Question about U-Line Kitchen Appliances - Others
I have CLR 2060 too much water on the pum - U-Line Kitchen Appliances - Others
2 Suggested Answers
  • 286 Answers
SOURCE: What freon 134A
R134 IS THE CORRECT REFRIGERANT IN U-LINES ICEMAKERS
Posted on Jun 22, 2009
How do I clean my iron? Sometimes my clothes get stained and water drips from the bottom. Please help.
Get some CLR descaler and mix it to the directions. Turn the iron on and set it to steam. Turn the iron off and put the CLR into it. When it has cooled a little, sit it faceplate down in an oven proof dish. Leave it over night. The CLR will drip through and sit in the dish cleaning the inside, and the topside of the soleplate. The next day, fill with water and shake upside down to empty any remaining CLR and scale through the fill hole. Keep filling and shaking to empty until the water comes clean.
If you don't want to use CLR, you can use white vinegar undiluted.
CLR
Mar 18, 2016 | Rowenta DX9800 Iron
Clean distilled
Use CLR or any other lime scale remover you can find. Pour out any water in the bottom chamber and put some CLR into it. leave it for 10 minutes to an hour. Run it to have some CLR so though any passages, then pour out any remaining CLR and replace with water again to wash out the CLR. When you are satisfied that the CLR is all rinsed and replaced with clean water, then it is safe to iron again. CLR can alway be put on a cloth and wipe the iron surface or any deposits.
Oct 15, 2013 | Tefal GV7070 Iron
My mansfield toilet 160 has a weak flushing problem
My toilet had same problem:
I thought it was a clog in the drain pipe.
But the problem was clogged holes where water flushes into toilet bowl.
Here's how I fixed problem.
Purchase:
Gallon of CLR calcium-lime-rust remover from Home depot.
Pumice stone from hardware store.
Home supplies:
Cut off bottom of empty clorox bottle to make container for CLR
Old 3" paint brush you don't use for anything else to apply CLR
Small cup to pour CLR into toilet flapper opening
Steps:
Look inside toilet bowl under rim and see holes where water comes out
Use brush and apply CLR to holes where water comes out.
Use pumice stone to scrape ... pumice stone will not hurt toilet surface.
Flush toilet to clear holes so far.
Turn off water to toilet.
Open flapper to drain tank.
Keep flapper open.
Use cup and pour dose of CLR directly into flapper opening.
(You can also pour CLR down overflow tube... but flapper opening puts whole dose directly onto problem)
Pour another cup of CLR into opening.
Notice how CLR starts coming out the holes into bowl.
Pour CLR down flapper hole until it runs easy and fast out of holes.
Close flapper, turn on water, toilet fixed.
Nov 22, 2010 | Home
Asko D3120 I have resolved the problem of pum always running by tilting the dishwasher but now I have a new problem of the pump not draining the water in the bottom of the dishwasher. I thought it was...
In the bottom where the filter are, you can see a yellow 'thing'. Remove this and stick one finger in an try to rotate the pump wing. Try to remove particals that is blocking the pump.
Or there is something in the drain hose. Try to drain the machine by holding the drain hose over bucket. If it drain here, then the problem is under the sink.
Jul 17, 2009 | Asko 24 in. D3120 Dishwasher
What freon 134A
The freon in most ice makers are R 410a at this time. You will be able to find the type of freon your model has listed most times on a data plate on the rear of the ice maker cabinet and on or near the compressor. R 134a is not always used in production ice machines because it does not freeze water as productive as
R 410a. The type oil in the compressor also will lead you more in the direction of the type of gas. Now If you need to replace the freon or compressor I can help you determine the exact type of freon gas was existing before the change, Let me know if this has answered your question. Thanks, Sea Breeze
Feb 06, 2009 | U-Line Icemaker
Bosch Maxx WFL 2060
connect at random. put on a rinse cycle. if cold water comes in then pipes are correct. if hot water comes in then pipes are wrong way round and just swap them
Sep 13, 2008 | Bosch Axxis WFL 2060 Front Load Washer
CLR 2060 Clear Ice Maker
just a guess but did you make sure that the fan under the unit is turning? if you don't get rid of the heat at the condensor the freeze tray can't get cold.
Aug 02, 2008 | U-Line Icemaker
Kitchen Appliances - Others Logo
16 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
