Question about Watches
Trying to find battery for casio watch MQ51W back of watch has 336 but no one has it.
I opened mine (back marked MQ-51W and 336) and it has a "371" battery.
Posted on Jun 29, 2014
My watch Casio buttons has stopped working, what is the problem.
Hi
What Casio model is it?
Do you still have a bright display?
Have you tried removing the battery to reset it?
In some Casio watches like the Protrek range the back light button fails to activate the display light. This is sometimes caused because the earth flange that completes the circuit when pressed has bended to far or snapped and fails to complete the circuit.
More info about the watch may help find a solution. mean time change the battery it may start working again. Good luck
Feb 12, 2017 | Casio Watches
Mtg 900 comes up charge and says recover. What do i need to do? I tried charging it under a lamp for several hours but that does not last long.
I have a watch which is solar type and the instructions say that several hours of sunlight will charge the battery but lamps need much longer (1 -2 days!), my watch now is left in a drawer.
If you haven't got instructions for your watch, to check what Casio recommend, you can get them on the net.
You can get instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Apr 05, 2011 | Casio Atomic-Solar MTG900 Watch
How di i change the batteries in my Casio Pathfinder 2782
  • Choose a quiet, well-lit room where you can replace the battery in your Casio Pathfinder watch. Prepare a table, desk or other clean, flat surface where you can perform your watch repair. Put down a soft cloth or piece of craft felt to protect the face of your Casio Pathfinder watch from being scratched during the battery installation process.
  • 2
    Set your Casio Pathfinder watch face-down on the soft cloth or craft felt. Use an optical-sized Philips screwdriver to remove the four screws that secure the watch back to the body of the watch. Set the screws aside, but don't lift the watch back.
  • 3
    Slide the watch back off of the body of the watch very slowly. There are three important springs held underneath the watch back; it is essential to remove the watch back slowly to avoid losing them.
  • 4
    Lift the three springs out of your Casio Pathfinder watch using a small pair of metal tweezers. Take note of the length and placement of the springs as you remove them. Set the springs aside with the other disassembled watch components.
  • 5
    Take the black rubber protective disk out of your Casio Pathfinder to reveal an identically-shaped white plastic disk. Remove the white plastic disk and set it and the black rubber disk aside. Use your metal tweezers, if necessary, to lift out the rubber and plastic disks.
  • 6
    Release the battery strap that holds the battery in place in your Casio Pathfinder watch by pushing the battery strap latch to the left. Remove the old battery from your Casio Pathfinder using a pair of small plastic tweezers.
  • 7
    Pick up your replacement watch battery with the small plastic tweezers and insert it into the battery compartment of your Casio Pathfinder watch. Replace the battery strap and push it gently with the tip of your plastic tweezers to snap the latch in place.
  • 8
    Touch the "-" and "AC" terminals on your Casio Pathfinder watch with the tips of your metal tweezers for at least two seconds. This helps ensure that your watch will work properly once reassembled.
  • 9
    Put your Casio Pathfinder back together to complete the new battery installation. Start by replacing the white plastic disk, followed by the protective black rubber disk. Use your small metal tweezers to replace the small watch springs in their correct locations. Replace the back cover of your Casio Pathfinder, insert the four screws and tighten them with your optical-sized Philips screwdriver.
  • Best regards. Jewel
    Sep 20, 2010 | Casio PRG-40T-7 Pathfinder
    How do I replace the batteries on my Casio Pathfinder PAG40B-2V watch?
    Thank you for contacting FixYa.
  • 2
  • 3
  • 4
  • 5
  • 6
  • 7
  • 8
  • 9
    Sep 19, 2010 | Casio Pathfinder PAG40B-2V wristwatch
    Resetting everytime i use the back light
    It may be that the watch is working in one of the "settings"modes.
    If you do not have any instructions you can get them from their web site.
    Select "support" and the "manuals", watches;
    Accept terms
    Mar 13, 2010 | Casio DBE301AVDF (Size: ) Watch for Men
    Casio watch no longer beeps.
    Try getting instructions from Casio.
    Accept terms
    Click on "search" and the download your instructions.
    If you can't find anything useful, try their technical support.
    Mar 10, 2010 | Casio DB360G-9A 30 Pages Telememo Watch
    I have a Casio DBC-60. I changed the battery because was not working for long time, but the watch stil is not working
    This is an old problem, but maybe this will help someone changing a battery on a Casio. Many Casio watches must be "zeroed out" by putting an pointed tweezers between the back of the battery and the AC terminal off to the side of the battery. On my old Casio Telememo 50, the AC terminal is in a very small hole just above the battery. On the Baby G force, it was in a wider opening, way at the edge of the watch. It has something to do with resetting the watches circuitry so it will operate again. Good luck!
    May 14, 2009 | Casio Watches
    Battery replacement
    You can do it yourself. Unscrew watch caseback and undo the contact on top of battery. Read the writings on battery and buy exactly the same one. Do not mind manufacturers (Casio, Maxell, e.t.c.), just make sure the numbers are the same.
    Some watch casebacks can be opened only if the watch band is removed, so, remove it if needed, just don't forget to memorize where every part and screw was fitted. Memorize how the battery is fitted and do not put the new one the other way around as this can damage your watch.
    Actually there is nothing difficult - only you have to put everything back exactly the same way as it was. If your watch will be left without battery for more than 3 minutes, you will need to reset your watch after replacing a new battery, but it's easy if you've got users manual.
    Good luck.
    Do not forget to rate, please.
    Mar 11, 2009 | Casio PRG-40T-7 Pathfinder
    I had the battery in my Casio G Shock DW 6800 replaced. Since then none of the beeps or alarms have worked. Is there a reset button he didn't press?
    There is a reset button inside your watch, but I don't think that is the problem. Most likely, there is a spring that makes contact to the watch and the back of your watch case, and it fell out by the person replacing your battery. I would definitely go back to the place where you had the battery installed, and have them take care of the problem buy ordering you a new spring or have them pay for you to send it to Casio.
    Apr 24, 2008 | Casio G-Shock GW500A-1V Wrist Watch
    Casio watch
    Get the code from the back of your watch and try going to the casio site for the manual. http://world.casio.com/wat/download/en/manual/ I was reminded of this by Noggins posts No if I could only figure out how to change the battery
    Jun 20, 2007 | Casio Technowear CMD40B-1T Wrist Watch
    Watches Logo
    65 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
