Wurlitzer troubleshooting I recently acquired and have almost finished repairing a 1936 Wurlitzer 412 Simplex. I am having a problem with microphonics, and from what I understand this is a common problem with this particular model. However I know they can work without having this problem, and I can't help but wonder if there is some sort of fix I am missing that will not detract from the value of a wonderful old machine. I have replaced several capacitors, checked to ensure everything is tightened and secured properly, but cant seem to get rid of the problem. Do you have any suggestions?
    Champion:
    Habit-Forming:
  • 239 Answers
Could it just be coming from one of the valves
Posted on Aug 09, 2014
  • 8 Answers
SOURCE: wurlitzer 1015 problem
Most likely the main fuse inside the wurlitzer itself - situated screwed into the lower right hand side of the amplifier panel.
Posted on Dec 24, 2007
  • 38 Answers
SOURCE: I am looking for an owners/operating manual for a
Is this a ONE MORE TIME WURLITZER MODEL, I CAN MAKE YOU A COPY A COMPLETE COPY.
(DOCTOR FIX JUKEBOXES)
In-Home Jukebox Repair. is company name. e-mail=== SEYLEVITT@JUNO.COM
my name is SEYMOUR LEVITT
Posted on Jun 10, 2009
  • 211 Answers
SOURCE: Wurlitzer 3600 Jukebox turntable problem
The 3600 has a hub that is supposed to play dinked and undinked records. They had 33rpm and 45 rpm records back then, so to change the record speed the undinked (small hole ) records pushed down the hub flat when it landed on it, which changed the gearing. When a dinked (big hole) record lands on it falls onto the larger part of the hub. So if the hub is down and stuck there that's your problem. After the hub has been pushed flat (because of a small hole record) it is supposed to rise up again when the record is returned to the carousel. Have a look under the turn table and push up the centre rod.
Posted on Jan 13, 2010
  • 211 Answers
SOURCE: left bubble tube for wurlitzer WR18 no longer
It can only be replaced by another one, but they aren't easy to find. Try www.wurlitzer.co.uk who sell parts in the UK.
Posted on Feb 21, 2010
  • 5 Answers
SOURCE: Wurlitzer 1015 OMT Disc spins, then stops....
Spoke with "Doctor Jukebox" from Folsom, CA about a similar problem I had. You can find him on craigslist.
I did NOT have the "2222" display issue.
Root cause: The laser isn't "seeing" the CD and interprets inability to see as being the end of the track, therefore, puts the CD back into the carousel.
Solutions:
1) Clean the lens. Be careful to use an appropriate lens cleaning solution. The lens is made of plastic and may cloud up if a harsh solution is used. Use a Q-tip dipped into the cleaning solution and gently clean the lens using a side-to-side motion, not a front-to-back motion. Wait for a bit until the lens is completely dry, then try playing a CD. (note: this fixed the problem for me)
If that doesn't work...
2) Replace the laser module. It's easy to remove with a torx. Be gentle when disconnecting and reconnecting the ribbon cable and/or other connections so you don't bend the leads. Laser modules cost a few hundred dollars, so try Solution 1) above before replacing the module.
Posted on May 22, 2010
Where can I hire a repairman to fix my Whirlitzer juke box?
go google and type in--- service agents for wurlitzer juke box ---
find and agent closest to you and call him on the phone
Dec 23, 2016 | Audio Players & Recorders
What is the age of my Wurlitzer piano serial number 192157?
Free Piano Age Research Look here. It looks like it was built between 1939 and 1940. Go down the page til you find Wurlitzer; after 1937: The year built is found by finding the serial number 192157, which would be between 180000 and 195000. That would make it having been built between 1939 and 1940. Hopefully, that's correct.
Jan 30, 2015 | Music
Why is my wurlitzer one more time not playing the cd
Faulty CD player or control pcb. If it is the more recent CDM12 player, or control pcb I can repair it. www.jukebox-repairs.co.uk
May 04, 2014 | Wurlitzer Jukebox 1015 One More Time...
Looking for the age of a wurlitzer piano with serial number 912242
WURLITZER
Apollo-De Kalb-Julius Bauer-Melville Clark-Farney
Kingston-Kurtzman-Merrium-Schaff Bros.-Underwood
1901- 480 1910-11600 1919-36000 1928-85000
1902-1430 1911-13000 1920-40000 1929-93000
1903-1910 1912-14000 1921-45000 1930-112000
1904-3000 1913-15000 1922-49000 1931-118000
1905-4500 1914-19000 1923-53000 1932-126500
1906-6000 1915-22000 1924-58000 1933-130300
1907-7500 1916-25000 1925-63000 1934-133300
1908-9000 1917-28000 1926-77000 1935-136000
1909-10300 1918-32000 1927-80000 1936-138700
After 1937:
1937-150000 1952-444000 1969-106500 1981-1645000
1938-175000 1953-474451 1970-1105000 1982-1700000
1939-180000 1955-537000 1971-1145000 1983-1725000
1940-195000 1960-657000 1972-1175000 1984-1775000
1941-210000 1961-715000 1973-1205000 1985-1825000
1942-225000 1962-760000 1974-1235000 1986-1850000
1946-330000 1963-815000 1975-1266000 1987-1900000
1947-333000 1964-860000 1976-1296000 1988-2020000
1948-340000 1965-905000 1977-1385000 1989-2055000
1949-370000 1966-945000 1978-1495000 1990-2080000
1950-400000 1967-985000 1979-1550000 1991-2115000
1951-419000 1968-1025000 1980-1595000 1992-2145000
http://www.bluebookofpianos.com/serial1.htm#WURLITZER
Dec 23, 2013 | Computers & Internet
After making a song selection, the device attempts to play the CD. The CD begins spinning then stops and does not play.
Troubleshooting procedures are different depending on which player system is in the machine. I can help with troubleshooting over the phone and can repair any on the components insdie the machine. Please email tech@wurlitzer-ohio.com.
Aug 19, 2011 | Wurlitzer Jukebox CD Player
Wurlitzer jukebox cd - when you punch in cd selection it goes into error mode "44" and seem not to recognize the cd. it does not play
I'm not sure what you are referring to by "error mode 44". I know Wurlitzer jukeboxes quite well and can help you troubleshoot over the phone. Please email tech@wurlitzer-ohio.com.
Mar 23, 2011 | Wurlitzer Jukebox CD Player
I need a repair shop reference in n.c or ga. or tenn thanks ihave awurlitzer replica 45 #1015 Wurlitzer Jukebox 1015 One More Time 100-Disc CD...
Although I'm not located in the states you prefer, I am the official Wurlitzer jukebox service center for the USA. I can help troubleshoot over the phone and make any repairs to any part inside your jukebox. I also have one of the largest stock of replacement parts in the country. Please email me for my phone number or more information. tech@wurlitzer-ohio.com.
Apr 12, 2010 | Wurlitzer Jukebox 1015 One More Time...
Digital display wont light up and machine is unresponsive to keypad
Have you checked the power supply in your jukebox for any blown fuses or circuit breakers that have tripped?
Regards
Alan Hood
ami-man
UK
Feb 03, 2010 | Wurlitzer Jukebox 1015 One More Time...
Four Wurlitzer 5250 wallboxes... need troubleshooting tips, etc.
Contact Greg Dwinell, Orange Sound of South Hadley, he can get that for you (413) 533-0900
Dec 16, 2009 | Wurlitzer Jukebox CD Player
51 people viewed this question
 Grubhead
Grubhead
