Question about Jabra GN9125 Wireless Headset
Onlin indicator light will not go on with jabra gn9120
Will these headsets work with a VOIP phone system as we are moving from ISDN to VOIP
neil look at the manual and check the voip phone model number against the most common phone types it works with
https://www.jabra.com/~/media/Product%20Documentation/Jabra%20GN9120%20Series/User%20Manuals/User_Manual_Jabra_GN9120-GN9125_EN.pdf
ISDN is a digital system are you using the old phones on the voip or having to install different phones ?
Nov 30, 2015 | Jabra GN9120 Wireless Headset
Jabra gn9120
Make sure ringer is turned on and the volume turned up on phone
Sep 02, 2014 | Radio Communications
Jabra wave battery suddenly won't charge
The battery may be shot and incapable of charging. The red light could be merely indicating that the charger is working.
Jan 13, 2014 | Jabra Wave Bluetooth Headset
I have it pair to my I phone ----but I lost my manual what are the buttons for?
Follow the instructions mentioned below to resolve the issue:
  • Charge the headset
  • Charge your Jabra VBT185Z until the solid LED turns off
  • (approximately 2 hours)
  • Turning the headset On and Off
  • Press the answer/end button until you see a burst of flashes on the
  • indicator light (LED) to turn your headset on or off.
Headset Pairing Readiness Instructions:
1. Fully charge headset for two hours.
2. The headset will automatically go into pairing mode if no device has
been previously paired.
3. Set your mobile phone to 'discover Jabra VBT185Z'.
4. Enter passkey or PIN = 0000 (4 zeros), then press Yes or OK.
For online pairing assistance visit www.verizonwireless.com/bluetooth.
Hope the above steps allows you to resolve the issue. Please revert back for any further clarification.
Regards
Anand
May 10, 2011 | Jabra VBT185Z Bluetooth Headset
Hello my jabra wont light up when it is fullcharge? can you help me?
The headset light turns off when it is at full charge. If it is not charged yet it will be illuminated red.
Found this in the online manual:
http://img5.jabra.com/sites/Jabra/GNimages/Products/Stone_Manual_EN_NA_8404.pdf
Feb 28, 2011 | Jabra Stone Bluetooth Headset
My GN9120 does not connect ...
I solved this over the weekend: I found out, that the GN9120 comes with slightly differing battery sizes. I had to push the contacts deeper inside the housing so they got in touch with the new battery again. I used a very small flat screwdriver to achieve that. You have to be careful not to destroy anything surrounding.
This was an easy solution to a stuoid problem, but the contacts are barely visible in the inside of the GN9120 so i needs to have the idea to search for that as the source of trouble,
Jan 16, 2009 | Jabra GN 9120 Midi-boom Microphone-Headset...
Jabra bt2020 will not charge/function
I don't know how long you have had the headset but it sounds like it isn't holding a charge.  Contact Jabra to find out what the warranty is on the headset.
Nov 12, 2008 | Jabra BT2020 Bluetooth Headset
Jabra GN9125 Wireless Headset Logo
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
