Question about Thermador POD301 30" Pro Series Deluxe Single Oven with Electronic Display & True Convection - Stain
Thermador oven pod301 clock broken. Can I order a replacement and replace myself?
  • Melinda Maffei
    Melinda Maffei Apr 17, 2017
    Have the same problem. Its an analog clock. It started losing time and now you can't even set the time the clock hands just get stuck in the same position. It acts like it is trying to move the clock hands, but they will not move past a certain point.
  • 213 Answers
SOURCE: thermador model sc272t oven 2 doors have dim display
there is a dispay kit you can order from bosch to fix this problem. it will come with a new display board and power control which is located behind control panel as well
Posted on Nov 19, 2007
  • 5 Answers
SOURCE: thermador c302 door hinges
487746 is the part number for the 30 inch model and
487747 is the part number for the 27 inch model if this is the parts you recieved then the should fit there should not be much difference
Posted on Jan 15, 2009
SOURCE: I have a Thermador SC301 wall oven and the display
I have just repaired two SC301 ovens myself, but it is alot of work. You can get the oven's LED lights reconditioned at a company called CGI industries. Look them up on the web and click on the link for thermador. Removing the led panel and oven relay board is an involved job, but easier if you do it the correct way. First, turn off the power to the oven. Then pull the oven out of the wall socket about 1 quarter of the way. Remove the top cover of the oven with a phillips screw driver. This reveals the oven relay board. Take a digital picture of the board to remember the wire positions, or alternatively write them down. You also need to remove the touch panel (two screws underneath) and gain access to the LED. Remove the LED panel and wires. ship both to CGI (boards only) and you will have them back in less than a week. Costs about $170 before shipping. Reinstall and turn power on. All is good.
Posted on May 03, 2010
  • 98 Answers
SOURCE: I have broken the outer glass on one of the doors
Yes. replacing the over door glass is no more difficult than removing a few screws, inserting the new glass and reattaching the screws.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=232432&diagram_id=194162#d194162
That link will take you to a detailed image of the door as well as where you can order a replacement.
Hope this helps.
Posted on Sep 06, 2011
KevinWhite
  • 1902 Answers
SOURCE: I need a replacement selector
Hello & Welcome to FixYa
You can buy it from here. Please get back to me if you have any other questions.
Kevin
Posted on Sep 13, 2011
F1 and beeping
Yes the control panel (ERC) is faulty , you can replace it yourself but best to have a company do it ,make sure they give good warranty etc
Jan 26, 2014 | Thermador SC302T Electric Double Oven
Thermador Professional Oven
hey man don;t worry i have too much solution if i explain u every thing then you confused so i explain one and if u want another then e-mail me on mango4529@rediffmail.com so listen carefully
Step 1: Turn off the power supply, both gas and electric, to the range. Then remove the burner.
Step 2: Soak the burner in a solution of mild household detergent and water. Clean it with a soft cloth.
Step 3: Clear the gas ports with a pin or needle, rinse the burner, and let it dry. Caution: Do not use a toothpick or matchstick to clean the gas ports. If the tip of the wood gets stuck in the burner ports, it could cause a serious blockage.
Step 4: When the burner is completely dry, replace it, and turn on the power and the gas supply.
An oven that won't heat can occur for a variety of reasons.
and if not then open this link http://home.howstuffworks.com/how-to-repair-an-oven.htm
Nov 23, 2007 | Thermador POD301 30" Pro Series Deluxe...
I have broken the outer glass on one of the doors on a thermador SC302TB oven. Is replacing the glass something that a handy homeowner could do?
Hope this helps.
Sep 06, 2011 | Thermador SC302T Electric Double Oven
I have thermador double electric wall ovens and I have slowly over time lost the abilitty to read the information in the window display. I took off the face plate in the hopes that it was a simple bulb or...
You need a new display kit. The display kit has a new clock relay board and the white harness to the clock. The repair is straight forward.
Apr 22, 2011 | Ovens
I have a thermador oven m#SCD302TP reading F2 F5 // HELP
F2 -Oven temperature too hot
Replace relay board if faulty. Check and replace oven temperature sensor (RTD). If failure repeats, replace ERC (electronic range control or clock).
Thank You
Sep 03, 2010 | Ovens
Thermador CMT21 clock and timer don't work
If you have the old analog clock, there is a new digital replacement kit that makes this oven look modern and give it more life
Mar 17, 2009 | Ovens
Thermador oven display is dimming
replace the capacitors on the display unit. Just did this and it now works
theblog
Nov 29, 2007 | Ovens
Thermador oven problems
Greetings, this JUST happened to me.
The solution was to break the circuit at the breaker panel for 1 minute, reset the clock, and the unit seems to work now.
Nov 20, 2007 | Thermador Ovens
Thermador model sc272t oven 2 doors have dim display
Nov 18, 2007 | Thermador SC272T Electric Double Oven
Thermador Display
Have 2 Thermador ovens, SMW272 and SC302. Both have display failure. Just repaired one with replacement display. It did not require a new control unit or harness. Have not opened up second unit yet as display is still dimly/slightly visible.
Called Thermador and received no offer of replacement parts or service. Numerous other web reports of similar failures. My neighbor has 2 dead ovens also unfixed because of outrageous repair estimates ($600 each). Do not recommend this brand.
Full kit including display, control, and harness ordered on Ebay for $170.
Sep 21, 2007 | Thermador SMW272 Electric Double Oven
Thermador POD301 30" Pro Series Deluxe Single Oven with Electronic Display & True Convection - Stain Logo
Top Thermador Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
