Question about Holley 1985 Ford Bronco 5.8L Mechanical Fuel Pump
Ignition switch dont work can i bypass it
Lost keys ripped ignition out put switch on solenoid will crank and run but cant turn it off without stalling it out and have to unhook battery or it will drain it so what wires can I put a toggle switch on to fix my problem
    Champion:
  • 216 Answers
LOOK AT IGNITION SWITCH IT HAS A PIN THAT HOLDS TUMBLER FOR KEY. DEPRESS PIN AND YOU CAN REMOVE TUMBLER, PULL IT OUT AND HOOK IT BACK TO WIRE HARNESS. JUST USE A SCREWDRIVER TO START AS USUAL.
Posted on Apr 20, 2014
I have a 2008 Pontiac G5 that will not crank I think it's the anti theft lock how do I bypass it and it's been sitting for 8 ,months and someone ripped the ignition switch out
To fix your problem Fix what they ripped out first. You can get the key/lockset and ignition switch at parts stores. Fix wiring also if needed. After it is back to normal. Do a relearn for the key. Put a battery charger on the battery( you don't want it to go below 8 volts). Turn the key on for ten minutes, off for thirty seconds. Three times. Then try to start. If the voltage gets to low or you hit the starter at any time, you have to start over. This will reprogram passlock III keys to the security.
Nov 21, 2016 | 2008 Pontiac G5
I have a 2008 Mazda tribute when I put the key in and turn it it lights up as normal but when I turn it to crank it nothing happens... In the pass I would put the key in while turning it and it would crank...
It could be any of several things. I would start out with some basic testing. Battery good? If yes, then ignition switch. When you turn the key, it makes a connection from the key switch to the solenoid. Check with a test light at the switch and at the solenoid (on top of the starter). If no light at the started, try running a wire from the battery to the solenoid. Does it click/turn over? If no, then maybe starter. .
It's rather like a chain. If all the links are good, then it will start. If any of the links are broken, then it won't. Sometimes a "click" can help you identify where that chain is broken.
Oct 31, 2014 | 2002 Mazda Tribute
2004 grand vitara will not start and solenoid will not click, Battery is fine.
Sounds like the ignition interlock at the transmission switch is out of adjustment or faulty. Bypass the key switch, at the starter, if it now cranks, it's in the interlock switch or the ignition switch.
Feb 06, 2013 | 2004 Suzuki Grand Vitara
How do get the engine to crank or turn
check that you have put the small wire on the correct terminal of the starter solenoid. The solenoid will require power from the ignition switch to close the contacts the make the starter spin
Jan 10, 2013 | 2004 Cadillac Deville
Starter/solenoid/ignition bypass?
I think what your co-worker is doing by touching the solenoid while the car is on is quite dangerous especially when it is running. I understand the need to avoid putting off the car but you will just have to get your own towing accessories and truck if you keep going on like this.
My advice would be to take your car to the garage and fix the problem once and for all.
Keep me updated!
Nov 30, 2012 | 1997 Mercury Grand Marquis
~ 1991 STX38: Starter engages, engine cranks but won't start, when key is turned off, engine continues to crank. Disconnected battery to stop engine from cranking. Upon attempting to reconnnect battery...
The starter solenoid may be stuck in the on-position. To check this, on the starter, remove the small wire connected to the solenoid coil terminal. If the starter still runs, the solenoid is stuck on. If rapping it with a hammer doesn't stop it, the contactor pin is welded to the motor contacts.
Jul 02, 2017 | John Deere Garden
How do i bypass the security on my chevrolet s10 so that it will crank
YOU CAN CRANK VECHICLE BY PUTTING KEY IN THE IGNITION SWITCH IN ON POSITION FOR 10 MINUTES UNTIL SECURITY LIGHT TURN ITSELF OFF.THEN TURN OFF IGNITION SWITCH FOR 5 SECONDS THEN START ENGINE.YOU CANT BYPASS THE THEFT SECURITY SYSTEM BECAUSE ITS A FEATURE THAT CAME WITH TRUCK.THEFT SECURITY SYSTEM IS CONTROL BY BCM AND PCM. IF YOUR IGNITION KEYS AND SWITCH IS FAULTY ALSO THE BCM THEY ALL HAVE TO BE REPLACED AT DEALERSHIP AND REPROGRAMMED CANT BYPASS SYSTEM YOU HAVE TO GET IT FIXED.
Mar 12, 2011 | 1999 Chevrolet S-10 Pickup
98 Ford F150 4.2 Liter Engine will not crank keeps blowing fuse #21 (15amp) as soon as I turn the ignition key. Was running fine just stopped to gas up and it wouldn't crank. Jumped the posts on the...
Sounds like there's a grounded wire somewhere between the ignition switch and the solenoid. When you bypass the switch with the screwdriver you don't ground out the line, but with the switch the ground shorts the circuit, blows the fuse, and then won't start the engine.
Apr 18, 2010 | 1998 Ford F150 Regular Cab
Wont turn over with key?
W/out knowing details on your vehicle, it makes it very difficult to help. Year? Stick or auto>? engine/trans info. Does it have an alarm installed or a factory security system?
Common checks would be park/neutral switch (Or clutch switch if its a stick), fuses (some cars actually fuse the start signal), old alarm brain that has activated and cut off starter signal, and do the cluster lamps go into SELF TEST and all light up when you turn the key to CRANK. If the lamps do the normal cranking bulb check, then likely your ignition switch is working. depending on the year, ford ignition switches sometymes could be a common problem. But without info to look up a diagram, cant offer more help than generalities
Sep 17, 2009 | 1988 Ford F 150
Will not start. Can jump accross the selinoid and
I assume that you are jumping the solenoid in order to bypass an ignition switch that is no longer operating?
If so, did you have the key turned to the run position?
You should not need to bypass any safety switches, just be sure that everything is in the normal starting position. (deck disengaged, in neutral, etc.)
Either way, it sounds like you have a bad ignition switch, or faulty wiring between the ignition switch and the solenoid.
Jul 30, 2009 | Garden
Holley 1985 Ford Bronco 5.8L Mechanical Fuel Pump Logo
46 people viewed this question
Top Holley Plumbing Experts
bobalix
Gil Shultz
Jerry Kramer
Jerry Kramer
Are you a Holley Plumbing Expert? Answer questions, earn points and help others
