Question about Ulead Videostudio 8 for PC
Easycap record error - Ulead Videostudio 8 for PC
Windows7 64bit & EasyCap directions
In my experience with the Easycap software the quality of sound & vision is very poor. My recommendation is as follows:
1) Use windows movie maker instead to capture video.Use the 2M byte/sec capture rate. Make sure the box for "make video clips" is NOT selected - you probably don't want your vid chopped into little bits.
2) In my experience USB audio is rubbish on these devices, so instead connect your PC or laptop audio LINE IN to your sound source. Don't forget to set sound source in RECORDING section of Control Panel Sound devices to Line In instead of your Easycap (which the Easycap drivers would have preset it to by default).
Good Luck.
May 17, 2014 | DekCell EasyCap USB 20 Video Capture...
EasyCap bad audio input quality !! HELP!!
Already answered in a previous post!
Mar 15, 2014 | GE EasyCam Webcam
When trying to copy VHS tape to pc with EasyCap and original software all works well, audio and video then stops after 6 minutes. I can stop and restart capture from this point and again error after 6...
Ok check you have enough RAM the more the better, Check how much hard drive space is left, on your 60GB drive, sometimes if there isn't a large amount of space ..like 10 - 15GB you can have problems. Actually I would also suggest you try another program to record to your PC. try Dscaler this is simply the best there is. http://deinterlace.sourceforge.net/ Even though it says for TV, it is the BEST recording program out there and works with most input devices.
Feb 06, 2010 | Ulead Videostudio 8 for PC
Ulead 11 with EasyCap on Windows Vista
souds like you have not selected the correct video type - try all the diff Pal ones
Apr 08, 2009 | Televison & Video
EasyCAP USB 2.0, can't install driver from CD, Window Vista
Your going to need to download the drivers for it off the internet. The same problem happened to me so i decided just to search for the drivers. I downloaded them, and then when i was installing it asked "Search computer for drivers" so i did that and found where i had downloaded the drivers to and then the EasyCap Capture Card worked. The only problem is you will need a good recording program to record with because the program they give you probably will not work. I decided to download AmCap which is a software that lets you record with your Easycap. Also i downloaded Pinnacle Studios 12 to record. If you have a Windows xp computer you can use Windows Movie Maker to record.
Dec 10, 2008 | DekCell (CPA-1040)
Problems with easycap
do you have enough memory on your computer to complete the recording? i had a problem once where it stopped recording because i was running low on memory. in that case i just had to delete unnecessary things to make room.
if that is not the issue, please take a screen shot (the button on your keyboard that says "Print Screen", then go to Paint and click edit>paste) and show me the messages you are receiving, and i may be able to help.
Jun 06, 2008 | Ulead Videostudio 8 for PC
Ulead Videostudio 8 for PC Logo
Top Ulead Computers & Internet Experts
d3yavu3
Alun Cox
Karan Sethi
Are you an Ulead Computer and Internet Expert? Answer questions, earn points and help others
