Question about Porter Cable FR350A Factory Reconditioned 3 1/2" Round Head Framing Nailer Kit, 70 120 Psi
Coil framing nailer doesn't return on contact firing
2 Suggested Answers
  • 1388 Answers
SOURCE: Plastic gear broke
Porter cable parts are available at www.toolpartsdirect.com. I believe that the part you need is also available by itself and in a repair kit from your local dewalt repair center.
Posted on Nov 25, 2008
Fires first nail will not fire second nail
Ez test. With nails removed, and door open driver should be at top of cylinder. If driver is down replace piston oring. If driver is up, lightly strike nose of gun against softwood. The driver should stay at top. If driver drops with light tap replace piston oring. If driver stays at top dry fire the nailer against softwood. The driver should hit the softwood leaving a mark and return to top. If driver stays down or does not travel all the way up pull the cylinder and make sure checkband is installed. Checkband is oring or rubber band covering series of holes on lower part of cylinder. Good luck
Jun 21, 2015 | Stanley Bostitch Coil Framing Nailer
Paslode cordless framing nailer doesn't fire
check date on bottom of fuel canister, fuel goes bad
Sep 17, 2012 | SK Paslode Sk312 Framing Nailer O`ring...
DOESN'T FEED,IT MIGHT MISS SHOOT A TIME OR TWO THEN GET A NAIL THEN NOT FEED.I'M SHOOTING A 1.5"TECO NAIL. ANOTHER GUN DOESN'T SHOOT EVERY TIME LIKE THE DEPRESSOR ISN'T LETTING THE...
Usually miss feed happens when the driver does not return to top position not allowing the nails to feed into position. Easy to check, point nose of nailer up then down again to see if the driver is loose in the cylinder. If loose, the driver will be in the down position when the side door is opened. If driver is down, replace driver oring. If driver oring is good, look for spring tension on feeder and check feeder spring on the door side. If piston oring good and feeders have good spring tension, suspect lower bumper cracked(remove head and piston to check bumper).
On gun with depressor (safty foot) not actuating trigger, look for worn trigger (trigger inner lever could be worn) or loose or worn firing pin in the trigger valve above the trigger(valve # tva6). Replace as needed. To check for proper gun action, remove the nails, remove the 3mm roll pin holding trigger and dry fire the gun by depressing the tigger pin. Good luck
Sep 21, 2011 | Stanley Bostitch Coil Framing Nailer
The framing nailer blows air out the exhaust,and will not fire a nail when I pull tre trigger
take of clylinder head when off there is a large button make sure its fre should work like a door bell switch grease slightly and put together again
Aug 28, 2011 | Stanley Bostitch Coil Framing Nailer
The framing nailer first started not firing all the time and when it did - the nail didn't go all the way in. Now - even though we installed a new cell and fully charged battery - i does nothing. ...
ive found that sometimes where the batt is inserted into the gun theres two contacts down there wit a rubber pads the contacts rest against. check and see with a flash lite if one of the rubber pads has pulled away and wraped itself around the contact, if so pull it out with needle nose pliers or what ever works.if not the problem make sure your batt is good some will read 6 volts but will have no or week current. worst case repAIR SHOP.
Jul 05, 2011 | RTO PasLode 900420 Impulse Framing Nailer
I changed the feeder springs in my hitachi NV83 a2 and it wants to double fire and jaming up the driver with seconded nail. it was skip nailing before i changed springs. any help you could give me would be...
Your nailer is a very heavy duty nailer with very powerful blow. Works best with full size nails, not 2 inch range that are used in fencing, they are not spaced correctly for your gun (like hitting number 6 nail with sledge hammer). Open side door and remove the nails, leave the door open and dry fire gun against piece of rubber or old coiled air hose. The driver should return all the way up between shots and the feeder should move back then forward just as fast as the driver moves. If the feeder seems to move in slower motion then pull feed piston and replace orings and remove debris from feed cylinder. If the driver seems to stick out further than normal then lower bumper could be breaking up causing debris to enter feeder. Make sure that the driver is not bent and has a squared bottom, if rounded, remove and grind square. Finally adjust the depth control up or down slightly and bump fire for test, do not place gun on the work then fire. good luck
Jun 16, 2011 | Nailers Hitachi Nv83a2 3 14" Coil Framing...
Paslode framing nailer will onley fire one time and wont return to fireing pos. fires first nail great . started this problem after cleaning
Did you remember to lube the upper cylinder, lg 0-ring and silicone the striking pin----sticking may prevent returning to firing position
Mar 05, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Firing Pin doesn't return
The piston is returned to its firing position by air from the trigger valve after the piston has fired. It relys on the piston sealing against the bumper at the bottom of its stroke, if the bumper was damaged when the driver shattered or it was put in upside down the piston will not return. Also the piston uses air fed into the return chamber from the little holes in the cylinder, if the seal over these holes is damaged the piston may not return. Basically change the bumper and the check seal on the cylinder.
Jul 28, 2009 | Stanley Bostitch Coil Framing Nailer
N80CB - Coil Framing Nailer firing plunger stuck
There is a number of reasons that this will happen. Is the driver (plunger) physically stuck? Take a small screw driver and see if it can manually be pushed back. It may also be a broken head valve spring, or a stuck head valve (you have to remove the rear cap to get to these parts) Maybe this unit just needs an O-ring kit. Try these things and let me know
Apr 02, 2009 | Stanley Bostitch N80CB Coil Framing Nailer
Stanley bostitch coil nailer gun
check the safty shaft and see if something could be under trigger safty causeing it to fire.
Jan 05, 2009 | Stanley Bostitch Coil Framing Nailer
Porter Cable FR350A Factory Reconditioned 3 1/2" Round Head Framing Nailer Kit, 70 120 Psi Logo
27 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
T bone 1963
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
