Question about Sparco Tabletop Folding Machine, Letter Size, 14-1/4 x 6 x 14 Inches,
It only folds one at a time - Sparco Tabletop Folding Machine, Letter Size, 14-1/4 x 6 x 14 Inches,
07 corvette top will retract but deck lid makes no effort to close, then top will not go back up. Need to release pressure in block lift top up about 1/4 of way then top will go back up
Manually Moving the Folding Top from the Down Position
Important: Allow the system a minimum of four minutes to bleed down pressure after the last cycle.
Manually release the folding top cover latch using the emergency release cable.
Raise the folding top stowage cover.
Manually raise the folding top, holding the 5 bow up.
Manually lower and latch the folding top stowage cover.
Manually unfold the top and latch per normal procedure.
Manually Moving the Folding Top from the Up Position
Manually release header latch per normal operation.
Manually lift front of roof off of the header and raise the #5 bow at the same time.
Manually release the Folding Top Cover latch using the emergency release cable.
Fold the roof down into the well.
Manually close and latch the folding top stowage cover.
Power Folding Top System Components
The power folding top system consists of the following components:
• Folding top control (FTC) module
• Body control module (BCM)
• Folding top control switch
• Serial data communication
• Folding top cover latch actuator
• Folding top cover pull down actuator
• Folding top pump motor with valve manifold
• Position switches and limit switches:
- Pin receiver switch
- Luggage barrier switch
- Folding top cover open switch
- Top open switch
- Top closed switch
- 5 bow raised switch
- 5 bow lowered switch
• Tonneau release relay
• TONNEAU PULL DOWN ACTUATOR Fuse 20 A
• TONNEAU RELEASE Fuse 10 A
• BATT 2 Fuse 40 A
• REAR FOG/ALDL TOP SW Fuse 10 A
• Folding top mechanical components:
- Folding top
- Folding top cover
- Folding top valve 1
- Folding top valve 2
- Folding top valve 3
- Hydraulic lines and cylinders
Folding Top Cover Latch Actuator
The power folding top system includes a folding top cover that is powered open and close by a hydraulic system that is controlled by the FTC module. A power unlatch motor is used to unlatch the folding top cover before the folding top control (FTC) module powers the top cover open. The folding top cover unlatching is requested by the FTC module via class 2 message, but is executed by the body control module (BCM). When requested, the BCM applies battery voltage through the folding top cover release relay control circuit to the tonneau release relay. The relay is energized and battery voltage is applied through the folding top cover release control circuit to the latch actuator. The actuator is energized and the latch releases the folding top cover.
The electronics on this are very complex ,
System Operation
Before any movement of the power folding top is allowed, the folding top control (FTC) module must be aware of the following conditions:
• Unlatch the header. The FTC module reads the pin receiver switch is Inactive.
• The windows must be normalized. Refer to Power Window Reinitialization.
• The ignition must be placed in Accessory or RUN.
• The transmission must be placed in PARK, or with manual transmission, the park brake must be applied.
• Trunk status must not be ajar.
• The luggage barrier must be in place.
• The pump motor temperature must be within the operating range.
After the last cycle of power folding top operation, allow the hydraulic system a minimum of 4 minutes to bleed down before attempting manual operation of the top.
Your best bet take and have it checked for DTC'S - diagnostic trouble codes .
DTC B3666 Rear Tonneau Position Error
DTC B3667 Tonneau Release Circuit
DTC B1011
DTC B1291
DTC B1420
DTC B3602
DTC B3666
DTC B3667
DTC B3670
DTC B3971
Jan 23, 2017 | 2007 Chevrolet Corvette Convertible
When opening the top, it all works until it is time for the truck to close and then it doesn't.
What make ,model an year vehicle ? Could be a sensor or a control module . Some of these convertibles are very complex , could set DTC'S diagnostic trouble codes .
The hydraulic lines and the cylinders
GMLAN communication to the Body Control Module (BCM)
Open/Close request circuit to the driver and passenger window motors
Power and Grounds
Folding Top Main Power Fuse 30A
Folding Top Logic Power Fuse 20A
Ground G301 for the FTC module and G305
Folding Top Open/Close Switch (S15 and S16)
Rear Compartment Limit Switches
Rear Compartment Lid Release Switch (S3 and S4)
Rear Compartment Lid Release Switch-Front Hinge-Left (S11 and S12)
Rear Compartment Lid Release Switch-Front Hinge-Right (S9 and S10)
Folding Top Front Location Pin Guide-Left (S17 and S18)
Rear Compartment Lid Release Switch-Left (S19A)
Rear Compartment Lid Release Switch-Right (S19B)
Rear Compartment Partition Position Switch (S20)
Folding Top Front Location Pin Position Switch (S13)
Folding Top Front Latch Actuator Position Switch (S14)
Hall Effect Sensors
Folding Top Header Latch Cylinder Sensor (S1)
Rear Compartment Cylinder Extended Sensor (S2)
DTC B367F 58: Roof Stowed Ready to Latch Sensor Circuit incorrect reaction after event
DTC B367F 59: Roof Stowed Ready to Latch Sensor Circuit circuit/component protection time out
DTC B367B 58: Deck Lid Anti-Rotation Latched Sensor Circuit incorrect reaction after event
DTC B367B 59: Deck Lid Anti-Rotation Latched Sensor Circuit circuit/component protection time out
Your best bet is probably to take your vehicle to a qualified repair shop.
May 23, 2016 | Cars & Trucks
How do you fold the back seats on a nissan tino 2001
You do it from behind. Pull the handles on the LEFT and RIGHT and push up
Apr 09, 2013 | 2001 Nissan Almera Tino
What is a tri-fold futon? I have only ever heard of a bi-fold.
A tri-fold futon folds three times (hence the name) instead of twice. Some models have legs, while other sit directly on the floor.
Aug 01, 2012 | Furniture
To remove 1993 mustang conv. top cylinders should top be up or down? thanks, bill
don't have 93. here's 94
Motor Assembly, Convertible Top Removal and Installation
NOTE: The folding top hydraulic cylinder rods should be in the fully retracted position.
Use absorbent rags or a container to catch any hydraulic fluid that leaks out when removing the fittings.
  1. Remove motor and pump assembly as outlined.
  1. Loosen each folding top motor upper and lower hose fitting on the sides of the folding top hydraulic lift motor and plate kit (533A00) .
  1. Remove the folding top hydraulic lift motor and plate kit .
  1. Remove each of the service folding top hydraulic lift motor and plate kit plugs one at a time and attach the tee fitting to the replacement folding top hydraulic lift motor and plate kit . NOTE: Make sure that the o-ring is installed in the bottom of each folding top hydraulic lift motor and plate kit port before attaching the hose tee fitting.
  1. Connect the folding top hydraulic lift motor and plate kit unit to a 12-volt power source and cycle the folding top hydraulic lift motor and plate kit in and out several times to purge the air from the folding top motor upper and lower hoses (53390) . Some noise squeal may be noticed due to the air. srb~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not overfill or the reservoir seal could be blown out.
  1. Carefully remove the rubber fill plug from the back and the reservoir and check the fluid level. The level should be at the bottom of the filler hole. If necessary, add Synthetic Mercon® Multi-Purpose Automatic transmission fluid E6AZ-19582-B (ESR-M2C163-A2) or equivalent.
  1. Replace the fill plug with a new fill plug.
  1. To install, reverse Removal procedure.
Section 01-17: Convertible 1994 Mustang. Workshop Manual
REMOVAL AND INSTALLATION Lift Cylinder, Power Top Removal and Installation
NOTE: The cylinder rods should be in the fully-retracted position.
  1. Remove pump and motor as outlined.
  1. Remove the upper and lower hose fitting from the folding top hydraulic cylinder (50600) . Use absorbent rags or a container to catch any hydraulic fluid that leaks out when removing the fittings.
  1. Remove each of the service cylinder plugs one at a time and attach the hose fittings. NOTE: Be sure each fitting is installed in the correct position on the folding top hydraulic cylinder .
    NOTE: Make sure that the tetra seal is installed in the bottom of each of the folding top hydraulic cylinder ports before attaching the upper and lower hose fittings.
  1. Connect the folding top hydraulic lift motor and plate kit (533A00) to a 12-volt power source and cycle the folding top hydraulic lift motor and plate kit in and out several times to purge the air from the hoses. Some noise squeal may be noticed due to the air.
Jan 21, 2011 | Ford Mustang Cars & Trucks
Cannot fold!! pulled up on arrows to disengage top half, but what now to fold the bottom half?
You need to push it together at the same time that you are pulling up on the unlock part. It took me a few weeks to really get it down. If possible, try using the rear end of your car as a stop for the front of the stroller. Disengage the locks at the handlebars and at the same time press your weight into the stroller against the car. I promise it'll get easier over time.
Apr 23, 2009 | Jane Powertwin Azulon Stroller
Paper folder grabs too many sheets and doesn't fold accurately
Not sure what make / model you have but folders are pretty much the same. The issue with the paper feed is your retarder, also known as the paper seperator. On the feed table where you load paper there should be a pad or rubber wheel. Look for an adjustment screw. You need to close the gap enough so that it only takes one sheet at a time. The extra fold sounds like you need to adjust the fold plate stop positions just a hair. If you give me the make and model I should be able to email you a manual.
Apr 10, 2009 | Office Equipment & Supplies
Konica minolta 600 has problem printing duplex mailmerge and tir
CAUSE: The tri-fold printed on side is set incorrectly on the machine.
SOLUTION: To change the tri-fold from printing inside fold to printing outside fold, perform the following:
1. Press the Utility key.
2. Select Admin mode and enter the password.
3. Press Copier Setting.
4. Press the down arrow.
5. Press Tri-Fold Printed on Side Selection.
6. Press either INSIDE or OUTSIDE.
good lock
Feb 28, 2009 | Panasonic DP-C264 Copier
Convertible top
here's some info
Symptom Chart Condition Possible Source Action
  • Folding Top Does Not Raise and/or Lower
  • Blown fuse(s).
  • Circuitry open/shorted.
  • Damaged folding top switch.
  • Damaged raise/lower relay .
  • Damaged folding top hydraulic lift motor and plate kit .
  • Parking brake not engaged.
  • Go to Pinpoint Test A.
  • Top Hesitates and/or Comes Up Uneven
  • Damaged folding top motor upper and lower hose .
  • Damaged folding top hydraulic cylinder .
  • Damaged folding top linkage.
  • Go to Pinpoint Test B.
  • Top Does Not Raise or Does Not Go All the Way Up
  • Go to Pinpoint Test C.
  • Hydraulic System
  • Damaged fluid reservoir.
  • Go to Pinpoint Test D.
Jan 04, 2009 | 1989 Ford Mustang
Sparco Tabletop Folding Machine, Letter Size, 14-1/4 x 6 x 14 Inches, Logo
458 people viewed this question
Top Sparco Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Sparco Office Equipment and Supply Expert? Answer questions, earn points and help others
