Question about Miele CVA4070 Coffee Maker
4070 brew cva unit /how to put the spring in thw place
SpotBert
  • 231 Answers
SOURCE: miele CVA 4070 coffee system
I called Miele hot line & here is the solution to fixed the problem... 800-999-1360.
http://www.miele.com/
Whenyou start the cleaning cycle, Don't stop the process by pulling the plug! Turnthe unit off from inside wait 5+ seconds & turn back on and thecleaning cycle should restart... If you do not use a cleaning TAB..Open& shut the LOOSE coffee Door under the drawer (Top Left) and thecycle will continue.
Posted on Jan 03, 2009
SOURCE: miele coffee maker cva 4070
OK. Here's the deal. I struggled with this CVA 4070 (F 73) problem also recently, and even posted a questions in the cyber world about it. I jiggled, re-cleaned the machine, re-read the Miele manual, and scoured the internet for schematic drawings of this brewing unit's insides. No luck. Finally after finding out I'd have to pay $199 just for a service clown to walk in my front door, I said NYET!!!  I must solve by myself. If I can take apart & fix my Dyson, etc, etc, I WILL DO THIS TOO!!  (MUST HAVE COFFEE>>>)
Pull out the brewer, turn it a quarter-turn to your right, and look at the spot where that small black plastic piece -- shaped like a block "M" or block "W" -- should be situated. Pull it out, if it isn't out already. Don't worry about yanking it out or harming these parts, said the Miele troubleshooter guy in New Jersey on the phone. They're "made from the same plastic used in football helmets."  Okey-dokey.
This approx. 1.5" wide, blocky plastic piece is part of the "slide" that takes the brewed coffee grounds into the waste container. When positioned correctly, it looks like a block "W,"  with the "wings" ointing up, and slides in just under a brown 1.5" flat piece. A small, down-facing tab on the brown piece clicks into the "W" piece and holds it in place. The "W" should feel fairly solid, although it is not rigidly in place, as the entire mechanism is a movable system to deposit the grounds in the waste receptacle.
Put everything back inside your CVA 4070 "love" machine, hit "on," and wait for it to go through its warm-up.  No F73 message?  Yeah!  Mission Accomplished. You, like I, have fixed your Miele, saved your family relationships, and saved yourself a bundle from unnecessary service calls.
Posted on Apr 09, 2009
  • 4 Answers
SOURCE: Getting Fault 73 for my CVA 4070 at start-up.
I have had the same fault 73. Miele is coming out to replace the drive and the brew unit. SHould be a $700 repair. Thank God for warranties. I'll et you know the end result once repairs are complete.
Posted on Mar 17, 2010
SOURCE: Miele CVA 4075 brew unit locked
Turn your machine off. Close the door. Depress <clear>, holding it down, press <on/off> then let go of both. Then press <clear> 3 times. On 3rd time, hold it until Service menu appears. Select <brew unit> then press left arrow to turn from <off> to <on>. Then press right arrow by <select> This will turn your brew unit drive to the correct position and you should be able to get your brew unit in/out and your waste container back in. Make sure to turn your machine off/on again to get out of Service Menu. I have a picture of how the wire needs to be inserted to get that back on. It's definitely not intuitive, but send another note with your email address and I can send the pics.
Posted on Jun 03, 2010
aviral_srms
  • 1216 Answers
SOURCE: I own a Meile CVA 4070 coffee system. The Brew
use any method which helps you
Press & hold down Hot Water button & small coffee buttons & turn ON WITH LIGHT. Release buttons.
Press & hold Large coffee button and hold until you see two '1's on the left side of the screen. Release.
Press & hold medium coffee button until you see two '2's.
Release.
Hit & release quickly Large coffee button.
Brew unit should be reset.
or
Turn your machine off. Close the door. Depress , holding it down, press then let go of both. Then press 3 times. On 3rd time, hold it until Service menu appears. Select then press left arrow to turn from to . Then press right arrow by This will turn your brew unit drive to the correct position and you should be able to get your brew unit in/out and your waste container back in. Make sure to turn your machine off/on again to get out of Service Menu.
Regards.....
Posted on Oct 30, 2010
Need Mile CVA 4070 Brew unit parts
Please contact the manufacturer for parts or his authorized dealer.
Feb 23, 2017 | Coffee Makers & Espresso Machines
CVA 4070. Where can I get replacement gaskets and brew unit?
Check with local appliance parts distributor and/or Miele to determine availability and source.
Sep 01, 2015 | Miele Coffee Makers & Espresso Machines
Miele cva 5060 when i press on shows 'insert boiling unit.' And stucks there any solutions pls .
any chance you could put up a photo of your brew unit ? something has fallen out of mine and i can't figure out where to put it !
Aug 20, 2015 | Miele Coffee Makers & Espresso Machines
I have miele CVA 4070 It just recently started only brewing about 1/2 to 2/3 cup of coffee or espresso and the rest of it goes into the waste container. So the waste container has a watery puck and...
Have you clean the brew unit with the cleaning tablets? This dissolves and rids the brew unit of the oils which in turn build up and clog the brew unit - the result being watery pucks and less product being disbursed.
Feb 21, 2014 | Miele Coffee System
I can not release the main component in my Saesco de luxe. Here a loud clicking noise when machine is turned on.
Hi
The loud clicking noise is a broken brew drive. This usually happens when you use the pre-ground button but put more than the level scoop into the brew unit. The brew unit can't compress the coffee and jams the brew unit which breaks the drive gears. Drive gears have to be replaced. I have some drive units complete.
Oct 26, 2011 | Saeco Magic De Luxe Espresso Machine
I have a Miele Coffee Machine (built-in) CVA 620-1. I got a message saying the brewing unit is blocked. I removed the waste unit, a procedure that has to be done before you can remove the brewing unit. ...
The brew unit has lose parts on left-hand-side, wiggle them up and down. Put the waste unit back, switch off the machine and then turn it on (pull the cord). It worked for me!!!
Sep 14, 2010 | Miele CVA615 Espresso Machine
Getting Fault 73 for my CVA 4070 at start-up. Have removed the brew unit to ensure is clean and plastic piece -- shaped like a block "M" or block "W" - is in the "W" position. Have tried a manual on and...
Jan 09, 2010 | Miele CVA4070 Coffee Maker
Water in the waste unit, coffee comes not strong enough, as use to, although the settings are for strongest possible and the coffee grinder is set to medium. My unit is 4075 but I think it is just the...
Your chute between the grinder and the brew unit is "glued" with coffee. Take out the the brew unit, clean it under water. Take a vaccum cleaner and put the pipe into the hole where the coffee falls into the brew unit. Move the bean container "hard" in and out ( knocking inside the maschin to loose the blockage). Switch in the main menue all to factory defaults. Put the grinder "level" into the middle again. start a brew unit cleaning process. After that you coffee must be ok again. Do not use oily beans or coated beans. the block the chute.
Mr. Cool
Sep 30, 2008 | Miele CVA4070 Coffee Maker
Miele coffee maker cva 4070
Feb 27, 2008 | Miele CVA4070 Coffee Maker
Miele CVA4070 Coffee Maker Logo
22 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
Jerry Greenberg
Jerry Greenberg
Michael Galve
Michael Galve
Colin Stickland
Colin Stickland
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
