Kyocera fs8000c 5120 error : what is it; what needs to be replaced / cleaned / etc.?
  • 56 Answers
Clean separation charger wires, or replace separation charger wires or unit. This code says that there is separation voltage leak..
Posted on Nov 02, 2007
You will need to replace the cleaning lamp for the drum unit or replace the engine board
Dec 16, 2014 | Kyocera Mita Office Equipment & Supplies
What can i do for error code 5300 on kyocera 9130 printer
Broken cleaning lamp wire While the cleaning lamp is on, the broken cleaning lamp wire detection signal is detected for 2 s continuously.
Id look at replacing the drum unit
Aug 13, 2014 | Kyocera FS-9130DN Laser Printer
Call service Code 4600 KYOCERA FS 8520 MFP
LSU cleaning motor error
When the LSU cleaning motor
is driven, an error signal is
detected continuously for 1 s.
Defective connector
cable or poor
contact in the connector.
Reinsert the connector. Also check for continuity
of the connector cable. If none, replace
the cable.
May 17, 2014 | Kyocera FS-C5030N Led Printer
How do I solve Kyocera KM-1650 error code C6400
Usually these are just software issues which can be solved by uninstalling the old one and reinstalling it. Cleaning the system with a cleaning utility of all old unwanted files, links etc may help solve the issue. Restoring your system to an earlier date when you didnot have any issues will also solve the problem. Especially in Windows Xp.
May 12, 2014 | Kyocera Mita KM-1650 All-In-One Printer
My Kyocera KM-5035 receive error code 4200 in PC printing and in photocopy
Hello, This error C4200 indicates a problem with the main Laser Scanner Unit. The laser scanner functions to image onto the drum in the copier. It scans at a high rate of spped, the error indicates it is in trouble.
The Laser scanner would need to be changed.
It is also possible the main PCB is failing (remote chance)
Find a Kyocera Repair Facilty.
Dec 10, 2010 | Kyocera Mita KM-3035 All-In-One Laser...
Printing problems Kyocera KM 2050
when this error comes up..hit the print button on the left hand side..this will than tell you on the screen wha the actual problem is..i.e ( out of paper...lost connection etc
Jan 29, 2010 | Kyocera Mita KM-2050 Printer
I have a Kyocera FS-2000D printer that will not print
first turn off your pritner power.
check open the front door pull your ink cartridge then clean dust and blur from it then check there is not any paper jam then refix ink cartridge.then turn on the power.
Mar 21, 2009 | Kyocera FS-2000D Laser Printer
Scan error C3200
remove the flat wire in the scanner, then remove the railings from the scanner, clean the railings with a soft cloth, if you encounter the c3200 error it only means that the railings of the scanner is dirty, the scanner cannot move. i hope this will fix your problem..... if you have anymore questions regarding kyocera copiers dont hesitate to txt me or call me to this number +639081953003 or +639079941995
Feb 27, 2008 | Kyocera Mita KM-1815 All-In-One Laser...
Kyocera KM4035 Service Message C6050
the above is incorrect, Kyocera made a mistake by having a thermistor that physically touches the upper heat roller/belt.. it has worn the roller to a point where it throws up the error.. you will have to install a new fixing unit.
I have done over 25 warranty replacements regarding the 4050/5050/2525 etc.
Sep 14, 2007 | Office Equipment & Supplies
128 people viewed this question
