Fisher & Paykel Frigidaire Excellence 7.5 clothes washer Model: GW709NZ Ser: NEL559749 no power in the machine but there's power going to the machine it's as if the fuse has blown
There is power going to the machine but there's no power in the machine
4 Suggested Answers
livewire874
  • 618 Answers
SOURCE: Fisher & Paykel Frigidaire Excellence
May be one of the fill valves are not opening when it is calling for either cold or hot water. Have the solenoids checked with an ohm meter
Posted on Feb 26, 2011
  • 2468 Answers
SOURCE: I have a Fisher &
have you tried the www.Fisherpaykelparts.net/ website, when you open this page scroll to the bottom of the page and there will be a portion that says "FREE TECH SUPPORT AVAILABLE" click below where its high lighted in purple and they will give you the info. you are looking for or even call them on their toll-free phone number
Posted on Apr 29, 2011
Daniel S
  • 4323 Answers
SOURCE: Need Service Manual for Fisher & Paykel clothes
Hi
Please click on this link to download the repair manual for your Fisher & Paykel GWL10 washer. Hope this helps...please post back for further assistance.
Daniel
Posted on Jun 17, 2011
Fisher & Paykel gw711 excellence keeps filling and overflowing
the clear pressure tube is blocked,
you need to blow air down the clear pressure tube hose.
Jan 30, 2013 | Fisher and Paykel GWL11 Top Load Washer
My fisher & paykel 7.5 kg excellence smart drive doesn't spin
Check the out of balance switch (under the larger Grey board)
for corrosion on the terminals and replace if faulty.
Jul 03, 2012 | Fisher and Paykel Washing Machines
I have a Fisher & Paykel 6.5 Excellence, my garage door had a mishap and the wiring blew and is now all melted, have found that my washing machine now does not go whch is more than likely due to the...
i am sorry to say there is no reset switch if u are geting power to the unit and the display is not coming on then u have a bad control board located in the front panel.
Apr 09, 2011 | Fisher and Paykel Fisher & Paykel Washer
Fisher & Paykel Frigidaire Excellence 7.5 clothes washer Model: GW709NZ Ser:NPL579002 the clothes washer starts as normal, water runs for approximately ten seconds and then stops, runs for two to...
Feb 26, 2011 | Washing Machines
Fisher & Paykel GW709NZ will not fill
Hi just read your posting.Your Error Code is 49.This means you have a Water Valve Fault.Would you like me to guide you throe the testing and repair of your machine?If you do then have you or can you borrow an electrical test meter to test the water valves?Please reply and tell me how you would like to proceed.Looking forward to your posting.
Jul 19, 2010 | Fisher and Paykel Washing Machines
I have the fisher & paykal excellence 6-5 smart drive model gw609au when i first turn it on the seconds green light is flashing and it is trying to fill up but starts and stops all the time then just...
Hi Damian just read your posting.Your fault on your machine is the out of balance switch is faulty.Do you still require help?Please reply and I can guide you throe the repair of this problem.
Jul 02, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fisher & paykel GW 703-U water flow and the engine sounded choked
sounds like out of balance switch is faulty. does the water start stop start stop then machine beeps. if it does it is most likely out of balance switch.please reply 4 more help
Mar 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GW708F Screaming like a jet engine on spin!
Hi there
Yea if the machine sounds like a train going through the middle of your house when its on spin it will most definately by your seals and bearings, an easy way to check is lean the machine back onto something and look underneath if the main seal is leaking and the bearings are run there will be rusty looking residue on the motor rotor(the round thing in the middle of the drum), seals and bearings are fairly expensive to replace About $350NZD if no shaft is needed and up to $500NZD if a replacement shaft is needed.
I hope this helps you out.
Nick
Aug 03, 2009 | Fisher and Paykel Fisher & Paykel Washer
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
