HOW DO I HOOK UP pioneer CX-700 amplifier TO MY TV
TRYING TO ADD 80 WATT EXTERNAL SPEAKERS
marsrover
  • 682 Answers
SOURCE: hook up pioneer stereo amplifier model SA-1270
for audio system always you have left and right channels.
get the output (left&right) from tuner---go to equalizer input left&right.---from equalizer output go to amplifier inputs.and certainly from amplifier output to speaker.
Posted on Mar 11, 2008
  • 151 Answers
SOURCE: Zone 2 connections
go into your amp settings menu then to speaker settings,set zone 2 on and main on, turn up the volume for zone 2 about half way then connect phono cables from zone 2 pre out to a input on the external amp (eg cd input )
never use the phono input this is for turntables,connect this amp to your speaker switch/selector then to speakers.
hope this helps
cable guy.
Posted on Jun 04, 2008
  • 124 Answers
SOURCE: need to turn external speakers on (ilo tv)
What is the model of the DVD player and the Television.
Posted on Nov 12, 2008
  • 54 Answers
SOURCE: Hooking up external speaskers to my Panasonic TV
you will need to buy a surround sound receiver. the new tv's do not have an external speaker jacks on them. you might also try a old stereo receiver hooked up to the tv's audio out jacks
Posted on Jan 24, 2009
SOURCE: How do I hokk up external speakers to the Sharp
I want to hook up external speakers to my new lcd hdtv Sharp and control the audio with my remote.
Posted on May 16, 2009
500 watt tower spkrs unable to hook up to tvhoo
If the speakers are powered with their own amplifier, then connecting them to the audio out terminals on the TV will work. If the speakers have no amplifier, then they will never work on your TV. You must go to the audio setup on the TV to redirect the sound to the external jacks.
Dec 12, 2016 | Televison & Video
I have a Boss 4x50watt in-dash stereo, 2 Pioneer 270-watt max/ 40 watt nominal rear speakers, and 2 Pioneer 500 watt peak/ 80 watt rms front speakers. Do I need to buy an amplifier? Or is does the head...
You do not need to buy an amp, the only reason to buy one is if you do not think it is loud enough when you turn up the volume to max. The speakers you have can take more power than your stereo can provide, but you only need to add an amp to get more power if you want it to play louder than it does now.
Dec 19, 2013 | BOSS AUDIO SYSTEMS Car Audio & Video
Can't find an rca audio out on my hitachi hitachi cmp4121hdu. Is there one? or is it just the wired speaker inputs?
Hi I hope this answers your questions today. Your tv does not offer rca audio out, and the built in speakers are the only available that way.
That being said, I suppose you could disconnect the wires from the speakers and feed them out the edge of the cabinet, you would judt have to cut out a spot big enough for the wires to come out.
The TV has an 8 watt stereo amplifier, so I guess as long as you don't expect to be blasting the windows out, you could attach them to external speakers, or even an amplifier, if it allows speaker in, some do.
If you do hook it up to external speakers, just remember that the TV doesn't have a high-watt amplifier, though I suppose you could get an adapter. Speaker levels input and line-level outputs. This would provide you with the rca jacks that you are seeking.
Jan 28, 2011 | Hitachi CMP4121HDU 42 in. Plasma...
This isn't much of a problem as it is a qestion. Is there a was I can hook up my Pioneer car sprekers to a TV or an electric piano? If there is, can you describe materials I need and what I would need to...
You'd have to know what impedance the TV amp is (probably 8 or 16 ohms). Then you would have to match the impedance of the car speakers to that impedance. Tthe car speakers are likely 4 ohms, in which case you'd have to series 2 of them together (or 4 if the TV amp is 16 ohms) for each channel of the TV amp. You'd probably also prefer to mount them in an enclosure, since the power output on the TV is probably really low.
This assumes you're not trying to add a power source of some sort, but are intending to power the speakers off of the TV or piano.
Speaker wire/stripper, **** connectors, spade connectors to fit speaker terminals, crimper.
Nov 08, 2010 | Pioneer TS-W307D2 12" 1200 Watt Champion...
How much is the watt power for two speakers i need
add watt power for two speakers together(100 watt as example)your amp power must be (120 watt)at least.
Dec 15, 2009 | Pioneer A509R Amplifier
How do i hook external speakers to sony bravia television
The proper way to do this would be to use the audio output from the TV, either analogue left and right or the optical port, and send it into an dedicated amplifier or AV receiver. You can then use the amplifier or receiver to power the external speakers. If you are using a dedicated amplifier with no volume control you will want to change the audio output setting on the TV to "variable out" as oppose to its current "fixed out"settings. You can find this in the TV menu, usually under the audio settings. This will allow you to use the current TV remote to adjust the audio volume coming out of the external speakers.
Aug 21, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Where can I get wiring diagram?
www.pyleaudio.com/manuals/PLMRA220-420.pdf
Jul 22, 2009 | Pyle - plmra220 - Marine 600 Watt 2...
No Audio when disconnect from external amp and hook to speakers
In a radio like your Pioneer and all similar units there are always a pre-amp circuit that feeds a power amp circuit,In some players there are more than one pre-amp circiuts. It is possible and highly probable that the power amp circuit in your Pioneer is shorted, so you still get some audio output , but very little. I believe this is your problem and I suggest that you bring it to a repair shop for an estimate or replace the unit. Good luck and please rate this answer, Thanks.
Apr 12, 2009 | Pioneer Car Audio & Video
JVC TH-M45
no, u cant use the speakers with other normal DVD player because it wont have amplification for the speakers... u can use the sub to other dvd player because its inbuilt 120 watt woofer. ur dvd player is 5-disc player as wel as 120 X 2 and 80 X 3 watts amplifier (AV receiver ).... so just the JVC better sound thru the sub and speakers... ENJOY
kanny_amancha@yahoo.com
www.kanny-sounds.blogspot.com
Jan 24, 2009 | Pioneer 1000 Watt 5.1 Surround Sound...
Rca jacks for external speakers have no output
rca jacks are a low level output. you have to use an amplifier with rca's. you cannoy hook rca's directly to speakers.
Jan 19, 2009 | Pioneer DEH-P3900MP CD Player
 Grubhead
Grubhead
