Question about Trendnet 108Mbps Wireless Super G Broadband Router (TEW452BRP)
Set password how do i set network password
  • Trendnet Master
  • 2,219 Answers
Download the user guide from here
TRENDnet Support TEW 452BRP 108Mbps Wireless Super Broadband Router
1. Go to Wireless on the management menu.
2. Got to Security on the next menu and change the wireless security from disabled to your choice of security setting and then follow the prompts. Page 31
Posted on Jan 23, 2015
I forgot admin password
To reset the SWS (SyncThru Web Service) password:
  1. Press the Menu button.
  2. Press the right or left arrow until Network appears, then press OK.
  3. Press the right or left arrow until Clear Settings appears, then press OK.
  4. Select Yes and press OK.
  5. After the printer finishes clearing the network settings, unplug it for a few seconds then plug it in again.
  6. All network settings (including the SWS password) will be reset. If you had manually configured IP info or were connected to a wireless network, you will need to re-enter those settings now.
  7. The login will default back to admin and the password will be sec00000.
Note: If you did not change your password or this is your first time trying to use the SyncThru service, the default SyncThru user/password is admin/sec00000.
Dec 17, 2012 | Samsung SCX-6345N Printer
I want to know how to connect my ssid pasphrase located on the back of my router and when i tried to conect it to my ps3 conole it said it was weak and it couldnt find the acess point or something so can...
i'm going to assume that you are asking "how to connect your ps3 to your home network?"
if your home is set up with wireless modem or router and your computers are connected wirelessly its pretty simple to set up. more likely you or someone who set it up probably set it up securely meaning with security key and password. So you do have to know few things about your home network. like what is the name of your home network (SSID). the security setting of your home network. and finally the password of your network. if you don't know these things about your home network you will not be able to get connected wirelessly. but if you do have these info on hand read along....
JUST MAKE SURE YOU DO HAVE A WIRELESS HOME NETWORK... it definitely wont work if you don't have a wireless setup and u are trying to connect wirelessly. people overlook this no brainer.
Turn on your ps3 and from the XMB...
1) go to Settings
2) Scroll down to Network Settings and press X
3) Scroll down to Internet Connection Setting and press X. confirm on "O.K."
4) easy *it may or may not give you a message reading "checking network configuration"
5) wireless
from this point on you need to know few things about your network.....
6) scan -- once scanned it'll give you wirelss access point for you home network and some other near your home along with few information such as....
...SSID (which is what you set your network to be -- i.e. "the jones" or "linksys" or "summer home" or "my connection" etc etc) ...SECURITY (this is the password you set up your network with) ...SIGNAL STRENGHT (usually your network will be the strongest among your neighbors since you are closer to your router)
7) highlight your network and press x . (you should know what it is) selecting on the other network probably wont do you any good since it'll probably be all locked with password and such. yours should also be locked and have password on it too.
8) SSID which means service set identifier basically mean the name of your network. if your home network is set up with security and password your home network will not show up under SSID (this is one of the things you need to know about your home network. if you don't know ask the person who set up your home network)
9) on WLAN SECURITY SETTING page (this is another thing you should know about your home network or ask the person who set it up) -- most people i deal with have a WPA-PSK / WPA2-PSK security password. Yours may be different so choose the one that you used.
10) WPA KEY - which basically means password. input the password you used to set up your home network (this is another thing you should know about your home network or ask the person who set it up)
**it'll give you "checking network configuration"
11) if you input all the correct info you should get the "setting list" screen
12) press "X" to save the setting
13) do the connection test and if all things were entered correctly you should have success.
all this seems complicated just reading but if you follow it step by step its easy. you just need to know the name of your home network, the home network setting, and the password of your home network.
on the other hand if you are setting up a wired connection it makes it a whole lot simpler. you don't need to know your network name, security key, and password.
make sure you have the ethernet cable plugged in to your ps3 and to your modem or router
1) go to Settings
2) Network Settings
3) Internet Connection Setting. confirm on "O.K."
5) wired
6) auto-detect
7) automatic -- for the IP address setting
8) do not set
8) automatic -- DNS setting
9) automatic -- MTU
10) do not set -- PROXY SERVER
11) ENABLE -- UPNP
save connection setting
test connection
if your home network is set up and u got the ps3 connected it should work
Sep 01, 2011 | Sony Playstation 3 (PS3) Console
Lost my password
Are you looking for the wireless password or the password of the router?
If you want the password of the router, then try the default password of the router. If the default password doesn't work then you will need to reset the router and reconfigure the router.
If you are looking for the wireless network password, then you will need to open the set up page of the router. Is there any computer connected to the router ? If not then you will need to connect the computer to the router. Or any other computer which is able to go online using the router. Check the IP address on that computer. open the set up page of the router. Set up page of the router is the page where you will find all the settings of the router. under the wireless section you will find the wireless network password.
Click here for more information about the routers and wireless network.
Oct 24, 2010 | Belkin Computers & Internet
I am trying to connect another computer to my wireless network but i do not know my netgear code, where do i find this?
Netgear code? Can you be more specific?
Are you referring to the password required to connect to your wireless network called "Netgear"? I assume you're being asked for a password on the 2nd computer when trying to connect to the wireless network called "Netgear".
  1. In a web browser, enter the router's IP address - either http://192.168.0.1 or http://192.168.1.1 by default.
  2. When prompted for a Username and Password, enter the default username and password (admin; password) unless you have already changed it. NETGEAR recommends changing the default password to increase the security of your network.
  3. Select Wireless Settings from the Setup menu in the left-hand navigation bar.
  4. Under Wireless Network, enter your desired network name in the Name (SSID) box. This is currently set to "Netgear" most likely.
  5. Under Security Options, select WPA-PSK [TKIP] + WPA2-PSK [AES].
  6. Under Security Options (WPA-PSK + WPA2-PSK), enter your desired network password into the Passphrase box.
    • WRITE DOWN or KEEP NOTE of your network name, security option and passphrase - you will require them to connect wireless computers and devices to your network.
  7. Click Apply to save the settings.
Once you've set this password, you can use it to connect to "Netgear" on your second computer.
Jul 25, 2010 | NetGear WGR614 Wireless Router
Get stuck changing net settings, ie ssid...
1) go to Settings
2) Network Settings
4) easy *it may or may not give you a message reading "checking network configuration2_bing.gif"
5) wireless
6) scan -- once scanned it'll give you other wirelss access point for you home network and some other near your home along with few information such as SSID (which is what you set your network to be -- i.e. "the jones" or "linksys" or "summer home" or "my connection" etc etc) SECURITY (this is the password you set up your network with) SIGNAL STRENGHT (usually your network will be the strongest among your neighbors since you are closer to your router)
7) highlight your network and press x . (you should know what it is) selecting on the other network will probably not do you any good since it'll probably be all locked with password and such and so should yours be.
9) on WLAN SECURITY SETTING2_bing.gif page (this is another thing you should know about your home network or ask the person who set it up) -- most people i deal with have a WPA-PSK / WPA2-PSK security password yours may be different so choose the one that you used.
all this seems complicated just reading but if you follow it step by step its easy. you just need to know the name of your home network, the home network security setting, and the password of your home network.
1) go to Settings
2) Network Settings
5) wired
6) auto-detect
8) do not set
9) automatic -- MTU
11) ENABLE -- UPNP
test connection
May 19, 2010 | Sony Playstation 3 (PS3) Console
Playstation 3 (PS3) Console: hi my ps3 wonk connect wirelessly keeps asking for...
if your home is set up with wireless router and your computers are connected online wirelessly read along....
1) go to Settings
2) Network Settings
5) wireless
8) SSID which means service set identifier basically mean the name of your network. if your home network is set up with security and password your home network will not show up under SSID (this is one of the things you need to know about your home network)
9) on WLAN SECURITY SETTING page (this is another thing you should know about your home network or ask the person who set it up) -- most people i deal with have a WPA-PSK / WPA2-PSK security password yours may be different so choose the one that you used.
May 16, 2010 | Sony Playstation 3 (PS3) Console
How do I change my password?
are you speaking about the wireless network key . The password for the wireless network will depend upon the router. to change the wireless network pasword , you will need to change the settings of the router.
Open the set up page of the router and change the wireless network password.
Mar 17, 2010 | Belkin N1 Wireless USB 2.0 Network Adapter...
How to sercure my wireless network
Securing a wireless network includes:
1. Setting a router admin password so nobody can get into your router (do this by using the default user/password to access the router and in Basic settings set a password...go to http://192.168.1.1 in your browser to access the web interface.
2. Set up a SSID for your network...this can be any name with numbers value...its just a description
3. Set up under wireless settings you WEP encrption with a password so when you scan for wireless networks you will find your SSID named network and when it prompts you you enter the password you set for WEP.
Oct 21, 2008 | NetGear MR814 Wireless Router
Trendnet 108Mbps Wireless Super G Broadband Router (TEW452BRP) Logo
91 people viewed this question
Top Trendnet Computers & Internet Experts
David Payne
David Payne
Lynne
Are you a Trendnet Computer and Internet Expert? Answer questions, earn points and help others
