Question about Vehicle Parts & Accessories
What engine oil do I put in my Sym jet 4 R scooter 2013 model
What engine oil do I use
    Problem Solver:
  • 7 Answers
More than likely 15w 40 but 10w 40 or even 20w 50 should work just fine
Posted on Dec 17, 2014
What oil to put in a Sym scooter
Hi, Silao you should refer to your owners manual for oil recommendations more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Choosing the proper Engine Oil for your Scooter
Oil for SYM Symply Symply 50 2010 and after Which oil is the best...
What Type of Engine Oil Should Use in My Scooter
Oil
ScooterCommunity
May 08, 2017 | Sym Motorcycles
Can I lower the ride hight of my Sym Jet 4 125 as I find it hard to put my feet down
Hi, Terry here are some options for lowering your bike depending on your needs and how much "DRACHMA" you have in your wallet:
1. Rear shock lowering kit.
2. Front fork lowering kit.
3. Shorter rear shocks.
4. Shorter front forks.
5. Thinner padded seat.
6. Lower profile tires.
Please be aware that some of these options or a combination of options will require a shorter kickstand or your stock one modified. For more information about your issue and valuable "FREE" stuff that you will need please click on the blue links below. Good luck and have a wonderful day.
Adjusting Ride height on the rs125
http://motocrosshideout.com/2011/12/07/6-ways-how-to-lower-the-seat-height-on-your-dirt-bike
Sym Service Manual
Jet 4 125 AD12W1 6 SYM Sanyang Scooter Parts Racing Planet UK
Sym Jet4 125 Owners Manual Eng pdf
Feb 26, 2017 | 2011 Sym Jet 4 125
Hi got a sym jet 4 rode it parked it up and now no spark at all help please is this a comon thing 2014 plate to
Hi, Ben and the usual suspects are:
1. Fouled spark plugs.
2. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting, leaking, spark plug cable connections loose check for spark leakage in the dark.
6. Faulty ignition coil or electronic control module.
7. Faulty CKP, CMP, or BAS sensor.
8. Faulty ignition switch.
9. Tilt sensor needs a reset.
10. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
no spark at all on 50cc sym jet euro sport Scooter Doc Forum
My scooter has no spark how to fix gy6 chinese scooter 139qmb qmb139 50cc...
Sym Jet 50 Service Manual
SYM JET 50 Spares Parts Accessories
SYM Fiddle II 125 AW12W Service Manual
SYM JOYRIDE 125 User Manual
Jan 16, 2017 | Sym Motorcycles
How to refuel a sym jolie 50cc scooter, do you mix oil into the petrol tank, or do you fill the oil and fuel seperatley or does it mix it itself????
Pretty much all are normal petrol in the fuel tank and the oil is on another tank. The oil is mixed as it enters the inlet manifold.
Your manual is here. Section 2-3
ScooterCommunity
Nov 06, 2016 | Sym Motorcycles
I need crank shaft for SYM HD 200 EVO 2013
Hi, Said for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
2013 SYM HD 200 Evo Parts
SYM HD200 Parts SYM HD200 Scooter Parts SYM Parts SYM HD200 Replacement...
http://scooterunderground.ca/knowledge/manuals/documents/SYM_HD200_Service_manual.pdf
Sym HD Evo 200i 2011
Aug 03, 2016 | Sym Motorcycles
How can I replace air filter?
Hi, Rachael sorry you can't find the first and best tool you ever bought for your SYM despair not for a mere $0 you can download another one. For more information about your issue and free downloads that you will need please visit the websites below. Good luck and have a nice day.
http://www.sym-center.ru/files/jet-all.pdf
SYM Owners Manual
SYM Jet 4 125cc
Jan 24, 2016 | 2010 Sym Jet 4 125
Strating PROBLEM
Hi, Andrew and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Vacuum line from the petcock to intake manifold cracked.
5. Float needle and seat sticking.
6. Float level too low.
7. Carburetor bowl vent line clogged/blocked/pinched.
8. Idle adjusting screw set too low.
9. Air/fuel mixture screw set too lean.
10. Idle port, transfer ports, slow air jet clogged.
11. Slow fuel jet clogged.
12. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the blue links below. Good luck and have a wonderful day.
Why won my SYM Jet motor scooter start
Scooter Troubleshooting Scooter won start All about Scooters
SYM Sanyang Scooter Parts Racing Planet USA
Sym JET 50 series Owner Manual
May 09, 2017 | 2007 Sym Jet Euro X 50
Repairing a sym euro jet x 50cc scooter all aspects
Hello
Is it a GY6 Motor?
Go to www.scootdawg.com this forum should have wat you need also www.scooterrebels.com as well
Best Reguards
Larry
Dec 31, 2009 | 2004 Sym Husky 125
Scooter wont start
carb could be clogged with trash even though fuel is gettin to carb the main jet could be blocked not letting fuel enter intake
Aug 02, 2009 | 2004 Sym Husky 125
Vehicle Parts & Accessories Logo
56 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
