Question about Proscan 50" FHD 1080p Roku Ready Black LED HDTV - PLDED5030A-C-RK
Proscan 50 LED Tv has lines in screen and is jumpy
3 Suggested Answers
FSAhead2
  • 214 Answers
SOURCE: does the Proscan 47" LED
yes it does , if you are viewing the TV from the rear it is located in the back on the lower right , on the right side of the RCA's . here is a link to give you a visual , just wait for the manual to pop up .
http://www.managemylife.com/mmh/owner_manuals/15565/PROSCAN-LCD-Television-L1001098
Posted on Jan 28, 2011
jdvillanueva
  • 2098 Answers
SOURCE: bought a 26 inch proscan from Costco on line. Tv
Hi sglassgold,
Here are steps that may help you fixing the problem. You should prepare tools and multimeter.
I'm assuming that your unit is dead set and your outlet is live.1.Power cord - check the cord it might be opened (no continuity).This is due to frequent bending,pulling. 2. Power switch - check for dry joints, open contact. 3.Check the internal fuse- sometimes the fuse fail because of the power surge, replacing with new one will cure the problem, If this is the case I've advice you to use surge protector/AVR (Automatic Voltage Regulator). However if the fuse blew again this is an indication that you have a shorted parts on the power supply, you may visit the linkhttp://www.fixya.com/support/r8053361-fuse_keeps_blowing for more info. If no reaction and still the unit didn't power up then you have an open parts on the power supply.
4.If you see that the fuse is intact on the board, don't attempt to touch anything because there somefatal components stored electricity enough to hurt you with a simple mistake only.
The next steps should be done by an expert or qualified technician because isolating the problem on the power supply is technical and complicated. I would advice also to replace the entire power supply for your convenience if finding technician there is not possible.
Also check if your unit is under warranty before opening the back panel, it will void the warranty. Avail it because the manufacturer of your unit will fix it for free or a little charge only.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Feb 14, 2011
My Proscan 50 LED TV PLDED5066A-E picture totally went out, but the sound is normal for each station. Do I need a new power supply?
In most of the case, the problem is defective LED back lights strips.
You may try a new power supply first.
Aug 18, 2017 | Proscan Televison & Video
50 in proscan led tv powers on then has black screen but can see screen work with flashlight
Your backlighting is no longer working.
With a LED TV it's an array of LED's that light it, in an LCD TV it's fluorescent bulbs that do the backlighting.
There's a chance it's the power supply board that's bad, unfortunately, it could also be the backlighting itself.
You'll need an expert to look at it to make that determination.
If you don't know Electronics, don't open it up yourself! There are hazardous voltages even in flat screen TVs. The hazardous voltages are there even when the unit is unplugged!
Jul 17, 2016 | Proscan Televison & Video
Why vertical lines on half of screen after moving Proscan 39" LED TV?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 14, 2014 | Proscan 32LB30QD 32 in. LCD TV
My 50" flat screen tv isnt turning on why not what can I do to fix it
If you are a trained and qualified TV-repair technician, you can trouble-shoot it and fix it. Otherwise, take it down from the wall, and take it to a qualified technician.
Jun 13, 2014 | Curtis Proscan 50" Led 1080p 60hz 8ms
Screen is jumpy and has lines through it
You do NOT try to fix it. Instead, because it is "brand-new", you take it back to where you bought it, and EXCHANGE it, and then it will be the responsibility of the seller to send it back to the manufacturer for repairs.
Apr 18, 2014 | Proscan 50" FHD 1080p Roku Ready Black LED...
Led tv horizontal lines
If the lines are multicolor such as pink, yellow, cyan and white, you most likely have a damaged Led screen. You could have just bumped it on something unknowingly and joggled a connection loose too. If I were you I would consult with the store where you purchased the item and see if they will send it in for a check, this may cost you 50-60 dollars but it's worth not buying a new TV.
Source: My laptop has the same thing.
Nov 13, 2013 | Proscan Televison & Video
Screen gets horizontal lines and jumpy screen.
Your problem is capacitors CP204 and CP205 by the 9 volt regulator on the main board. Cp204 is a 47 microfard @ 50 volt and the other is 100 microfard@ 16 volts
Nov 13, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Proscan 50" FHD 1080p Roku Ready Black LED HDTV - PLDED5030A-C-RK Logo
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
