No picture when 1st turned on LNT 4099FX
Samsung tv LNT LN-T4099FX need to turn tv on, and off many times to get a picture.
SOURCE: When I turned the tv on only vertical lines appeared
I talked to a Samsung support helpline and it needs to be taken to a service center for repair.
Posted on Mar 03, 2009
SOURCE: Samsung LCD Flat Screen TV LN-S2651D - Volume Problem
I lived with it for about six weeks, then took the back off the TV. Just now it seems to be fixed, but I don't know if it will last.
I disconnected the wire leading to the channel up/down, volume up/down and source board, turned on the tv, turned it back off, reconnected the cable, and everything seems fine now.
Posted on Mar 14, 2009
  • 3 Answers
SOURCE: my samsung 40
This tv has issues with 4 capacitors. These caps can be replaced for about $10. They are located at the top right corner of the power supply. They will read 10v,1000uF. I had the same problem, then I replaced them wit 16v,1000uF capacitors. And presto tv!
Posted on Jul 19, 2009
  • 257 Answers
SOURCE: Samsung LN-S3241D HDTV LCD snowy display
The main board may cause this problem. If it wass happened when you play DVD, so the main board needs replacing.
Posted on Aug 18, 2009
SOURCE: Samsung LN-R408D - No Picture
My Mom's LNR408D also had sound but no picture. I was able to fix it by soldering in a jumper wire across a blown (1.5A ???) SMD picofuse on the "T-Con" board.
Consider attempting this ONLY if you: 0) Know enough to avoid the potentially fatal High Voltage parts of the power supply board!!!
1) Are a fearless hackazoid 2) know what you're doing with a soldering iron and teensie SMD parts 3) are gonna throw the busted thing out anyway so you have nothing to lose and won't be sad if you screw something up.
4) Know enough to avoid the potentially FATAL High Voltage parts of the power supply board!!!!!
This board is at the top center under a close fitting RF shield. The suspect part was labeled "CP" on the board and marked with "P" on the part. It is visible above the right-center of the connector from the main board. An ohmmeter showed it as open, so I bypassed it with a jumper wire from connector VIN to the hot side of C13. One image shows the suspect part and the jumper in place.
The other shows the TCON board placement top-center (under its RF shield). With care, it seems possible to test the fuse and put the jumper in place without removing the shield. (Obviously don't touch anything else with the VOM leads!)
Thanks to ZORBUS and Steve's TV and Electronics for the idea.
http://www.avforums.com/forums/lcd-televisions/892447-no-picture-but-got-sound-my-samsung-lcd.html
http://www.gesda.com/transformer/Fall08_files/Page336.htm
Steve C
Posted on Sep 22, 2009
Samsung LN-S2651D LCD TV no picture
What happens when you turn the TV on? Is there a clicking noise or popping sound?
May 28, 2014 | Samsung LN-T4665F 46 in. LCD Television
Clicks for 30 seconds prior to powering on
CALL SAMSUNG ASAP!!!! THIS IS A KNOWN ISSUE AND THEY ARE GIVING A ONE TIME COURTESY FIX!! INSTEAD OF RISKING MESSING UP THE TV, HAVE THEM DO IT!! HAD THIS TV AND I LOVE IT, BEST PICTURE I EVER SEEN. TV ONLY 1.5 YRS OLD.
Jan 14, 2010 | Samsung LN-T4671F 46 in. LCD Television
Samsung LNT-4665F won't power up properly
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
You can get parts for your TV here:
http://www.shopjimmy.com/catalogsearch/result/?q=LN-T4665F+
Dec 09, 2009 | Samsung LN-T4665F 46 in. LCD Television
NEED MANUAL FOR SAMSUNG MODEL LNT 1953H LCD 19''
..review of the product and related issues:
http://www.amazon.com/review/R2LL7LEO1ABLU8
Crutchfield's take on that model and it 'ease of use issues':
http://www.crutchfield.com/S-rsaLPNJLHDO/p_305LNT1953/Samsung-LN-T1953H.html
..more specifications from that site + related comments:
http://www.crutchfield.com/p_305LNT1953/Samsung-LN-T1953H.html?tp=161&tab=detailed_info
...manual download page for 19" LCD series:
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_mdl_name=LN19B360C5D
Rule of thumb is check a similar product in case you can't find exactly what you want. Discussions on those other sites indicate they only have "user guides" for the LNT 1953H LCD 19" ..and nothing in the way
of serious service manuals (i.e. for the consumer).
Email me back for more info:
specialsystems@bizland.com
Oct 02, 2009 | Samsung Televison & Video
My samsung LNT 4065fx will not turn on..
Nevertheless, the power supply is likely defective.
Aug 17, 2017 | Samsung LN-S4051D 40 in. LCD Television
Samsung LNT-4665F takes several minutes to turn on
This could be the power supply problem, or the main board. You need technician to fine out what is going on.
Aug 16, 2009 | Samsung LN-T3253H 32 in. LCD Television
Aug 16, 2009 | Samsung LN-S3241D 32 in.LCD HDTV
4665 samsung has sound but no picture
Try a hard restart, which simply means unplugging the power cord of the TV, and replugging it after 4 hours have passed. This technique reprograms the electronics, to a certain extent.
Jul 28, 2009 | Samsung LN-T4665F 46 in. LCD Television
Televison & Video Logo
11 people viewed this question
Top Televison & Video Experts
Electro Med Services...
