We have just moved into this home and we cant get the heat to work on the air conditioner
  • 6 more comments
  • lindsayjulia Jun 19, 2009
    what solution did you send through, so you need the make and model?
    the IAG air conditioner is not send out warm heat is there a manual or can someone tell me how to work this conditioner the model is IAG 6-60gw/a
    yes it is a split system, its blowing air so the fan must be working also the louvre door swings, the lights some on the front of the air con.
    Sorry its a heat pump
    the number i gave was incorrect it is IAG 60gw/a hope this helps
    No definately no KF number, the fan and the compressor have both come on, on the outside unit
    on the front of the remote is in capital letters IAG and a swirly symbol. jit has anon/off button underneath that is three across mode control fan control and louver control under that is timer control and the a + and - sign time and temp under that is the sleep button, it seems to be working now, maybe it was just us ...... modern technology and all .... thanks for you time and help
    thankas for your help it is working fine now.
  • 334 Answers
Hey there, I should be able to walk you through this. First I need to know hat knid of system you have. Is it a split system, one unit inside, one outside. Is it a heat pump, gas furnace. And also what kind of tstat do you have. Is anything running, fans compressor, let me know what is and what is not.
Posted on Jun 19, 2009
  • 4 more comments
  • seth veloso Jun 19, 2009
    OK, does the system run on gas for heat or do you know if its a heat pump?
    try looking for a make and model number on the outdoor unit. The number you posted is not any good.
    OK, you got a heat pump, if you turn the thermstat up so there is a call for heat, make sure the fan in the house turns on (sounds like it is) then go outside. The fan outside should be running and you should also be able to hear the compressor runnin, a loud motor inside the unit, let me know what you find. Depending on the equipment, there may be time delays in the thermostat and/or outdoor unit. Give 10 mins at most for the outdoor to come on, usually 5 min after indoor comes on. The fan and compressor should both come on outside at the same time
    would the model number KF-60GW/A make sense, it would be on a tag somewhere listed under model number or m/n
    Ok that is good news, very carefully, fell the pipes going from the outside to inside, the bigger one may be very hot do not grab it
    I am still having troubles fing the manufacturer of your unit, is there a name or design on the side of it somewhere or on the remote if you have one
  • 297 Answers
Whats the model and make of the air conditioner you are using?
Why can i see outside looking into my air conditioner?
It extracts the heat from inside your home to the outside, that's how an air conditioner works. It also bring in some fresh air from the outside. You should have a damper that can be closed if needed. If you have gaps around the unit, then seal it with some weather striping material. It is wise to cover the air conditioner during the winter months to prevent any cold air from coming in. Hope this helps!
Jul 22, 2011 | Fedders A3X05F2A Air Conditioner
Why the out side unit get ice and freezing when it work on heat
this is common your condenser becomes the evap. pulling heat from outside air to heat your home.assuming were talking about a heat pump
Feb 13, 2010 | Samsung AS18A6RB Air Conditioner
Heat/AC unit in working order, plugged in 20Amp outlet.. no fan?
Hi1
Do you have at least 200 volts at your outlet? Check that first. You said you brought it home from work, so when you plugged it in at home did you plug it into a 120 volt recepticle?
Jan 01, 2010 | Emerson Quiet Kool 12NW46HK Air...
Does this heat pump also work as an air/con. Just moved in to new home and not sure if it works or not. thank you
All heat pumps are A/C units heat pumps are slow to give good heat but as the inside temp gos up so will the tempiture that comes from the vents
Nov 28, 2009 | Heating & Cooling
Moved into a new house with a goodman air conditioner. it is also the heater (?). No experience with this. Is there something we need to do when switching from air conditioning to heating? we turned it to...
Well it might be a heatpump. Where it uses the A/C portion of the system to draw heat from out side and place it into you home. If its a new home I would call for a Check-Up its only $60 to $80. But dont buy anything you dont need like a new thermostat. Just tell them to check the refrigernt levels and to tell you if everything is runing ok.
Oct 16, 2009 | Goodman CLQ36AR49 Air Conditioner
Cant get heating to work
adjust temp e.g. 39 deg Celsius or high and turn on heat,but first you must turn off air conditioner then select heat rating and turn on a.c.
Jul 05, 2009 | Heating & Cooling
Heating & Cooling Logo
73 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
