Question about Sharp EL-1801AII Calculator
Paper will not,n. what to doumbers printing on top of eah other
HP 6110 Officejet all-in-one will not print from the glass top. It will make prints coming from the computer after I press "enter" from message "paper jam". I also can fax. Please help.
You will need to open the top and look inside where the paper travels through and attempt to free any paper pieces that have gotten stuck in the pathway. You probably have a bad board in your control panel, since you are able to print from the computer.
Feb 20, 2013 | HP OfficeJet 6110 All-In-One InkJet...
Eah 5570 - GIGABYTE GA-K8NF-9
Did you disable the onboard video in the Bios?
Jun 19, 2012 | Gigabyte GA-K8NF-9 (890552602964)...
Which way do I insert the transparency into my front loading MP 560 Canon Printer.Shiny side up or down Thank you V
It depends on which side you want to print on. For transparencies, you want to print on one side only. Most likely, you want to print on the shiny side; essentially as if it were a glossy photo. Load the transparency so that the shiny side gets printed on. Don't know that part? Front loading printers are the easiest to determine which side is printed on. Look at where the paper goes in and where it comes out. Think about it; for single sided printing, the paper isn't being turned around inside; merely rolled around an internal roller, then back out. Watch what happens to the paper the next time you print on a single side. See if the top of the printed page came out first, or last.
The most common designs of front-loaders have the paper come out above where it went in. The paper curls around the bottom of the internal roller and comes right back out on top. Therefore, the printed side started out on the bottom, then curled around the internal roller and came out with the printed side up.
Most front loading printers have the top of the printed page come out first; therefore, the same edge that went in first, got printed on first. With that in mind, if you ever want to print on the unprinted side of a piece of paper (that is already out of the printer), obviously keep the printed side up, but since the top of the printed side came out first, you need to make sure the top goes in first to come out first for the back side.
Your Canon 560 printer has duplex printing, so it is a good idea to run your test to see what happens when printed on a single side, and what happens if you use the duplex-mode. For duplex mode printing, after printing on one side, the printer pulls the paper back in to print the other side automatically. Think about how much space is inside the printer. Depending on how much data the printer can store, either the first page is printed, then the second page, or the second page is printed first, then the first page. It depends on how the printer wants the page to come out. You can run a simple test and see exactly what happens.
Since the printer cannot easily turn the paper around, it merely starts with the opposite end of the first printed side when it prints on the back. If the top of the page came out first for the first printed side, the printer prints the bottom lines of the second page of text working back to the top in reverse order. As a result, the bottom of the page comes out first, with the top coming out last.
Some duplex printers can store so much data that the determine how the second page will look, print it first, then print the first page. Watch to see what yours does.
Worse comes to worse, mark a sheet of paper in one corner, insert it into the printer, then print a document that contains only the period character and see where it is printed. By knowing how you put the paper in, and where the period was printed, you can tell how to handle any situation. By the way, the period character was chosen because it will be so small that most likely you can use that sheet again.
Jan 07, 2011 | Computers & Internet
Printing on a customise continuose paper
Check the printer settings about page length by the procedure given in the user manual.
If OK check your software if it is giving soft commands to adjust paper lengths.
Sep 28, 2009 | Epson LX-300 Matrix Printer
My printer is only printing half of the page
half page? just half top page (top-bottom), or left and right. If just left half page, set page setup as actually paper wide that inserted. because, if actually paper wide is smaller than page setup, some epson printer jsut print half. before starting printing, the paper sensor measure paper wide first.
Jun 08, 2009 | Epson Stylus Photo 925 InkJet Printer
Want to print on legal size paper from Tray 1 (top) as default
print menu - config and verify paper is being sensed correctly. If paper size in tray is not set correctly printer will ask where to print from
Feb 12, 2009 | Lexmark T640 Laser Printer
Toshiba 2060 will not print 1/2" from top side with letter paper
Have you tried the manual feed tray? Which way is the letter size paper being feed in? LTR or LTR-R. You may have a reg. clutch that is slipping. I would also look to see if you have any paper jamed behind the paper tray and make sure the paper trat is displaying that ltter paper is in the papre tray the same way as displayed. Good Luck
Feb 02, 2009 | Toshiba 2060 Copier
Grinding Sound - Orange Paper Jam Light
You have a broken gear main motor. I had the same problem, bought $5 part and after the replacement of the gear,it runs like new
Dec 04, 2008 | HP LaserJet 4L Printer
Printing
Dear jamin4volks;
As per this excerpt from the Oki B4350 User manual:
"FACE UP AND FACE DOWN PRINTING
For face down printing, make sure the rear paper exit tray is closed (the paper exits from the top of the printer). The paper exit bin on the top of the printer stacks printed pages face down, capacity 150 sheets of 20 lb. paper. Pages printed in reading order (page 1 first) will be sorted in reading order (last page on top, facing down).
For face up printing, make sure the face up rear paper exit tray is open and the paper guide is extended if required. In this condition, paper will exit via this path, regardless of driver settings. Paper is stacked in reverse order, capacity 50 sheets of 20 lb. paper.
Always use this tray and the manual feed tray for heavyweight stocks to reduce the possibility of paper jams."
This manual is available at http://my.okidata.com/mandown.nsf/(MOC-B4350)/BE70FCAF93D577E285256E89005052F9?OpenDocument
Hope this helps;
Frank
Apr 18, 2008 | OKI B4350 Laser Printer
Sharp EL-1801AII Calculator Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
