Question about Ovens
Error code f7 for comfortair model csd-12y3 - Ovens
2 Suggested Answers
  • 1891 Answers
SOURCE: We get a F7 error code on our model JT910SA3SS
F 7 code is an most G E ranges . is stuck key on pad . some of these can be unstuck but if hi heat caused the pad is warped and not repairable . turn off power disconnect the key pad from the clock and if code goes away key pad is at fault if it does not the eoc is at fault . and you will have to replace the clock . **** hope this helps . feed bk pls .
Posted on Dec 26, 2009
GE Profile Wall Oven Model#PT916S error code F7
U have a bad clock or your probe inside of oven is bad.I would replace your probe first .it looks like a rod sticking out inside back upper top .f7 I believe means its not reading up temp and getting to hot
Nov 10, 2011 | Ovens
Dec 26, 2009 | Ovens
Oven displays F7 error code and does not function
Unplug the Oven, Disconnect the Power Supply and then Turn the Oven Back, say after 30 minutes. If the code still appears it could be either Faulty Touch Pad or Computer.
Now,
To check, Turn OFF the Oven as we did earlier, then remove the Control Panel . Disconnect the Ribbon like Cable from the Touch Pad. Disconnect it from the Computer. Turn the Oven, and if Code appears Replace Computer Unless Replace Touch Pad.
It is a Valid Model Number. You could buy the same from :-
http://www.repairclinic.com/Appliance-Parts?s=t-JT950B0A1BB-%3d%3d
http://www.cashwells.com/
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 20, 2009 | GE Ovens
F7 flashing on our oven screen
Without the model and brand I can only give you the most common F7 Error code. F7 for the most part on a oven is a stuck key on the key pad and can also be a control board. Some key pads are part of the control and you will just need to replace the control.
Sep 26, 2009 | Magic Chef 9815 Electric Single Oven
Giving an F7 error code
There was a tag on stove that told on the error codes. Reset pad, it was somehow stuck. Thank you for your help!!
Cheryl
May 27, 2009 | GE JRP15 Electric Single Oven
Range led flash code F7
Here is the error information for Fault Code F7
F7 Lock motor relay watchdog circuit is active when it should be off Microprocessor checking the operation of the EDC lock, relay failed. Replace EDC.
Hope this is helpful, I will also provide you a link to to a helpful site.
http://www.applianceaid.com/fault_codes.html
Mar 14, 2009 | Frigidaire FEB27S5A Electric Single Oven
Oven does mot work
F-7 on the GE is a touch pad error, all you can do is replace the whole touchpad. You can try shutting the power off at the breaker leave off for 5 min at least. turn the power back on sometimes this will get rid of it for a time.
Feb 23, 2008 | GE JGRP17 Gas Single Oven
I have an F7 error code
This usually indicates a stuck key, requiring keypad replacement.
This often involves replacing whole console assembly. You need full model a and serial to order parts.
Nov 22, 2007 | GE JGRP17 Gas Single Oven
Ovens Logo
15 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
