Question about Saws
Craftsman 3 inch circular saw model 112.10872.0 where to get blades
I have checked on line and at Sears hardware 3 inch circular saw blades not available can any one help this saw is great?
muttandjeff
  • 359 Answers
SOURCE: how to lock blade on older circular saw
ONE WAY IS TO TAKE A PAIR OF VISE-GRIP PLIERS ,LOCK THEM ONTO THE BLADE VERY TIGHT WHEN THEY TURN UP AGAINST THE BED OF THE SAW YOU SHOULD BE ABLE TO REMOVE THE BOLT THAT HOLDS THE BLADE WORKS WELL DID IT LOTS ( bear in mind some of the bolts are left hand threaded so if does not go one way try the other )
Posted on Nov 24, 2008
muttandjeff
  • 359 Answers
SOURCE: how do i change the blade on craftsman circular saw?
some saws don't have a blade brake , i always take a pair of vise grips and adjust to grip blade tightly and hold or bind against housing then remove bolts works well for me
Posted on Jan 02, 2009
rowdy45176
  • 2176 Answers
SOURCE: cannot remove blade from craftsman circular saw
without knowing the model number I can only assume that it is a circular saw and the blade is on the right hand side and then the bolt should be a standard thread. Hold the spindle lock in and turn the bolt counter clockwise to loosen. If other than it would probably be a left hand thread and do just the opposite. Let me know and if so please provide the model number so I can look at a breakdown for the tool.
Posted on Jan 31, 2010
odiebugs
  • 949 Answers
SOURCE: need substitute switch part for sears saw
Sorry , but go buy a new saw. Your not going to find an aftermarket
dealer that carries this switch.
Trying to rig some other switch is not worth the trouble over buying a new one. If the switch is not available, then the saw is old.
New
Craftsman Evolv 12 Amp 7-in Circular Saw 35.00 dollars.
Posted on Feb 15, 2010
  • 268 Answers
SOURCE: Where can I find a
take it to Lowes or Home Depot and they have switches that will work. My Lowes Hardware Store even will take it out and put in replacement switch.
Posted on Oct 07, 2010
I bent the depth of cut scale on a Craftsman 7-1/4 in. Circular Saw. How to true it so I can again set correct depths?
With the saw unplugged, lay it upside down on a bench or table. Put a small scrap of 2x4 against the blade and adjust until the depth of the blade matches the thickness of the 2x4. Lock it in place, Then bend or adjust the depth scale so that it reads 1-1/2 inches. Good luck.
Dec 10, 2012 | Sears Craftsman 7-1/4 in. Circular Saw...
My Craftsman 7&1/4 inch 12 amp Circular Saw(Model 315.108330) slips while cutting. The motor keeps spinning but the saw stops rotating. Can I Fix it?
Most circular 7-1/4 saws have a bolt and a compression washer that acts as a brake shoe that holds the blade secure but under dire circumstances will allow the blade to slip some rather than hold the motor shaft and allow burn out. The compression washer under your bolt has become worn and doesn't grip the blade securely. You can find a split washer that will fit under the blade and give you some more friction, or go to sears and order another compression washer for your saw.In the Sears Parts List found at: http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Saw-Parts/Model-32018780/0247/0744410/50035950/00001?blt=06&prst=&shdMod=
see part no. 44
Feb 23, 2011 | Craftsman Evolv 12 Amp 7-in Circular Saw -...
Need two 7 1/4 inch blades, can I find that in a store or do I have to order it??
You will find a large selection in any decent hardware store. You can also use 7" blades in your saw. the important thing is dont go larger than 7 1/4 and make sure the arbor matches your saw(or has a knock-out that will make it match). It's good to have a selection of different toothed blades on hand for your various projects. For basic construction, any brand of carbide tipped blade is fine, for finer work, my personal preference is Freud (less expensive)or Matsushita (more expensive).
Happy sawing:)
Farmerbear
Aug 30, 2010 | Sears Craftsman 7-1/4 in. Circular Saw...
I have an older sears cicularsaw model 31511850 i need a switch but it is no longer available where do i look?
The trigger operated switch should be available if you look at the switch itself and read the numbers off of it and find it on the web, its a pain but it beats buying a new saw because a cheap switch failed.
Jun 17, 2010 | Sears Craftsman 7-1/4 in. Circular Saw...
Need substitute switch part for sears saw
New
Feb 15, 2010 | Sears Craftsman 7-1/4 in. Circular Saw...
4HP Tecumseh flat-head head-bolt torque?
check the numbers on the motor and you can contact Tecumseh or check their website for info, they are usually very good with their help
Jun 29, 2009 | Sears Craftsman 7-1/4 in. Circular Saw...
Circular saw Types
There are for types of circular saws available. 1. Worm Drive - The motor is in line with the blade, delivering enough torque to carve up wet lumber or saw through concrete, which makes a worm drive ideal for framing or major renovation jobs. With the handle farther back, a user can better resist kickback and steer the 16-pound saw through long rips. 2. Sidewinder - The motor sits alongside the blade, making for a lighter (11 pounds or less) saw, which is more maneuverable over a long day than a worm drive. 3. Small Sidewinder - Weight, balance, and handle size are all key features to consider when choosing a saw that fits you. For a slight-bodied person, a small model may be more appropriate than a full-size sidewinder. 4. Cordless - Battery-driven models have increased in size as their power packs have gained voltage, making them convenient tools out in the field or when the electricity's not on. However, cordless models still have limited run times and generate less torque than corded saws. 5. Trim Saw - For finish work or paneling, this is your best choice. blades range from 3½ to 412 inches.
Aug 27, 2008 | Makita 794520 1 5 Pack 5" X 120 Grit 8...
Saws Logo
174 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
