Question about LG Jabra DRIVE Bluetooth Speakerphone
Jabra in car Drive - How do I get it to dial an outgoing phone number?
I do not know how to place a call
How to unblock my outgoing calls
That was done whoever set up the system.
Nov 30, 2016 | Samsung Cell Phones
What does outgoing call are restricted by fdn mean
FDN(Fixed Dial Number) if enabled, allows you to restrict your outgoing calls to the limited set of phone numbers that are included in the Fixed Dialing Number list.
Jun 10, 2014 | Motorola Mobility Verizon Wireless Droid...
My phone has a dial tone, but when I make a call there is a short buzz and a response of "The number you dialed is not in service". I can't make any outgoing calls to anyone!... yet I can...
This isn't an issue with the actual phone. I would attempt to call a number that you know is working. Like a free 800 number from the television. If you are able to get through with that call then you should check that the numbers you are calling are in service. If you have the same problem with the 800 number then you need to get in contact with your phone company.
May 10, 2011 | Uniden DECT 6.0 Cordless Phone ID
Ristriction password Nokia E71
if you mean that you are trying to place outgoing calls where you don't want the call recipient to be able to see your number the way to do that is to dial #31# and then the number you are calling for example:
#31#310-222-3333 (the recipient will see "blocked number" instead of your number)
Aug 28, 2009 | Nokia E71 Smartphone
Retrieve last 10 dial out number
Same as the other one
It will mainly depend on the setup but usually the last 10. TO access the last 10 select the soft key menu button, down arrow on silver dial to outgoing call log. Let me know if that helps.
May 19, 2009 | Panasonic KX-T7730 Corded Phone
Retrieve the latest 10 dial out number
Can't enter outgoing phone number....I have a dial tone
  • your phone or phone company may have used or set restriction on making outgoing calls
May 03, 2009 | Lands Phones
Fax not going out/coming in
connect a phone with 4521 in the back side jack of phoneout,
for outgoing fax
place original in the adf or glass for fax
Press hookdial and dial your sending fax number in 4521 after number dialing pull the phone handset to ear when you leason fax tone from the dialing number press start button to send fax.
for incoming fax (in not automoated)
press hook dial and press start to receive
Mar 01, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Wont accept outgoing calls
you need to contact your service provider and let them know what going on. They probably send you another phonelike the same one you have
Jan 30, 2009 | Samsung SGH-J750 Cell Phone
LG Jabra DRIVE Bluetooth Speakerphone Logo
Top LG Audio Players & Recorders Experts
jairo sanchez
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
