Question about Car Audio & Video
Running lights honda civic
I have lost my running lights in the front and rear, altso my direction lights too. Is it the control unit for wipers and lights that is broken?
mail me at: aleksander_bergersen@yahoo.no
  • vwcars Nov 04, 2007
    I have checked fuses. bulbs are fine too.
    there is something wrong from the fuseboxs and out in the el.system. But i cant finde out where?
Have you checked your bulbs? fuses? the control unit is not the problem.
Posted on Nov 04, 2007
DX. Why are rear wiper and hazard signals not working?
Honda Civic How To: Hazard Switch Bulb - YouTube
? 4:54
www.youtube.com/watch?v=P3TqheRsX1w
Sep 25, 2013 - Uploaded by Honda Civic How To
Hi in this first video i will look at how you can easily change a failed bulb in a 2001-2005 Honda civic's hazard ...
DIY] 92-00 Civic REAR Hatch Glass Intermittent Wiper ...
honda-tech.com/honda-civic.../%5Bdiy%5D-92-00-civic-rear-hatch-glas...
[DIY] 92-00 Civic REAR Hatch Glass Intermittent Wiper Retrofit Guide ... The answer lies in a 1997 Honda CR-V. So the 98+ CR-V models all had their rear ... Remove the Rear Intermittent Washer/Wiper Relay from the under-side of the dash, ...
Oct 03, 2015 | 1997 Honda Civic
Fuse box layout for 2005 honda crv
No. Amps Circuits Protected 1
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38 7.5
15
10
7.5
(15)
(20)
_
10
7.5
7.5
10
10
10
7.5
7.5
10
10
20
15
7.5
20
_
_
(20)
20
20
(20)
15
15
20
(15)
20
20
7.5
7.5
10
7.5
30 Power Window Relay
Fuel Pump
ACG
ABS/VSA
Heated Seats*
Front Fog Lights*
Not used
Rear Wiper
ODS (Occupant Detection System)
Meter
SRS
Right Headlight High Beam
Left Headlight High Beam
Small Light (Interior)
Small Light (Exterior)
Right Headlight Low Beam
Left Headlight Low Beam
Main Headlight High Beam
Small Lights MAIN
TPMS
Headlight Low Beam
Not used
Not used
Moonroof*
Door Lock
Front Left Power Window
HAC Option
Rear Accessory Socket
Accessory
Front Right Power Window
Accessory Power Socket on the Center Table*
Rear Right Power Window
Rear Left power window
ACC Radio
ACC Key lock
HAC
Daytime Running Lights
Front Wiper * If equipped
Dec 06, 2013 | 2005 Honda CR-V
98 Honda Civic Wipers stopped working and are stuck in up position. Motor can be heard running when the switch is on...
bad motor. (gear box inside motor chassis)
both wipers? if one bad, the shaft is stripped. at dead wiper.
the motor can be a victim.
if the linkage jamps it can wreck the motor.
Sep 23, 2013 | 1998 Honda Civic
Where is the fuse for a 2005 honda odyssey rear wiper
First, please review this article: Where's The Fuse?
Then to answer the question you asked:
There are actually 3 fuses involved in your rear wiper system.
They are all located in the driver's fuse/relay box located under the left side of the dash.
Fuse #7, 7.5 Amp
Fuse #21, 7.5 Amp
Fuse #30, 20 Amp
These same three fuses, if blown, will also have the symptom of the front wipers not working. So if the front wipers are working, the problem has nothing to do with a blown fuse.
There are also several control units involved in making the rear wipers work:
There is the Combination Switch Control unit, the MICU Rear Junction Box Control Unit, and the Relay Control Module. These are also powered (protected) by the fuses listed above.
I would recommend Obtaining a scanner and scanning the Controller Area Network (CAN) in your vehicle to see if there are any fault codes that can help you determine why your rear wipers are not working.
Feb 27, 2011 | 2005 Honda Odyssey
I lost my manual for 97 mountaneer fusebox diagram
1. pwr antenna 7.5 amp 2. high mount stop lamp 7.5amp 3. lights 15 amp 4. left headlight 10 amps 5. data link connector 10 amps 6. airbag, blower motor relay 7.5 amps 7. lamp dimmer 7.5 amps 8. RH headlight, daytime running lts, fogs 10amps 9. autolamps, memory seat 10amps 10. blend door ( heater), shift lock actuator, cruise control, brake press limit, console, integrated contol panel, rear blower relay 7.5amp 11. radio, dimmer relay, inst cluster, autolamps 2 7.5 amp 12. liftgate wiper washer, front washer relay 10amps 13. brake on off switch 15 amps 14. antilock brakes 10amps 15. airbag diagnostic 7.5 amps 16. wiper main 30amps 17. cig lighter 25 amps 18. heater-a/c eatc module 15 amps 19. radio noise cap, ign coil, PCM power diode 25 amps 20. radio, powr ant 7.5 amps 21. turn /hazards 15 amps 22. turn hazards 10 amps 23. rear wiper relay, 10 amps 24. anti theft 10 amps 25. cluster 7.5 amps 26. rear window defrost, overdrive trans, backup lamps 10 amps 27. interior lighting 10 amps 28. GEM, mem seat 2 , 7.5 amp 29. radio CD changer 10amps 30. not used 31. rear blower relay, RH heated mirror, 7.5 amp 32. heated rear window switch RH heated mirror 7.5 amp 33. DRL module, RH LH daytime running lamp 15 amp 34. power antenna module, remote chassis unit 7.5 35. not used 36. not used
Jan 07, 2010 | 1997 Mercury Mountaineer
Honda Civic 2001 electrical issues
check all the fuses are in place (all fuses that are reqired are installed and are the right power) and for burned fuses change them.
Jan 07, 2010 | 2001 Honda Civic
Oil in my honda civic 1991 is dripping all over but only when the car is running any ideas?
your the only one that can answer where, check the oil filter and the oil light switch first.
Oct 02, 2009 | Honda Civic Cars & Trucks
Rear wiper does not work
check the rear wiper fuse in the fuse box or check the motor is connected correctly to the plug or check the motor earthing is well tightened to the chassis
Oct 30, 2008 | 1991 Honda Civic
Car Audio & Video Logo
534 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
