Printing not centered
Your software label template does not match the size label your printing on. Make sure your label size IE: 2.25" x 1.25" matches the template size in the software, then perform this calibration:
TLP 2742 is printing blank labels
SOURCE: Labels print out of center
the important thing is if you are using different type labels and sizes before printing see to it that the labels must properly calibrated..to avoid printing incorrectly
SOURCE: labesl are printing very light in the center. OK
This is a good challenge so lets start with the "simple stuff".
First, Have you cleaned the printhead? If not just use a Q-Tip and some rubbing alcohol if you don't have any other cleaning materials.
Second, look at the platen (the white roller) are there any cuts or hunks missing? This would result in voids every-time the platen rolled around to that point during printing. If you see any, the platen needs to be replaced.
Third, it would be odd but do you see any stuck labels on the platen? If so remove them.
Fourth, the "standard" 105 SL has one tension spring. I'm guessing it's already centered in the middle of the label?
Regards,
[email protected]
