Strong 5405E set top box
I am setting up this Strong 5405E set top box to a Sharp CS 68NF5 television.
I am almost set but just get the blue screen. I get the Format number required 576i but it then settles to 34. The 576i just wont stay. What do I need to do
Strong SRT 5006 Set top Box - how to unlock Channels so they dont require password everytime??
Posted on Mar 05, 2010
Sound problem with Standard (CRT) Televisions along with set top box
From your description, it is likely that there has been a failure in the TV sound system.
Dec 27, 2013 | Televison & Video
I need help with setting the color on my sharp aquos LC-40LE820UN. My reds are brown,my greens are brown, and my blues are very bright.
If the colors do not change when pressing the av mode button and selecting dynamic fixed then there is either a problem with the component cables you are using (most likely), a problem with your set top box or a problem with the television. I recommend trying another set of cables first. Try all of the television's inputs and connect different devices to it.
Mar 11, 2011 | Sharp Televison & Video
I AM UNABLE TO PROGRAM MY SET TOP BOX (STRONG SRT 5405E HD) TO MY PHILLIPS UNIVERSAL REMOTE SRP2008B/86. I HAVE ALTHOUGH PROGRAMMED MY TELEVISION SHARP TO THE UNIVERSAL REMOTE. COULD U SEND ME...
Your Philips URC may not have an applicable code. All URCS do not contain all possible codes. Try code search before giving up and trying a different one.
Feb 06, 2018 | Televison & Video
HOW DO I GET THE BLUE BOX ON MY SHARP AQUOS LCD TV TO STOP POPUP
This happens when you are connecting with a coaxial cable. If possible you will need to connect your set top box to the television with a composite/RCA cable and watch tv on input 2 instead of on input tv.
Mar 19, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Remote not working after replacing baterries.remote is for set top box strong 5405E
To check if the r/c is working...If you have a phone with a camera,look at the top of the r/c through the camera,you should see a light when you press any button,if not the r/c is faulty.
Jan 31, 2010 | Televison & Video
Black box covering the top of the screen.
go into customer setting and turn off closed caption
Sep 23, 2009 | Sharp AQUOS LC-20D30U Television
Turn on goes blue then turns off
The most common reason for a TV to display a blue screen with no picture is because the source device has not been set to the proper mode.
If you are using a cable or satellite set-top box, ensure that it is turned on and set to an active station. If the set-top box is connected to the television using a coaxial cable, then the television should be set to Channel 3 or 4 to receive the signal.
If you have are using a VCR that is turned on, but not playing a tape and not tuned to a receivable channel, then a blue screen will be displayed on the TV. To resolve this, turn off the VCR or tune it to a receivable channel. If a cable or satellite set-top box is connected to the VCR using a coaxial cable, then the VCR should normally be set to Channel 3 or 4 to receive the signal.
If the blue screen is not because of a connected VCR or set-top box, the TV may require service.
Sep 22, 2009 | Sony KP-57WS500 57" Rear Projection...
Stereo/Mono Fluctuation Screen Display Problem
I had the same problem.
All I did was unplug the standard cable wire from my tv and used RCA cables to connect my TV to my digital cable box the the Input 1 jack in the back. It also increased the video quality.
Aug 07, 2008 | Sharp LC-42D64U 42 in. LCD HDTV
Aquos Channel Bar/audio bar
There is no factory option to stop the box from poping up every time the signal changes, which is what is happening. It has something to do with signal strength or the fact that your cable box is not set up for HD. Call your cable company to get a tech out to check your signal and set up your cable box because they do not come pre-set with HD defaults.
Jan 12, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Televison & Video Logo
849 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
