Question about Drills
The lock button will not lock - Drills
How to turn off child lock of LG refrigerator vth model number GL- 528?we already tried by holding it for 3 sec....it doesn't works at all....nd have a beep sound too
Pressing this button stops operation of other buttons.
"Locking" or "Un-Locking" is repeated whenever pressing the CHILD LOCK button. (For "Locking" or "Un-.Locking" press the "CHILD LOCK" button for 3 secs.)
When 'CHILD LOCK' is activated, pressing the other buttons would not work.
Aug 22, 2016 | LG Washing Machines
Child lock turn off
For the Candy CH642B cooktop:
LOCKING BUTTON OPERATION
The locking function prevents the children from starting the hob. It is also used for cleaning the control strip as the controls can be locked without the hob being on.
To lock the hob :
- Press the on/off button
- Press simultaneously " - " button and " + " button of the front right zone (CH 633 front left zone), and then press again on the " + " button of this zone.
When the hob is locked, the locking indicator " L " is displayed on all zones for 20 seconds.
To unlock the hob :
- Press the on/off button. The locking indicator " L " is displayed on all zones.
- Press simultaneously the " - " button and the " + " button of the front right zone (CH 633 front left zone), and then press again on the " - " button of this zone. The hob is unlocked.
Dec 05, 2015 | Cooktops
Door locks
Replace the door panel switch on the driver side
Mar 15, 2017 | Pontiac G5 Cars & Trucks
Where is the resset buton on frigidaire electric dryer machine?
  1. Press and hold the "Control Lock" button for five seconds to lock the dryer. Release the button when the dryer beeps, indicating that the dryer is in locked position.
  2. Press and hold the "Control Lock" button for five seconds to release the lock.
  3. Press and hold the "Options" and "Select" buttons at the same time on Frigidaire dryer models that do not have a "Control Lock" button. Hold the buttons for 10 seconds until "LOC" is displayed.
  4. Press and hold the "Options" and "Select" buttons simultaneously and hold for 10 seconds to release the door lock.
  5. please comment on these by telling how helpful.
Dec 20, 2010 | Frigidaire Electric Dryer
Help me my system is OSD Lock give me the solution.
Option 1: OSD lock - all 4 buttons are locked except the "POWER"
button. Press and hold the "MENU" and ">" buttons for 3
seconds to lock the buttons. Repeat this step to unlock.
Option 2: OSD & Power button lock - all 5 buttons including the
"POWER" button are locked. Press and hold the "MENU"
and "<" buttons for 3 seconds to lock all 5 buttons. Repeat
Mar 06, 2010 | ViewSonic E70f 17" CRT Monitor
The panel of my frigidaire dishwasher has a dummy light signifying a lock. it will not respond to any other button
to lock this unit out you have to hold the lock button down for a few seconds until lock light comes on. lock button could also be a combination button with start button or some other button. hope this helps!
Aug 29, 2009 | Frigidaire Dishwashers
Step by step reset the door remote control lexus 400LS
1. sitting in driver seat, with driver's door OPEN, press lock/unlock button ON THE DRIVERS DOOR to lock all doors, then manually unlock driver door only.
2. Insert YOUR key in ignition, DO NOT TURN, then remove key.
3. Using the same lock/unlock button ON THE DRIVERS DOOR, slowly press lock-unlock in 5 cycles
4. Shut door.
5. Open door.
6. Using the same lock/unlock button ON THE DRIVERS DOOR, again slowly press lock-unlock in 5 cycles
7. With the door open insert your key into the ignition, turn to 'on' position (DON'T START), wait 5 seconds. Turn off and remove key.
8. Locks should cycle once (Car will lock and then unlock once by herself). If they don't cycle or they cycle more than once, do steps 1-7 over.
9. Now using the remote, push lock button, hold for one second, then release the button. The locks should cycle once. If not, start over and go slower.
10. Close the door.
11. Open the door.
12. Press the lock button on the remote. The locks should do a lock-unlock cycle.
13. Close the door
14. Press the lock button on the remote, the doors should lock.
15. Press unlock button and the doors should unlock.
Jun 16, 2009 | 1996 Lexus LS 400
Mitsubishi tv
Without the code, you must get an original remote and press the "QV" and the "9" buttons together to unlock the TV.
Oct 16, 2007 | Televison & Video
Drills Logo
26 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
