Question about Hoover Steam Vac Dual V w/ SpinScrub Vacuum
Detergent tank leaks - Hoover Steam Vac Dual V w/ SpinScrub Vacuum
How do you remove the lower handle?
Check the clean water holding tank. I had this problem and found that was a crack near the outlet on the bottom of the tank. I replaced the tank and resolved the problem. I have taken this machine apart several times, if the tank is not the problem with yours, check the water tube.
Apr 26, 2015 | Hoover F7425-900 SteamVac V2 Widepath...
My Hoover steam vac dual v clean water and detergent tank leaks water before attached to the vac and during cleaning
This is a common problem with the earlier models which had a separate soap tank glued to the clean water tank. The plastic was too thin beneath the valve on the clean water side and would develop cracks. You most likely will need a new one piece tank. ( Part # 42272104)
May 21, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
The detergent 'leaks' into the clean water reservoir when I am using it.
This was a common problem with units manufactured around 2006. The problem lies in the pressure valve inside the handle. This is best left to a dealer to repair. The alternative is to remove the tank as quickly as possible after using it.
Jan 05, 2011 | Hoover F7425-900 SteamVac V2 Widepath...
Leaking tank
(1) Does water or chemical leak from the tank when filled, but before it is installed? If not, then the tank is OK.
(2) If the tank is not properly aligned to the lower handle when assembled and latched, the black rubber seals on the handle will not seal to the tank. You may wish to look at this. Also, make sure both round black rubber seals are present on the flat mount where the tank valves will sit.
Oct 05, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Have a Hoover Steamvac Model #F7426-900 - Series AA12.0 On the bottom of the clean water tank and the detergent container, the gaskets leak and water constantly drips from the tank. How do you repair...
Inspect under the seals to see if the tank hasn't cracked, which is usually the problem. If it is a new seal that is needed, part #43513026. If a new tank is needed, part #42272104.
Apr 24, 2008 | Vacuums
Detergent won't dispense
Check the valve at the bottom of the tank, does it push up then come back by itself (part #43513014)? If it is ok, then there may be a problem with the plate that the tank sits on or the plunger inside the handle isn't pushing to release the detergent.
Feb 08, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Tank Dispensing
Is the detergent tank cracked at the bottom, under the black seal? If so the whole tank asm. needs to be replaced. But if this is new, then it has a one years warranty on it and you can take in for warranty repair.
Oct 13, 2007 | Hoover F7222-900 SteamVac Upright Vacuum
Bissell 1697w Powersteamer
I have a similar model and occasionally have problems with water/detergent flow. I find it is generally due to an airlock in the piping caused by forgetting to turn the deregent water control off before removing the detergent container. Follow the manual instructions. Turn the knob to off. Fill both containers. locate them carefully. Make sure filters in the water tank and in the flow meter are clear. Start machine with handle laid flat and knob turned to maximum flow.
Dec 22, 2006 | Bissell 1697-7 Powersteamer Pro Deluxe...
Hoover Steam Vac Dual V w/ SpinScrub Vacuum Logo
15 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
