Question about Yahoo Mail
I can't get my at&t mail from my laptop
At home I use my laptop and a wireless - peer to peer connection with my fathers computer which is connected through a wired High speed connection. I get connected, and can access my secondlife game, but can not pull up my home page at AT&AT?
  • Narayanan Srinivasan May 11, 2010
    There's one possible explanation I can think of. Am assuming that
    you're not able to check webmail (through browser). If it's through
    outlook or thunderbird, it's an easier problem.
    Technically, http uses the port 80 and Secondlife being a game makes
    use of ports other than port 80. Can you please comment on whether you
    can access other websites? If you can't I'll have to guide you on how
    to forward ports.
    To sum it up. There's a chance that some of your ports are blocked.
    President:
  • 392 Answers
Check whether which connection is activated..i think the wireless connection is wrongly setup .. if u disconnect from your fathers computer ur internet will work ... so to overcome this problem.. go to internet options in your browser and go to connections--> advanced LAN settings..in that mention which network adapter is used for internet .. then the problem will be solved
Posted on Jun 20, 2009
Tip
How does Wireless Network work?
A wireless network is simply two or more computers linked together by invisible radio waves with the purpose of transferring data or sharing resources. The configuration is similar to cordless phones in that they can share one telephone line, which utilizes one central "base" station along with multiple handsets placed throughout the house. Wireless networking is an excellent solution because you don't have to deal with cables and it takes little effort to expand.
There are two kinds of wireless networks:
Ad-hoc mode: Each computer in the network with a wireless adapter can communicate directly with each other without the use of a router or access point. You can share files and printers with this method. However, it is more difficult to connect to networks - both wired and wireless. This mode is also known as peer-to-peer networking.
Infrastructure mode: Each computer in the network uses a router or access point to handle all data transfer and network traffic. You can easily access a wired network, whether it is a LAN or the Internet. For most home networking purposes, infrastructure mode is the best choice.
Wireless Standards
Wireless-B (802.11b) - Operates on the 2.4GHz frequency band and can transmit data at speeds of up to 11Mbps within a range of up to 100-150 feet. Wireless range can be affected by reflective or signal-blocking obstacles, such as mirrors, walls, devices and location, whether indoors or outdoors.
Wireless-A (802.11a) - Operates at the frequency of 5GHz, which is less crowded than 2.4GHz where telephones and microwaves may cause interference. Although the speed is up to 54Mbps, the range is only up to 75 feet. Wireless-A is incompatible with both Wireless-B and G because it operates at a different frequency.
Wireless-A+G (802.11a + g) - Linksys also offers dual-band products, in which routers and adapters are compatible with both 2.4GHz and 5GHz frequencies. Both radio bands work simultaneously, blanketing your wireless zone and bandwidth.
Wireless-G (802.11g) - Features the same benefits as Wireless-B, but offers 5X the speed at up to 54Mbps. Wireless-G currently offers the best combination of performance and value. You can mix Wireless-B with Wireless-G equipment, but you will lose the higher performance speeds of Wireless-G.
The chart below outlines the differences and features for each wireless standard, along with the activities that are best suited for each one.
Network Hardware
Once you've chosen the type of network (wired or wireless) for your home, here is the basic network hardware that you'll need:
Router: This is considered the heart of your network and is the device that routes all the traffic to and from the Internet to the various computers on your network. It lets you share files and printers, and provides a basic layer of security from Internet threats.
High-speed Internet Connection (either DSL or cable): You can purchase High-speed Internet service from your local telephone (for DSL) or cable company. Both types of connections are considerably faster than dial-up access. High-speed Internet is also commonly referred to as broadband.
Modem: Connects your Internet service to your computer so you can surf the Internet and access your e-mail. Depending upon what type of broadband service you have, you must purchase or rent either a DSL or cable modem. Or, you can purchase a modem from your local electronics retailer or e-retail store. Linksys offers a gateway router which is an all-in-one solution that combines the functions of a router with a cable or DSL modem so that two separate devices are not required.
Network Adapter: Allows your computers to connect to the network. If you already have a wireless or network adapter pre-installed in your computer, you may not need to purchase one. There are different types of adapters available, depending on if you have a desktop or laptop computer.
For a Desktop Computer:
  1. A PCI Adapter - connects inside your computer, requiring you to remove the outside case.
  2. A USB Adapter - does not require you to remove the outside case since it simply plugs into a USB port on the outside of your computer.
For a Laptop Computer:
  1. A PC (PCMCIA) Card - about the size of a credit card and simply slides into a slot on your laptop computer. This type of card is recommended when using a wireless network setup since you can walk around without having to juggle an external adapter.
  2. A USB Adapter - simply plugs into a USB port on the outside of your laptop computer.
How Routers Work ?
The Router is the central component in connecting all of your computers and network devices together, allowing them to access and share one high-speed Internet connection. It organizes all of the devices in the home network so that they can communicate with each other and share information. A Router combines the functions of a switch, which organizes and controls data flow among your computers and network devices. A switch is best for wired networks that want to share files and printers, but does not provide Internet access capability.
A Router joins two networks, your home network and the Internet, passing information from one to the other. It also determines how the information is passed in the most efficient manner. The router's two main jobs are:
  • To make sure that information doesn't travel where it's not needed.
  • To make sure that information travels to its intended destination.
da2f5a9.jpgThe Router also provides security measures to your network which prevent outside users from accessing your private data. This is important because a high-speed Internet connection is always on, which makes it more vulnerable to attacks from hackers. You may already have a basic software firewall installed on your computer, but the network can still be easily broken into.
on May 28, 2010 | Computers & Internet
No puedo intalarlo
The Zero Configuration Utility built into Windows XP may vary depending on if you have installed Service Pack 1 or not.
Download Service Pack 1 here.
Without Service Pack 1
Step 1 Right-click on the two computer monitor icons in the system tray and select View Available Wireless Networks.
Step 2 Highlight your wireless network which is the SSID of your wireless network (if you are connecting to a D-Link router or access point it will be default) and click Connect.
Step 3 If you do not see your wireless network in the available networks box click on the Advanced button. Select Add and type in the SSID of your router or access point, uncheck this computer is connected in and ad-hoc peer-to-peer network, and then click OK.
With Service Pack 1
Please read here regarding Service Pack 1 and disabling the SSID Broadcast.
Step 2 Uncheck the Allow me to connect to this wireless network even though it is not secure box. Highlight your wireless network (if you are connecting to a D-Link router or access point it will be default), and click Connect.
How Do I enable Encryption using the Zero Configuration wireless utility?
Jan 18, 2011 | D-Link AirPlus Xtreme G DWL-2000AP...
Can I connect a wireless capable printer to my wifi laptop without a router? If so how? Not having much luck on my own. Thanks for any help you can give me.
You can create what is called a 'peer to peer' network. You will have to be disconnected from the internet for this to work and it has limited distance as your PC acts like a router. It would be much much easier to plug it in with a USB cable.
However if you wish to achieve this then depending on your operating system, set up a home or small office network, select that it is not going to be connected to the internet and select the 'peer to peer' option. Name it something you will remember, then go to your HP printer and select the wireless access point that you just created on your laptop. You should now be able to use it within a limited range.
Another option is to get a 'mini router' which plugs directly into your printer and broadcasts a signal which your laptop can pick up, it has a much greater range, but will obviously cost you money.
Hope this helps
Jan 06, 2011 | HP Computers & Internet
Software to restric internet access
You can use a Bandwidth limiting software on the appropriate laptop that can set an Upload and Download speed limit on any Internet accessing software: it is a fair-priced commercial s/w called 'Netlimiter' and you can download the 'PRO' version on a 28-Days evaluation from: http://www.netlimiter.com/download.php
Very handy to limit each application bandwidth especially Data transfer from your Laptop when using a browser (such as IE/Firefox/Chrome) at the same time as a Peer to Peer application (such as Azarus/Edonkey/EMule).
Dec 20, 2009 | Computers & Internet
Wireless networks not found
Sometimes Satellites get a little flaky when on battery power. If you haven't already, plug in the power cord with the notebook cold - meaning off for about a minute. Boot the notebook and try to do the setup with the power connected. If that solves it, it should work fine when you switch to battery power. If it doesn't, repost with your results.
Jun 11, 2009 | Toshiba Satellite M65-S821 Notebook
Unable to activate wireless lan
TRY GOING TO START, START SEARCH TYPE WIRELSS DEVICE
LOOKE IN DEVICE MANAGE FOR WIRELESS FOLDER
INPUT DEVICES
AS SO CHECK THE FOLLOWING FOLDERS ALLOWING COMMUNICATION BETWEEN THE LABTOP AND THE WIRELESS DEVICE AND THE COMPUTER.
NETWORKING AND SHARING FOLDER
PROBLEMS AND REPORTING
SECURITY FOLDER
SYNC CENTER IF YOU HAVE ONE
WINDOWS DEFENDER
WINDOWS FIREWALL
THE LAST 2 PROGRAMS IN THE LIST ABOVE CAN STOP THE DEVICE FROM WORKING.
YOU WANT MORE HELP I WILL HELP YOU IF YOU HAVE THE SITE CONTACT RODGANDYSR@GMAIL
ROD
May 12, 2009 | IBM TP R51 - P M715 1.5GHZ 256MB 40GB...
Wireless connection problems
How bout setting ur mom's laptop to remove all wireless connection history and then try to make new connection to the router at her home. It also recommended to see from the router
administrative tool is your mom's laptop detected? no kind of blocklist applied in the router? Hope it helps :)
Dec 18, 2008 | D-Link DI 514 Wireless Router (DI-514)
Sharp Copy Machine
You don't say if you are using a server/client network or a peer-to-peer. Go to START >printers and Faxes >Add a printer >Next and select A Network printer select Connect to the printer and then enter the path to the printer eg \\server\printer name
Oct 01, 2007 | Computers & Internet
Yahoo Mail Logo
114 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
Sunday Ojelabi
Sunday Ojelabi
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
