In to installation stat hdd not detected how
In to installation stat hdd not detected how install the sata raid driver
how to gt that driver
Check the cable see taht the cable is alright and see tomthe bios setting unplug n plug again
Posted on Jun 19, 2009
Mother board masi km4am-l H.D.D. 1 TRA WES 64MB when installing win xp hard not detected by win setup. I updated bios but not worked. advance thanks
you should not update the bios...the issue is the hard disk is on sata ...and you need a raid driver installed to detect the hdd...so ...either get into BIOS and under advanced features..look the place where the drives are detected..and select the hdd and look for a feature called AHCI ..and disable it ..and leave sata like ide..and save with f10 and restart ...after that the hdd will be seen ..
another way is to make a floppy disk with the raid driver on it (the one from the mothermoard drivers disk ) ..and when it ask you to press f6 for 3rd party software ...press it ..and insert the floppy ...it will pick up the raid driver and will go like a charm ..
if you do not have a floppy ..install a second cd drive ..and use a cd ..and after pressing f6 for 3rd party ..browse and point to the raid driver on the mobo driver cd ..
Jul 15, 2011 | MSI KM4AM-L VIA KM400A CHIPSET ULTRA...
I have problem in asus A8V-vm motherboard in that hard disk is not detected in BIOS but Win-XP is working properly and when I tries to install new windows XP it shows an error that hard disk cannot be...
Asus A8V-VM Motherboard coming with SATA RAID option, thats why you could not see the detected HDD in system BIOS. But you can see the the detected HDD in RAID BIOS. You can enter to RAID BIOS that will pop up after system BIOS. If you are using old version of WinXP it will not detect the RAID controller of you motherboard. Thats why you cannot able to install WinXP. While you booting from WinXP CD press F6 key when the WinXP installer prompted for third party driver. Copy the RAID driver provider in driver CD to a Floppy Disk (INF file) and insert it, hit enter to continue the installation. If you are using WinXP Service pack 2 or higher you do not need this step it will automatically detect the HDD.
Nov 25, 2010 | ASUS A8V-VM Motherboard
I attached 500gb sata hdd to this MBoard. But it does not detect with window xp.
Windows XP installation CD does not have a SATA driver on the installation CD. Foe details on hoe to install Windows XP on a SATA hard drive, please click on this link and follow my instructions :-
http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive
Nov 15, 2010 | ASUS K8S-MX Motherboard
500 Gb sata hdd not detected on k8mm-v motherboard
Find in your BIOS if you have an option that says configure SATA as IDE, AHCI and raid. Set it at IDE and try again to install the OS. After intaling do not switch back because it will not work.
Apr 06, 2010 | Computers & Internet
Trying to install vista 32 bit on my Gateway DX 4720-03.Vista won't install because it can't see Hard drive. How do i disable ahci or sata mode in the bios or is there a work around to install Vista32.
Vista will have the drivers necessary to identify SATA/AHCI controllers, built-in by default. It would not be necessary to turn the AHCI mode 'off' or to 'ATA' mode (unless you get a 7B or inaccessible boot device BSOD). Check if your system has a RAID configuration, in which case there may be a 3rd party supplied RAID driver that you need to install first. Also, check if the HDD cables are connected properly & the HDD is detected in the BIOS (System setup screen) first.
Mar 16, 2010 | Gateway DX4720-03 PC Desktop
I have a asus K8S-MX i want to connect SATA HDD
To enable sata port press Delete Key when computer Starts. U will get BIOS menu. On there the Main settings window the second last option is to enable sata option. If u want to install widows OS (XP,2000, Server edition) **** Driver CD and go to RAID folder there u get a driver ( shown as Floppy drive Image). Incerte Floppy in drive and click that icon. And click Extract. Then incert the OS CD. On starting of instalition u will get a option press F6 to install Raid Disk. Press F6. On Bitween instalition u will get a option to install this Raid. ( With out this RAID u cant install XP or Other vartions of windows in ur sata hard drive)
Mar 31, 2009 | ASUS K8S-MX Motherboard
Motherbord Bios & Driver Download
not sure what model of your asus m/board.. please provide details...
or perhap you can check below site if there is any model related to your motherboard issue...
http://etech.maiila.com
Nov 01, 2008 | ASUS K8S-MX Motherboard
Installing windows on SATA HDD
That happens because the BIOS uses a SATA controller that is not included in Windows XP install disk.
Usually you can solve the problem going to BIOS settings and changing SATA/RAID settings.Check your BIOS settings, and disable SATA RAID mode.This is done in different ways depending on the BIOS.
On HP/Compaq computers for example you press F2 on startup to enter BIOS, then disable SATA mode on bios settings.
On other makes the procedure can be slightly different.
Another way to fix the problem, is by creating your own XP setup disk with SATA drivers included, see:
Resolving "Setup did not find any hard disk drives" during Windows .
Sep 08, 2008 | Soltek SL-75FRN2-RL Motherboard
Sata hdd detected but problem with booting&installation
i have sata hdd 160 gb of seagate and hdd detected in raid channelbut when start installing window it shows message press enter for fresh installation "no hdd found please check power card,bios configuration
Jun 30, 2008 | ASUS P5RD1-VM Motherboard
Cannot Detect Hard drive Winxp On Toshiba Satelite L200
Hi ,
u can not detect HDD during installing win-xp coz in u r laptop u have SATA hard drive.
to detct hdd in setup u want to make sata netive mode diseble in COMS setup
Plz check COMS thereis sata netive mode is available ....
if this information is useful for u please rate me......
Jun 14, 2008 | Toshiba Satellite Pro A200-EZ2204X...
Computers & Internet Logo
Alun Cox
David Payne
David Payne
