Question about Delphi XpressRC XM Satellite Radio Receiver with Vehicle Kit
No antenna signal - Delphi XpressRC XM Satellite Radio Receiver with Vehicle Kit
How do I get a signal from my Jack OA8200 digital tv antenna.
The signal meter should show you available TV transmitters. If you have received a signal at this location before and you definitely are sure it is powered up the antenna is defective. Check for anything that appears loose or broken. If the meter indicates a signal check the cable that goes to the TV.
Oct 28, 2014 | Jack OA-8000 Digital TV Antenna
HG8245A VS HG8245: The same Wifi Signal Strength?
Probably not...... With an External Antenna, there is nothing to stop the signal, whereas with the Internal, the Signal has to penetrate the case, before it goes to wherever...... I suggest using the External for the extra distance.... With 2 way radio the clearer the area yo have the Antenna, the greater the distance.... same here.... just using different Frequencies.
May 08, 2014 | Computers & Internet
Can a dvd player be used as an antenna
No. An antenna is a "tuned" device used to radiate or receive electromagnetic signals. Its length and shape is a function of the electromagnetic signal frequencies it is designed to radiate or receive. An antenna is designed to "resonate" at its operating frequency for greatest efficiency. A DVD player is not an antenna. It is not designed to radiaite or receive electromagnetic signals. However, it generates electromagnetic signals by decoding information from a spinning DVD disk. Antennas do not "generate" signals. Antennas only convey signals.
May 02, 2014 | Televison & Video
My signal strength is really bad on my TVs. Should I buy a new antenna?
The more tvs you have hooked up to the same antenna, the lower the signal strength. Therefore you should get an antenna amplifier or get a new antenna with a stronger signal.
Jan 31, 2013 | Electronics - Others
How do i get hd channels with no cable ? just antenna
If your TV has a digital tuner, you can get any HD channels if you use the correct antenna pointed at the transmitter and are close enough to the transmitters. (Antennas labeled as HD are not always appropriate for your location.) Your TV will downgrade the signal to 480i if the TV can't support a 720p or 1080i resolution.
First where do you live? Use antennaweb.org or tvfool.com to determine the correct placement of your antenna for your area/stations. AntennaWeb uses a very conservative signal strength calculation despite assuming an external antenna. Tvfool will give the antenna color rating which is also provided on the antenna package. When properly installed (with no trees or hills blocking the signal), the matching antenna should receive the listed channel.
If you use a splitter to share the signal with several TVs, you may need an amplifier to bring the signal strength to that needed for the tuner to interpret the digital signal. (Note: amplifiers and splitters can fail and the amplifier may become a signal filter blocking the signal; test the antenna strength on a direct connection if there is a problem.)
If you do not have a digital tuner in the TV, you may have gotten an SD digital to analog converter. These are the more common (and available with the government coupon) converters. You will need to get an HD capable tuner to see the full HD signal.
Please add a comment with your TV model and antenna choice for additional support.
(antennaweb indicates that my external antenna should only get the stations 10 miles away. We actually receive the channels from 30 miles away. We use an amplifier splitter to feed the signal to several TVs. I set up two indoor antennas for a neighbor's TVs. One gets the signals from the transmitters 30 miles away and the other from the transmitter 10 miles away. Both get HD from the stations with HD broadcast (not all channels are in HD here). The difference is totally due to antenna placement.)
Aug 10, 2012 | Hisense Televison & Video
I hooked up an indoor antenna to the TV and select ANT as an input from the menu. Still can't get any channels at all.
First try moving your antenna around (see the sites listed below for the direction to point the antenna to get a signal). If the antenna has an amplifier, try unplugging that unit. (When an amplifier fails, no signal gets transmitted.) Similarly if you have several TVs sharing one antenna, remove the splitter and directly connect the antenna to this Toshiba to make sure that it isn't causing the problem.
You may be in an area where an iindoor antenna may not work for you. Tall buildings and trees can scatter the signal to the point where a digital tuner can't get enough signal to "read" the data. Again use the results from the sites listed below to check what stations are likely to be received in your area.
Different TVs have different tuner sensitivities. An amplifier may help bring in enough signal to get the channels. (Signal loss is inevitable. However, if the signal is sufficiently poor, an amplifier may give you more noise and won't help.)
There are two sources for a site specific list of channels: Antennaweb.org and tvfool.com . Antennaweb assumes an external antenna and is very conservative in the list of channel that you should receive. (It lists two channels from one transmitter in my area.) Tvfool will indicate the channels that you should get with different antennas (indoor, outdoor, amplified signals).
A rare issue can be that the tuner in the TV has failed. The only way to check that is trying the TV with different antennas (or in different areas - one with high signal strength).
I hope this helps.
(ATSC (digital OTA signals) are either enough to read or not. You can't get the fuzzy signal of an edge of range analog signal.)
Aug 15, 2011 | Toshiba REGZA 47HL167 TV
Am/fm radio stations not clear... I have the AM antenna attached... but there is no attachment for FM
First of all check for any nearby source of interference.....Move your unit away from all computers, fluorescent lights, neon lights, microwaves, cell phones, and cell phonemag-glass_10x10.gif chargers. These devises tend to produce noise in the medium frequency band, where AM radio is broadcast.
If the unit plugs into the wall with a nonpolarized plug (where both prongs are the same size), try reversing the plug inmag-glass_10x10.gif the outlet. Moving the plug to another outlet might help, too.
check for fault in the antenna lead, (common) or bad earth on the antenna to body
If you don't have an antenna connected to your FM receiver,With a receiver or tuner, connect a wire-loop or T-shaped dipole FM antenna to the back of your unit. Move the antenna until you get the cleanest signal. Use a signal-strength meter or display to gauge signal strength if your unit has one.
  • Step 2 If you're still not getting a good signal, try an indoor amplified antenna, which you'll find at an electronics store. Don't buy one unless you get a guarantee that you can return it for full credit if it doesn't solve your reception problems.
  • Step 3 If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters.
  • Step 4 If you're using a portable FM radio where the only antenna is the power cord, stretch the cord as straight as possible and experiment with positioning again.
  • Step 5 Temporarily switch to monaural mode to improve a weak signal on an FM receiver.
  • Read more: How to Strengthen FM Radio Reception | eHow.com http://www.ehow.com/how_114024_strengthen-fm-radio.html#ixzz0u9nhGXAL
    If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters. Make sure to Switch from stereo to mono.
  • Step 4 With a receiver or tuner, connect a wire-loop or T-shaped dipole FM antenna to the back of your unit. Move the antenna until you get the cleanest signal. Use a signal-strength meter or display to gauge signal strength if your unit has one.
  • Step 5 Alternatively, upgrade to a third-party passive or powered antenna.
  • Step 6 Install a rotatable roof antenna for the best possible reception. Connect your unit to an existing televisionmag-glass_10x10.gif roof antenna for the next-best alternative.
  • Read more: How to Improve FM Reception | eHow.com http://www.ehow.com/how_5554_improve-fm-reception.html#ixzz0u9oTaz4Y
    Jul 19, 2010 | RCA RT2760 System
    I can't get FOX on my converter box--what is the channel # for FOX?
    It could be your antenna. Some retailers sold consumers UHF-only outdoor antennas and not VHF/UHF combo antennas. Other outdoor antennas may not have a power boost included for the VHF antennas (rabbit ears). The new DTV signals from stations are now broadcasting in lower power signals than before June 12.
    Outdoor Antenna
    KMSP/FOX 9 and KARE 11 both broadcast on VHF signals. WCCO and KSTP broadcast on UHF signals. You will need a VHF/UHF outdoor antenna to pick up KMSP and KARE 11 and also get all the other channels.
    Indoor Antenna
    Check your antenna to make sure it's a UHF/VHF antenna. You may need an indoor antenna that has rabbit ears -- that is the best way to get KMSP/FOX 9 reception on your TV. Your antenna should have a power boost to amplify the VHF signal if you are having trouble getting FOX 9 or KARE 11.
    What Antenna Is Right For You?
    Need help locating the proper outdoor antenna to receive your local television broadcast channels? Based on geographical maps and signal strengths, AntennaWeb.org locates the best antenna for you, whether it's a home satellite system, high-definition television (HDTV) or a traditional analog set.
    Make sure you antenna is pointed toward Shoreview, where FOX 9 transmits from.
    CALL FOX 9 FOR HELP: 952-944-9999
    Apr 07, 2010 | Televison & Video
    As suggested by FCC, I moved the antenna to the other side of the TV, facing south, where the transmission tower is, but the picture and sound are still breaking up. Do I need to move the antenna closer...
    Is the antenna suitable for digital TV signals?
    The TV signal is weak, if the antenna is an un-powered device then I suggest you get a powered antenna, this will amplify the signal.
    Moving the antenna closer to the window will help.
    Jan 26, 2010 | Televison & Video
    How to improve on Wireless Range
    You can use repeater with your router to increase wireless router signal strength.
    Feb 19, 2006 | NetGear RP114 (RP114CN) Router
    Delphi XpressRC XM Satellite Radio Receiver with Vehicle Kit Logo
    Top Delphi Audio Players & Recorders Experts
    John
    John
    Darrell
    xxxxxx xxx
    Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
