Question about Bose Solo TV sound system - Black
Can i turn on the unit without the remote - Bose Solo TV sound system - Black
How to hard reset unit without remote
  • Reset the unit to factory default settings as follows:
  1. Press [POWER] on the unit to turn off the unit.
  2. Press and hold [FAST FORWARD] and press [POWER] and [OPEN/CLOSE] on the unit at the same time for more than 5 seconds until "PLEASE WAIT" is displayed on the unit.
  3. The power is turned on and then turned off automatically.
http://service.us.panasonic.com/OPERMANPDF/SCBT200.PDF
Feb 18, 2014 | Panasonic Audio Players & Recorders
How do i turn on the 1080p without a remote
Hi Patrick
Good luck with that, I believe there is no way of manually changing the resolution of the projctor without the remote, I have also looked for a replacement remote for this unit to no avail, unfortunately you have purchased a dead duck. and the reviews for this unit are not good.
Sorry
Andrew
Jan 09, 2014 | VVME V06b Led Lcd Projector 1080p Home...
I have c7 code
it is a communication problem between remote control and tankless unit
Temporary fix:
1 Turn off electricity to tankless and remove cover. Find two terminals that remote control connects to.
2 Disconnect remote control wiring. Turn electricity back ON.
3 Open hot water tap and see if unit works as expected.
4 Without remote, tankless will heat water to default 120 degrees F and will run without the remote.
Contact Rheem they may send you another pcb board.
Nov 11, 2013 | Rheem Paloma Tankless Water Heaters...
Can the unit operate without the remote control
Yes, by pressing the power button on the unit. It is factory set to cool to 68 degrees and maintain that temperature. To access any other settings you must use the remote control. The part # for the remote is CRMC-A750JBEZ
Aug 14, 2013 | Sharp CV10NH Air Conditioner
The buttons on my air conditioner quit working. It will still turn on and off. It is now set to fan. Will a universal remote work with it? I don't want to spend $75 on a remote(replacement remote) that...
I'm not sure there is a universal remote available for AC units. There may be, I just have not seen one. However, you can still operate the unit without the remote, if you do the following. I'm assuming you have changed the batteries in the remote and they were installed properly (i.e. Facing the right direction) and it still doesn't work or you lost the remote.
Turn the unit OFF and unplug it for 15 minutes. Once the time has elapsed, plug the unit back in and turn the ON/OFF switch to ON. The unit should have reverted back to the original factory setup settings. Which should now allow you to operate the unit without the remote, because the controls on the unit should now be activated.
I hope this helped you and thanks for choosing FixYa.
Aug 07, 2011 | Frigidaire FAM156R1A Wall/Window Air...
Unit will not turn on without the remote.
To operate the unit without having the remote .. Turn the unit OFF and unplug it for 15 minutes. After the time has elapsed, plug the unit in and turn the ON/OFF Switch to ON. You should now be able to operate the controls on the unit itself. As it should have reverted back to the original factory setup settings.
Hope this helps you and thanks for choosing FixYa.
Aug 07, 2011 | Amana ACD105R 10000 BTU REMOTE/TOUCH ROOM...
Hi, I have a goldStar GA 1866VHR split Airconditioner, (5050w cooling and 5040w heating capacity). Today I noticed that compressor/condenser unit was still running after I turned off the aircond: from the...
Thanks for your detailed information. But solution is very simple. The compressor contactor in out door unit. Struck. And hence, when you power on, without indoor commanding, the out door starts running.
Replace same type Contactor relay (In out door unit) immediately. Hope, it's helpful.
Jan 19, 2011 | Heating & Cooling
Philips 3360H - can't eject DVD
Try this..turn it off, unplug it for a min or two, then plug it back in. THEN...if the power stays off...hit the eject/open/close button on the panel.
Sometimes this activates the eject mode without turning on the unit. IF NOT, try the remote eject without turning on the unit.
Apr 06, 2010 | Philips DVDR3370H DVD Recorder/HDD...
I have a linear amp 1600 I ahve power to it but it wont work and what is the remote wire supose to be connected to?
The remote wire is supposed to be connected to the remote output on the back of the head unit that is feeding the amp.
Without the remote wire hook up the amp will not turn on.
Reason for this is, the Head Unit tells the AMP to turn on, without the remote connected the AMP is going to do nothing, find the remote switch wire on the back of your Head Unit and run the wire to the remote input on the AMP.
Sep 16, 2009 | Ultra Linear UL-1600M Car Audio Amplifier
Missing remote
I do not know how to solve it without using remote control, but you can order a replacement remote control for your unit from Panasonic part website. A new Remote Control will cost you $24.72 plus tax and shipping. Just type the model number, SC-HT1500, scroll down to find "Find Parts & Accessories" on the right, click on it. The pop-up windows appears. Choose SAHT1500, for main unit, and you will go to the page where you can order many parts for your unit. II think it is worth to invest to a new remote control since many features do not work without it. Here is the link: http://www2.panasonic.com/consumer-electronics/support/?cm_sp=Homepage%20Support-_-Header%20Support-_-Support%20For%20Customers%20Link
Dec 21, 2008 | Panasonic SC-HT1500 System
Bose Solo TV sound system - Black Logo
96 people viewed this question
Top Bose Televison & Video Experts
George Scott
George Scott
Are you a Bose Televison and Video Expert? Answer questions, earn points and help others
