Samsung model s42axyb09
The audio automatically turns all the way up or all the way down, volume icon stays on, and the sound can not be changed using the buttons on the tv or remote. What can I do to fix it?
SOURCE: direct tv remote control - tv volume
PaulTulsa is actually incorrect, Directv remotes do allow this function. I had this problem too... but was able to fix it. You have to go back into the system settings menu. Depending on your receiver (I have the hr21-100) press "Menu" then scroll to "Parental, Fav's & Setup" then "Sytem Setup" then "Remote" then select "Program Remote". Scroll to "TV" then select the brand name (I also have a Samsun tv). Follow the directions to change the code of the remote and manually go through the codes they have posted. The second one worked for me. Good luck.
Posted on Jul 29, 2008
SOURCE: direct tv remote- volume control
Here is how you fix it:
http://www.dbstalk.com/showthread.php?t=116241&highlight=SAMSUNG+REMOTE
Posted on Aug 27, 2008
SOURCE: STR-DE445 Works, but goes into protect when you turn up/down volume
This is a piece of **** unit. Mine only works on the left side, sometimes. When those times are I have NO idea. It doesn't seem to play 5.1 correctly and it goes into speaker protect mode for NO reason. It is TRUE lemon !!! ..let me know if you have any other problems with this JUNK .....schafe1001@aol.com
Posted on Aug 28, 2008
  • 336 Answers
SOURCE: Volume Knob does not adjust volume, but remote does.
Check your owners manual for "factory reset" this will reset the main micro-processor. Otherwise the encoder (volume pot) needs cleaning, soldering or replacement. It could also be a cracked circuit board (if it has recently been hit)
Posted on Jan 29, 2009
  • 6 Answers
SOURCE: unable to get ps3 to play when hooked to receiver
First of All, HDMI is a High Definition Multimedia Interface and will transmit both Audio and Video at the same time all in one cable. Try using the HDMI cable to your Gaming INPUT on the receiver, or HDMI 1 setting.
Are you running a Bose Lifestyle system too? Or are you using Bose speakers only?
Posted on Feb 17, 2009
Turned volume to max no ringtone sound will notify me of text or calls how to fix
depending on which phone you have you might have to assign a ringtone ? click on the phone icon,click on menu button,select ring tone ( you can have a different ringtone for each person if you want ) also when volume is tuned up you will notice on some phones theres a cog icon at the end of the slider ? click on that as other volume options will show ( they could be turned down ) sometimes our volume will stay down if you have had your phone on silent and switched back...or if we plug head phones in the volume turns down automatically.try scroll silent on /off or plug head phones in and out
Apr 26, 2015 | Cell Phones
Why won;t my volume shadow copy stay on or work?
VOLUME SHADOW COPY and sound functions have nothing in common other than both exist on a computer.
for volume icon, rt clk system tray expand button and select properties. Then turn volume on.
Sep 01, 2014 | Dell Latitude D610 P4 1.6 GHz CDRW/DVD...
Samsung le40b530
Chances are that one of the volume buttons (either on the TV itself or on the remote) is stuck. You'll be able to know if it's the remote by taking out its batteries and trying the same process. If the issue persists, see if the volume down button on the TV is stuck and can be freed.
Dec 18, 2013 | RCA Audio Players & Recorders
Volume icon missing
Which operating system ??
In Windows and on a Mac, you can use an icon shaped like an audio speaker to adjust the computer's volume or mute the sound output completely.
Whichever operating system you are running, it is possible to remove the volume icon from the screen.
If you have removed the volume icon accidentally, you may not have a convenient way to adjust your computer's sound volume.
Restore the sound icon to resume using it to adjust the volume or mute your computer's sound output.
Click the "System Preferences" icon on the dock.
If you have removed this icon from the dock, click the Apple icon at the top of the screen, then click "System Preferences."
Click the "Sound" icon in the "System Preferences" window.
Place a check in the box at the bottom of the window labeled "Show volume in menu bar."
The sound icon appears at the top of the screen.
Close the window to resume using your computer.
Restoring the sound icon in Windows 7
Click the Windows Orb (Start button), then click "Control Panel."
Click "Taskbar and Start Menu."
If you do not see this icon, click the "View by:" drop-down menu at the top of the window and select "Small icons."
Click the "Taskbar" tab, then click the "Customize" button.
Click the drop-down menu next to "Volume" and select "Show icon and notifications."
Click "OK" twice and close the Control Panel.
Restoring the sound icon in Windows Vista
Double-click "Taskbar and Start Menu."
If you do not see this icon, click the "Classic View" link.
Select the "Notification Area" tab. Place a check in the box labeled "Volume."
Click "OK" and close the Control Panel.
Restoring the sound icon in Windows XP
Click the "Start" button, then click "Control Panel."
Double-click the "Sounds and Audio Devices" icon, or click "Sounds, Speech and Audio Devices," then click "Sounds and Audio Devices."
Place a check in the box labeled "Place volume icon in the taskbar."
Restoring the sound icon in Windows 2000
Click the "Start" button, then click "Settings" and "Control Panel."
Double-click "Sounds and Multimedia."
Place a check in the box labeled "Show volume control on the taskbar."
Restoring the sound icon in Windows Millennium Edition (ME)
If you do not see this icon, click the "View All Control Panel Options" link.
Restoring the sound icon in Windows 98
Double-click "Multimedia."
Click the "Audio" tab.
Dec 04, 2013 | Computers & Internet
SAMSUNG N150-i have check sound/audio devices in the control panel and made sure volume is set right..selection...problems with volume...icon showing 100% but still no sound,help please!
If your computer came with a motherboard disc the sound drivers could be on it
Click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers. Click start control panel sounds and audio volume advanced speakers make sure you have selected the (appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings.
Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it.
If his does not fix the problem Click start control panel sounds and audio devices you can adjust the volume there also select speaker volume. You can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the speaker volume icon system select adjust volume Click start control panel sounds and audio volume advanced speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand system speaker right click properties then select use this device (enable) also you might check the speaker plug/outlets they are usually at the side of the laptop.
You will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity Clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit.
dust causes static to build up in a computer http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for IE: motherboard name audio driver you might have to try a few times to get it right for windows 7 Click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to update drivers Click start right click on computer select properties then device manager scroll to sound and video if you right click on sound and video then on high definition audio device select update driver software Click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers. Right click on the speaker icon in the bottom taskbar you will see an array of options select playback devices make sure it has a green tick and the correct speakers are selected be updated. If you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers Click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker You might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply
Feb 18, 2013 | Samsung N150 (36725723009) Netbook
How do i turn my keypad sound off on my corby pro without turning off my ringer
Go to settings-> phone profiles and tap on the [>>] icon next to the profile for which you want to make keypad silent (for eg:- normal). from the drop down menu at top right, select phone sounds. Scroll down till you see 'phone sound volume'. Reduce it to zero. Done!!
Apr 17, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
Can't change from MONO to AUTO mode
Hello
Can't make sound from mono to auto is your problem I thinks and posts this solution.
Hit the "Menu" button and surf through, come to "Sound Adjust" window.
The settings allow you to change and adjust sound in your TV. There are Bass, Treble and Balance control to adjust to your individual taste.
To adjust them
1. Press Menu button.
2. Press UP or DOWN button to select the desired item.
3. Press => or 4. Press EXIT button when finished.
When adjusting the parameter of "Balance" control, always set it to mid position to get stereo sound from both speakers. If it is set to any extreme end, there will be no output from the speaker of that side, and will hear as mono.
If you press "0" [Zero] button, you can reset the sound settings to it Factory settings.
To select 'Streo mode;
1. Press "Menu" button.
2. Press UP or DOWN button to select MTS [Multi-channel Telivision Sound].
3. Press => or [The ON AIR arrowtells you if a broadcast is in stereo AND/OR contains the SAP.
Press "Exit" button when finished.
Keep the TV in stereo mode to get the best sound quality. The sound will work in stereo
mode even if a certain broadcast is in mono sound only.
Choose the mono setting to reduce excessive noise on a certain channel or broadcast.
Selecting SAP will allow you to hear an alternative soundtrack, if one is available.
Apr 01, 2011 | JVC AV32F476 32" TV
I want to have a media player on my computer but my is problem my sounds and audio devices is activated. what should i do?
if you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps don
Mar 11, 2011 | Computers & Internet
What's wrong with my acer 4741? the sound is very low. I have adjust the sound level to the highest level. but it still doesn't work. please give me the suggestion
INSTRUCTIONAL STEPS
  • Click the "Start" button on your screen, then click on the "Control Panel." Double click on the "Sound and Audio" icon.
  • Click the "Place Volume Icon in the Taskbar" option to have it in the lower right corner. Click "OK" to save your settings.
  • Check your volume icon to make sure it does not have a red-and-white mute button around it.
  • Move the mouse click to the volume icon, then right click the mouse. Click on the "Open Volume Control" option on the pop-up menu. Remove the check on the mute button under the master control, if it is checked.
  • Move the volume slider in the master category upward. If you begin to hear sound, then the problem has been resolved.
  • Click the "Start" button on your screen, then click the "Run" option to check your Windows audio service. In the run window, type "services.msc" then click "OK."
  • Scroll down the list in the services window, then right click the "Windows audio option." Click on "Properties."
  • Select the "Automatic" option under the "Startup" tab, then click "OK." Test the sound. Try using headphones into the phone jack to test the sound
  • Click the "Start" button, then select the "control Panel" to check sound drives. Double click on "Sound and Audio" devices, then click the "Audio" tab.
  • Check the correct sound default device on your laptop under the "Sound Playback" option. If you installed other volume drivers on the laptop and you don't know the correct default, consult your user manual or contact the manufacturer.
  • Click the "OK" button ,i hope you"ll find this helpful,remember to leave your by saying how helpful this post is
  • Oct 07, 2010 | Computers & Internet
     Grubhead
    Grubhead
