Question about Dometic Rooftop RV Air Conditioner
Dometic air sounds like its running when turnrd off
    Genius:
  • Dometic Master
  • 1,363 Answers
Relay might still have fan on.
Posted on Aug 16, 2015
Why does my dometic ac runs but no cold air?
If the compressor is running, then you have a refrigerant leak. The blower fan can operate and make noise, move air, etc. So make sure the compressor is working too.
Jul 18, 2014 | Dometic Rooftop RV Air Conditioner
I have a Dometic 13500 BTU AC. The fan runs but will not cool?
Sounds like it's low on refrigerant, if you haven't used it for a while they normally leak at the compressor shaft seal
Regards
Gordon
Apr 17, 2011 | Dometic Rooftop RV Air Conditioner
Dometic 579 Series Brisk Air AC runs fine-blower still runs but every couple minutes it "kicks on and off" it will blow hot air and then cold air and continues to do this. Did not do this until we...
sounds like it is skipping the motor I mean, I am assuming that it was replaced with the correct motor(rpms,hp,volts). As if it was not it will skip, like it is doing now.
Aug 28, 2010 | Dometic Rooftop RV Air Conditioner
I have my dometic Rooftop ac unit. The heatstrip/fan run perfectly but when I turn on the ac...the fan runs good but when the compressor kicks on it just hums.
The compressor coming on does make a slight "humming" sound which is normal. Is the unit cooling properly? Do you think it is louder than before?
May 09, 2010 | Dometic Rooftop RV Air Conditioner
Fan does not run. Low power hum audible.
sounds like you have a bad run capicitor on your fan check if the cap is swolen and or any oil around the terminals thats usualy a tail tell sind thats its bad
Apr 08, 2010 | Dometic Rooftop RV Air Conditioner
Dometic air conditioner blowing cool air
When the cooling slows down, but water is still running off, usually something is icing up. You can turn the unit off, and let it thaw, and try again. Sometimes, if the humidity is high, this is more pronounced. It sounds like you are low on refrigerant. That implies that you have a slight leak. You should have the unit serviced, and the leak repaired.
Best regards, --W/D--
Aug 01, 2009 | Dometic Rooftop RV Air Conditioner
My Dometic 620315 Penguin roof a/c does not produce cold air.
If the compressor is running with no cold air the unit is more than likely no good. It can not be recharged. you need a new unit. If the compressor is not running you need to check the capacitors.
Mar 16, 2009 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
