Question about Samsung WF218ANW 4.0 cu. ft. High Efficiency Front Load Washer
Smoke in drum - Samsung WF218ANW 4.0 cu. ft. High Efficiency Front Load Washer
What's wrong with my candy washing machine when smoke is coming from the drum
The smoke is coming through the drum, but I'm afraid you burned out the motor. Perhaps the main motor, perhaps the pump motor.
You only can find out, when looking inside. When you don't have the skills please don't do this yourself. It can cost you your fingers or your life if you make a mistake while opening the machine.
Jan 28, 2015 | Candy Washing Machines
Smoke coming from inside drum after spin cycle
The noise would possibly indicate that your drum bearings are on their way out, this would more than likely mean a new spider assembly, tripod in shape and houses the bearings through the drum, as well. They come in kits or bearing assembly alone for various prices, usually around 40 pounds for the kit but it would be a very difficult job if you are not familiar with this type of work, bearing extractor kits are best used but more cost, drum seals may also be needed.
Jan 23, 2014 | Hotpoint WMA35 Front Load Washer
Is it worth trying to fix
wow, those bearings must of got really hot,, replacing the bearings is a very cheap job if you do yourself, if you think you can tackle doing them, go for it
Sep 12, 2013 | Fisher and Paykel Washing Machines
Smoking rear drums
Depends on what is smoking.
If you did not clean the protective oil off the drums then yes it will stop in time. If the wheel cylinders are leaking brake fluid then no.
Sep 30, 2012 | 1999 Dodge Durango
My Magtag Neptune TL 6800 started making a horrible squealing noise then smoke started coming out of the washer. What do you the problem may be?
You need to replace the belt needed to spin the drum. It sounds to me like you may have been overloading the drum, putting too much stress on the belt. Over time, it has begun to " burn rubber" as it spins, causing smoke, or worst case scenario, the motor that turns the belt is locking up as the drum spins causing friction on the belt.
Aug 17, 2011 | Maytag Neptune FAV6800AW Top Load Washer
The washine machine finished it's cycle but there was smoke coming out of the drum and a burning rubber smell
The usual cause of smoke coming out of drum is that the heater element has come on or stayed on with no water in the drum
Try it on a spin cycle only, if smoke still comes out of drum, then could be a faulty pump, or main motor is burning.
Jan 20, 2010 | Baumatic BTWM4 Front Load Washer
Candy washing machine smoke coming from inside
it is rubbing on spin cycle due to being out of balance.Rubbing wont occur when turning by hand.
Stop by your local hardware store for a packet of drum balancers.
Aug 16, 2009 | Washburn Electric Guitars Modelno. X10-B
Smoking washing machine
Switch it off before you burn your house down
The drum support sounds to have either cracked or come loose allowing the drum to run on the door gasket
The friction will cause the rubber to melt and burn hence the smoke.
Get a service person out to it asap
Jun 14, 2009 | Whirlpool GSC9455 Top Load Washer
Maytag neptune smoking
it could be the seal on the drum or it could be the belt getting too warm
Jan 12, 2009 | Maytag Neptune Washer
Samsung WF218ANW 4.0 cu. ft. High Efficiency Front Load Washer Logo
11 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
