Question about Intel Dialogic D 41ESC Modem
Error while strating dialogic card service - Intel Dialogic D 41ESC Modem
  • cube_vinod Nov 02, 2007
    i had notable solved this problem help me soon ?
Chang the interupt setting to 4
Posted on Nov 17, 2007
Windows error recovery message at startup, tried one key recovery takes me strate to enter my password,i dont have one
Hello, If you don't have your password then you will have to remove your motherboard's cmos clock battery for a few seconds and replace it back. This disables your password..
How to remove a laptop cmos battery.
laptop cmos battery
Hope this helps.
Jul 03, 2015 | Lenovo IdeaPad U550 (374955U) PC Notebook
F12 error code
F12: Lack of Display card-Main Card Communication
1. Check the effectiveness of contacts on CNC Connector Card
2. Overhaul 8-way connector on Display card
3. Check continuity of CNC-CN 8 way connector
4. Replace Main Card
5. Replace Display Card
Jan 23, 2014 | Ariston Technologies AWD121WH
Vst system link errors
In my experience, reasons for seeing errors in VST System Link (VSL) are usually due to the digital signal path (audio and/or data) not being routed properly within the System Link dialog box. If for example, you're using s/pdif between two ASIO 2 compatible audio cards properly (OUT of card #1, to IN of card #2 - then OUT of card #2 back IN of card #1), you also have to set your s/pdif System Link I/O channels in the dialog box to the 'same' channel...If say your options are s/pdif channels 9 & 10 (or whatever they are), you set the I/O's of both computers VSL dialog boxes to either channel 9, or all to channel 10. You of course need to route your digital audio properly within your audio interface! (see your cards documentation on that).
You can test if it's routed properly by 'listening' to audio from each computer, from the other...meaning listen at computer 2, from computer 2 & visa-versa. If you hear the audio thhen it should be correct. But in order to 'hear' the audio (besides proper settings in the VSL dialog box) you must 'also' set those digital audio s/pdif channels within Cubase's VST Inputs/connections. But in 'this case', you use both channels 9 & 10 for your Inputs/Outputs. They also say it's best to place your VSL digital audio channels at the top of the Inputs/Outputs list.
You do not need to keep the s/pdif channels in the VST Inputs/connections to make System Link work however, that's if you need to 'listen' or if you need to test whether it's routed properly.
Getting VST System Link working can seem complicated at 1st, but once you understand, and have it working, you realize it's actually not that hard at all. I recommend taking notes, and writing down what you did to make it work, as you go along the way. That has come in very handy when I need to use it again. Also READ your PDF manual and follow that to the letter!
May 23, 2012 | Lexicon Omega Desktop Computer Recording...
Internal memory is too low..only 155 kb......this creates problem in strating a error..''insuffient memory'' please say solution for it
Whenever internal memory shows low that you are
using your internal in net surfing.
Go to internet history and delete the HISTORY,COOKIES,CATHES,RECENT VISITED PAGES.
After it use your memory card as a default memory.
Thanks for using fixya
Aug 19, 2011 | Cell Phones
I have a Blackberry Curve 9300 having been using it for more than year. Then did a quick business trip overseas and the phone continued to function, unfortunately 24 hours upon returning to Sri Lanka, the...
If the phone does not accepts the dialog sim card then the phone must be locked to the particular network. Check the lock status of the phone, if the network lock is enabled you need to unlock the phone.
Follow the instructions given below:
1 - Switch ON your Blackberry 9300 with your current network/service provider's SIM card.
2 - Using the menu go to Settings Menu -> SIM card and press select.
3 - While holding the SHIFT key, type mepd.(NOTE: You may not see any text appear on the screen while typing mepd)
4 - You should now see the five locking categories listed.
You can get the unlock code through online, visit the site where they are providing good service in unlocking GSM phones
Jul 24, 2011 | RIM BlackBerry Bold 9000 Smartphone
The Update Assistant keeps opening a dialog box stating that it has no access to the router. But whenever I try to do anything in the dialog box--click a button or close the dialog--an Internet Explorer...
1.Press Windows logo key + R, type winver and hit Enter key.( Check the version details of Windows 10 installed on your computer).
2.Shutdown your device ,restart it back and then initiate the upgrade to see if goes correctly this time.
If any third party Antivirus or Online security software is installed, then try to disable it for a moment then try to initiate the upgrade to see if it goes correctly.
In case problem still persist, then try to upgrade it in Clean Boot state.
1. Press Windows Key, type msconfig in the search box, and hit Enter.
2. On the Services tab of the System Configuration dialog box, tap or click to select the Hide all Microsoft services check box, and then tap or click Disable all.
3. On the Startup tab of the System Configuration dialog box, tap or click Open Task Manager.
4. On the Startup tab in Task Manager, for each startup item, select the item and then click Disable.
5. Close Task Manager.
6. On the Startup tab of the System Configuration dialog box, tap or click OK, and then restart the computer.
Apr 08, 2017 | NetGear WNDR3300 - RangeMax Dual Band...
Keyboard scramble
You have different keyboard layouts installed.
Standard: qwerty, asdfgh
Dvorak: ‘,.pyf, adeuid
To prevent the keyboard from unexpectedly switching up on you, open your control panel, select Regional and Language Options.
In the Regional and Language Options dialog box, click the languages tab, select the details button at the top of the dialog box.
In the Text services and languages dialog box, under installed services: select the Keyboard United States-Dvorak service and then click the remove button, click ok, click ok.
Dec 23, 2007 | EliteGroup P4VMM2 Motherboard
Turns on and Off by its self
try to tun it on by taking out memory card if its get strated then ur h set is hitted with virus format memory card if problem persists contact motorola service centre coz hardware issue
Sep 14, 2007 | Samsung SGH-d807 Cellular Phone
Intel Dialogic D 41ESC Modem Logo
212 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
