Question about Kenwood Kpg-25d V3.02 Software For Tk-940, Tk-941, Tk-840, Tk-841
Cant get cumputer to reed disk - Kenwood Kpg-25d V3.02 Software For Tk-940, Tk-941, Tk-840, Tk-841
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 116 Answers
Download the software from internet and then read you radio by connecting with programming cable.
Posted on Jul 11, 2016
Lights
Check this and adjust it:
If the console takesbatteries, replace them. If this does not work or your console does not requirebatteries, check the reed switch or optic sensor. Reed Switch:Unplug the treadmill and remove the motor hood cover. The reed switch is mountedon the frame next to the front roller pulley. There is a magnet glued into thefront roller pulley. When adjusting the reed switch, make sure it is pointingdirectly at the magnet. Move the tip of the reed switch within 1/8" of themagnet. Also, check to see that the wire is not damaged, and is connected tothe console.
clip_image001.gifOptic Sensor: Unplug the treadmill and remove the motor hood cover. The optic diskand sensor are located either at the end of the motor or the right hand side ofthe front roller. The optic disk spins between two sensors on the optic switch.The disk must spin freely without touching either sensor. The sensors can bemoved by loosening the adjustment bolt holding the switch to its bracket. Theswitch can then be slid. Center the disk.
11_29_2011_3_44_52_pm.gif11_29_2011_3_45_23_pm.gifGood luck. sincerely
E.CUADRA
Nov 29, 2011 | Epic View 550 Treadmill
Power is going into machine but console does not light up and work
If the console takesbatteries, replace them. If this does not work or your console does not requirebatteries, check the reed switch or optic sensor. Reed Switch:Unplug the treadmill and remove the motor hood cover. The reed switch is mountedon the frame next to the front roller pulley. There is a magnet glued into thefront roller pulley. When adjusting the reed switch, make sure it is pointingdirectly at the magnet. Move the tip of the reed switch within 1/8" of themagnet. Also, check to see that the wire is not damaged, and is connected tothe console. clip_image001.gifOptic Sensor: Unplug the treadmill and remove the motor hood cover. The optic diskand sensor are located either at the end of the motor or the right hand side ofthe front roller. The optic disk spins between two sensors on the optic switch.The disk must spin freely without touching either sensor. The sensors can bemoved by loosening the adjustment bolt holding the switch to its bracket. Theswitch can then be slid. Center the disk. 11_18_2011_6_53_40_pm.gif11_18_2011_6_54_25_pm.gif
Nov 18, 2011 | Exercise & Fitness
Light blinking, not working
If the console takes batteries, replace them. If this does not work or your console does not require batteries, check the reed switch or optic sensor. Reed Switch: Unplug the treadmill and remove the motor hood cover. The reed switch is mounted on the frame next to the front roller pulley. There is a magnet glued into the front roller pulley. When adjusting the reed switch, make sure it is pointing directly at the magnet. Move the tip of the reed switch within 1/8" of the magnet. Also, check to see that the wire is not damaged, and is connected to the console.
Optic Sensor: Unplug the treadmill and remove the motor hood cover. The optic disk and sensor are located either at the end of the motor or the right hand side of the front roller. The optic disk spins between two sensors on the optic switch. The disk must spin freely without touching either sensor. The sensors can be moved by loosening the adjustment bolt holding the switch to its bracket. The switch can then be slid. Center the disk. 11_15_2011_12_05_38_am.gif11_15_2011_12_06_02_am.gif
Nov 14, 2011 | Exercise & Fitness
Motor runs but nothing turns on
Optic Sensor: Unplug the treadmill and remove the motor hood cover. The optic disk and sensor are located either at the end of the motor or the right hand side of the front roller. The optic disk spins between two sensors on the optic switch. The disk must spin freely without touching either sensor. The sensors can be moved by loosening the adjustment bolt holding the switch to its bracket. The switch can then be slid. Center the disk. 11_13_2011_11_53_47_am.gif11_13_2011_11_54_16_am.gif
Nov 12, 2011 | Epic 425 Mx Treadmill EPTL88105 !
Belt and incline wont move.
Optic Sensor: Unplug the treadmill and remove the motor hood cover. The optic disk and sensor are located either at the end of the motor or the right hand side of the front roller. The optic disk spins between two sensors on the optic switch. The disk must spin freely without touching either sensor. The sensors can be moved by loosening the adjustment bolt holding the switch to its bracket. The switch can then be slid. Center the disk. 11_16_2011_4_32_00_pm.gif11_16_2011_4_32_24_pm.gif
Oct 29, 2011 | Epic View 550 Treadmill
I have a Life Fitness 9100, and the display is dead, it worked fine the last time it was used two weeks ago. Thanks!
Adjust and clean very softly.
Oct 22, 2011 | Life Fitness 9100 Next Generation...
Screen is blank
Optic Sensor: Unplug the treadmill and remove the motor hood cover. The optic disk and sensor are located either at the end of the motor or the right hand side of the front roller. The optic disk spins between two sensors on the optic switch. The disk must spin freely without touching either sensor. The sensors can be moved by loosening the adjustment bolt holding the switch to its bracket. The switch can then be slid. Center the disk. 11_14_2011_4_33_45_pm.gif11_14_2011_4_34_07_pm.gif
Nov 14, 2010 | Proform 380 CS Treadmill !
I have windows millenium on my cumputer and want to upgrade to xp but it asks me for a 15 digit product key that I dont know because i brought the cumputer at a tagsale for 200.00
The 15 digit key is the one on the original packin the WinXP disk came in. It looks like a Microsoft sticker with alpha numeric code on it.
Aug 18, 2008 | Computers & Internet
Labtec webcam
right lve put in the diss in my cumputer and it is not woking in my hp cumputer and Ive got web cram allso
Apr 12, 2008 | Labtec 961307-0914 Webcam
Kenwood Kpg-25d V3.02 Software For Tk-940, Tk-941, Tk-840, Tk-841 Logo
59 people viewed this question
Top Kenwood Radio Communications Experts
eradiostore
eradiostore
michael galang
Jason
Are you a Kenwood Radio Communication Expert? Answer questions, earn points and help others
