Question about GE JGRP20 Gas Single Oven
How to replace the thermostat in a gas oven - GE JGRP20 Gas Single Oven
How to replace the thermostat on BP y-600
Turn off gas supply. Open panel on left side. Loosen the top and bottom unions. Remove thermostat capillary line from the oven. Now remove thermostat with 2 pipe wrenches. install new thermostat and attach assembly to the unions you loosened. Now insert the capillary line back into the oven.
Jul 27, 2014 | Bakers Pride Y-600 Gas Single Oven
Oven keeps switching off
Hello
First double-check the gas supply. Look over the gas valves on the back of the oven to make sure gas is able to flow into the oven. If those look OK, call the gas company to see if there has been an interruption in service to the area or to the house.
If the oven grows too warm, the thermostat might malfunction and the thermostat is probably to blame for what you are experiencing.
The thermostat is the part of the oven that tells it when it has reached the desired temperature, shutting off the heating process. If one of the thermostat's components is broken or dirty, this can render the thermostat useless.
Cleaning and replacing the thermostat components is a process best left to professionals because untrained hands can easily break a thermostat that simply needed cleaning. If you suspect this is the issue, contact your local gas company. Sometimes, gas companies offer oven thermostat repair services.
Apr 16, 2010 | Thermador SC302T Electric Double Oven
Oven won't light - electronic ignition oven
Hi, it could be your, electric heating element and oven burner gas valve. both are located in oven burner compartment, remove last bottom panel, locate oven burner, the valve that feed gas to burner, has two wires connected to it, that's oven valve could be faulty, also look on side oven burner, you will see electrical heating element, could also be faulty, it's better to replace both oven valve and element, that's the most common problem, but first check oven thermostat, that's knob you turn to light oven, if thermostat o/k, then it's your oven valve or heating element, (used to ignite oven burner) or call a mechanic, good luck.
Aug 12, 2009 | Kenmore 33169 Gas Single Oven
Frigidaire gas oven not heating
replace the bake ignitor its getting weak
Jul 01, 2009 | Frigidaire FGB24T3A Gas Single Oven
There is no gas going to my oven. Only the
hello, i can help you. first of all, if the broiler works then you must have gas coming into the stove. as far as getting to the gas line, it is in the rear of the stove. typically you have to pull out the stove to get to it. that said, here are some things to consider.
Not all gas ranges/ovens require electricity. If yours has a clock, electronic igniters, self-cleaning, or any other electrical features, the unit needs electricity to work properly. Check to see whether there's power getting to the range/oven. Does anything turn on--even a light? If not, check for a blown fuse or tripped circuit breaker.
It won't bake If your oven won't bake, check these:
Bake igniter
Other causes
Bake igniter Usually when an oven won't bake, it's because the bake igniter is weak or burned out. The igniter is a small, round or rectangular device, that's about 1 inch by 4 to 8 inches. It's near the burner itself.
The burner is the tube-type device the gas flows through before it's ignited. It has many small holes on the sides to let the gas, when ignited, form a long, low flame. If the igniter is weak, if it glows red but doesn't get hot enough, or if it's burned out, the gas doesn't flow to the burner and the burner won't ignite. If this is the problem, you may need to replace either the igniter or the gas safety valve. Usually the igniter is to blame.
Other causes Other reasons that your oven may not bake are:
  • The clock settings are incorrect (if you have timed baking or a self-cleaning oven).
  • The thermostat is defective.
  • The safety valve that prevents accidental gas flow is defective.
  • The selector switch is defective.
It bakes poorly Here are two instances of when food "bakes poorly:"
  • When the item takes far too long to finish, you probably have a weak bake igniter. Often, you need to replace the igniter, but you may want to troubleshoot the oven's electrical system further to more precisely locate the defect.
  • When the temperature is consistent but too high or too low, the oven thermostat or sensor is either mis-calibrated or defective. If your oven uses an electronic temperature-regulating device, you may have an electric sensor in the oven instead of a mechanical thermostat. If the oven temperature is off by 30 to 40 degrees in this type of unit, you must replace the sensor.
    On many units with a mechanical thermostat, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
Jun 22, 2009 | Ovens
Temp 50 degree too cold need to adjust thermostat on JGRS14
ive installed 100 new thermostats over the years and they are set from the factory.no adjusting.now some knobs have an adjustment on them.and some times customers got knobs mixed up and got the wrong one one there.
Jan 01, 2009 | GE JGRS14 Gas Single Oven
Lang gas oven
The thermostat may be faulty for that section of the oven, it checks to make sure there is a pilot flame via a thermostat that turns the gas on. The thermostat that turns the gas on is usually located next to the pilot light.
Sep 14, 2007 | Ovens
GE JGRP20 Gas Single Oven Logo
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
