Question about Centon DSP32GB-001 DataStick Pro Flash Drive - 32GB, USB 2.0
Centon usb drive not recognized - Centon DSP32GB-001 DataStick Pro Flash Drive - 32GB, USB 2.0
How do I get a DataStickPro 8 GB to allow me to access information on it or to add information to it. It is recognized by my computer but I can do nothing with it. The message from my computer keeps s
Hi kenneth,
I hope your issue has been fixed. If not please follow the below steps
first thing i am not sure which operating system are you using my guess is either windows 7 or 8.
Please proceed with caution.
use windows + R key this brings up the run box
please image below
Type the following in the runbox
diskmgmt.msc
Right click on your removable drive partition and select Change Drive Letter and Paths underDisk Management ( you can find your drive easily through size )
Change the drive letter some other drive letter like y: or b: which is not reserved by some other drive on windows
That's it . This should fix your issue
Note: images have been taken from various sources.
Sep 12, 2014 | Electronics - Others
Cant load music on centon player. Says disk
If your "Hold" button is on, turn it off. The hold button write-protects the USB drive and you cannot add or delete files.
Apr 04, 2010 | Centon Electronics 1GBMP3-001 MP3 Player
When i turn on my centon mp3 player, the screen comes on and says "mp3player" but then doesn't do anything. the screen just stays like that and none of the buttons will do anything either.
I had the same problem--It turned out to be corrupt data on the USB drive.
Remove the battery.
Make sure the "HOLD" button is "OFF" and insert the drive in your computer's USB port.
Find the USB drive in your "My Computer" menu and right click on it, then click "Format." (Note: Some computers to not supply power to certain USB ports. If you do not see the USB drive, try another port. If you can't find it using any port, put the battery back in and try again.)
Quick-format the USB device as at FAT, FAT16, or FAT32.
To prevent drive/data corruption, ALWAYS click on "Safely remove hardware" in your computer's taskbar and "eject" your USB device before removing it from the USB port.
You should have all menus and functionality restored, it worked for me.
Mar 09, 2010 | Centon Electronics 1GBMP3-001 MP3 Player
Centon Craze MP3 8GB: How does it charge or do I need to replace the battery and if so how.
MP3 players rechargeable battery is charged by connecting it to the computer's USB port or by a USB adapter charger.
Jan 01, 2010 | Centon Electronics 001 MP3 Player
No driver on my pc for centon usb datastick sport
Hello!
Your drivers can be found on the Centon website, here:
http://www.centon.com/usb/support/drivers
Oct 26, 2009 | Centon Electronics USB 2.0 PCMCIA...
I have a Centon 1Gmp3 player, have used it for one year. when I turn it on it reads "MP3 player" and does not go to my songs as it used to. it freezes and I have to take out the battery and put it back in...
which operaion system do you use?
win2000, xp, vista or such?
does PC supprt usb 2.0 ?
do you use an apple-macintosh?
(tjing s are different here!)
the PC-based Operation systems should recognize it at least as an usb-stick/removable memory storage item
if not :
- log on as administrator
goto:
settings(menu) - then : hard ware/ or system,
look for new devices, wait for feed-back:
- if recognized now, fine ! and handle stick as if it was a disk drive, format it with settings given(all music on it is gone then),
copy the files (mp3's only!), remove and test it!
or :
- if is there is driver problem, whatsoever, take down the possible error code
and come back
Jan 04, 2009 | Centon Electronics 1GBMP3-001 MP3 Player
Centon digital mp3 player problem
I don't know if this will work for you but make sure that the hold button on the side of the mp3 player is not "on" - you have to slide it off.
Dec 10, 2008 | Centon Electronics 001 MP3 Player
Cant figure out how to add music
Hey jankey mp3,
According to information provided by the manufacturer, this MP3 player functions just like a normal USB flash drive. This means that the device should appear in the "My Computer" menu under either "Storage Devices" or "Removable Hardware."
As such, you should be able to use the standard Windows "drag-and-drop" option to load music onto the player. Simply click on the music titles you want to add, drag them over the player, then drop the music files into that folder.
If you would like more information, I would suggest referring to the owner's manual documentation for more detailed instructions or the following Centon website:
http://www.centon.com/pmp/support
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 13, 2008 | Centon Electronics 1GBMP3-001 MP3 Player
Memory upgrade question
Yes that RAM should work fine even at the slower speed.
I have had terrible luck with Centon ram - I don't know why but they seem to have more failed chips than most brands.
If Compusa wont replace it see if they will refund you. Otherwise wait until Centon is open and at least you can warrantee it. See if they can swap for PC2-4200 to make sure of compatibility.
Worse case you can get Crucial (micron) RAM which almost always works at good prices from www.newegg.com or directly from www.crucial.com
Dec 21, 2007 | Electronics - Others
Centon DSP32GB-001 DataStick Pro Flash Drive - 32GB, USB 2.0 Logo
Top Centon Computers & Internet Experts
David Payne
David Payne
Are you a Centon Computer and Internet Expert? Answer questions, earn points and help others
