walking belt on the front roller (Often referred to as the "Stomp Test")
    1. This procedure works well for a previously installed belt that is now slipping.
    2. Underside of belt should be free of any glazing/wax buildup.
    3. Rollers must also be free of wax buildup.
    4. Be sure belt tracking/centering is correct before proceeding.
    5. The most popular speed for this adjustment is 2mph to 3mph.
    6. Try to slow the belt by applying pressure with your foot against the belt movement while grasping the handrails. If the running belt slow, slips or stops (and the front roller does not) adjust BOTH adjustment bolts 1/4 turn clockwise. Test again and repeat adjustment if necessary.
  2. This procedure requires two belt gauges or calipers
    1. This procedure works well when installing a new belt.
    2. This procedure requires you to stretch the belt. Depending on the manufacturer*, this varies between .4 and .6 percent. A dial on the gauge or caliper will indicate the amount of stretch. *Consult the owner/service manual for proper tension.
    3. If you are working on a previously tensioned belt you will need to release the tension before attaching the gauges or calipers.
  3. Gauges or Calipers unavailable
    1. Release the tension on the belt.
    2. Using a yard stick or tape measure, place two marks on the left and right edges of the belt and deck 36 inches apart (or 50 inches if you prefer).
    3. Adjust the left and right tensioning bolts until both sides measure 36 3/16 inches (or 50 1/4). This is equal to .5% of stretch.
    4. Test for proper tracking and tension, adjust if necessary.
How to Tension Treadmill Walking Belt that Slips
Apr 01, 2014 | Life Fitness 91Ti Treadmill
Belt has moved to the left
Adjusting Tension on a Treadmill Running Belt It is necessary to properly tension atreadmill beltwhen it is replaced. After time, a belt can stretch and may begin to slip. When this happens, it is necessary to adjust the tension of the running belt to stop it from slipping. Manufacturers of treadmills generally agree on one of three procedures forhow to tension a treadmill running belt.
  1. Adjust for no slippage of thetreadmill walking belton the front roller (Often referred to as the "Stomp Test")
  2. This procedure requires twobelt gauges or calipers
Mar 16, 2014 | Precor Exercise & Fitness
Adjusting the belt of the Precor 9.1
Mar 13, 2014 | Precor Exercise & Fitness
New running belt tracks to thr left
Feb 04, 2014 | Precor C962i Treadmill 220V
Walking belt alignment how to
Jan 07, 2014 | Precor Treadmill Belt 9.10, 9.2 Treadbelt...
How do I tighten drive belt on precor 956i
Jan 04, 2014 | Precor 956i Experience Series Treadmill...
Walking belt slipping
Dec 22, 2013 | Precor Exercise & Fitness
Adjust belt side
Dec 19, 2013 | Precor 9.21 Treadmill
How do you adjusting the running belt on precor 9.1 treadmill
Mar 13, 2013 | Precor Exercise & Fitness
What size belt do i use if i remove the A/C compresser
There is a company which makes a bracket with another idler pulley on it for replace the A/c compressor. I believe it costs between $60 and $90 Dollars. Problem with replacing the belt with a smaller, shorter belt by eliminating a pulley is the RPM of the Alternator and the Power steering pump.
To make an explanation, if 1 loop of the original belt turns the Alternator once every 8 inches, then a 48 inch belt will turn the Alternator 6 times a cycle. A shorter belt will make more cycles around the crankshaft pulley, the Alternator and so forth.
This will increase wear. The Fan blade will spin faster and you can get less assist from Power steering if it is speed sensitive. Power steering may or may not be better at Parking and will surely flatten out more quickly at higher speeds resulting in high steering effort.
Without the conversion pulley, the Geometry for the spring loaded idler pulley may not keep enough tension on the shorter belt for proper tension.
But to measure for eliminating the pulley, just slip off the old belt and get a string with a loop on 1 end. Press down on the spring-loaded idler pulley and place the string around each pulley and then pull the end of the string through the loop until it is snug. Pinch off the position with your finger to where it seems that the tensioner is applying tension with more tension possible for a stretched belt.
Temporarily slide the end of the string off, secure a removeable knot, and then let the string handle some of the tension in the idler. Basically you are making a template for the correct belt length. If all looks well, the string can be fit on a belt sizer or just measure it. Remember the buy a belt with the same number of grooves.
Another thing to remember is the car will still try to adjust the engine idle for the A/C, sometimes even in the Defrost function, because that is how they are made. So you may have idling problems without the A/c.
I hope my solution has helped you.
Sep 30, 2012 | 1997 Lincoln Town Car
WISE 2086 Electronic Professional Tension Head Logo
243 people viewed this question
Top WISE Sport & Outdoor - Others Experts
Bill Eager
Are you a WISE Sport and Outdoor - Other Expert? Answer questions, earn points and help others
