Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Cub cadet 2166 pto not working - Cub Cadet Street Sign- tractor lawn riding mower parts
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Cub Cadet Master
  • 1,917 Answers
Check fuse then check to see if power going to pto if is bad pto if not check switch then safty switches
Posted on Dec 17, 2014
panilling9
  • 284 Answers
SOURCE: engine stalls when electric PTO clutch is engaged
check your spacers to be sure you havent locked the clutch assembly directly to the motor shaft
you should be able to turn it fairly free less some clutch drag
Posted on May 26, 2009
  • 85 Answers
SOURCE: Cub Cadet LT1018. When I go into reverse the
the safety switch on the pto lever is not activated (lever is not back all the way)
this unit should not cut in reverse
Posted on Aug 17, 2009
  • 33 Answers
SOURCE: I need a deck belt for a cub cadet 2166 what
http://www.cubcadet.com/webapp/wcs/stores/servlet/category1_10051_14101_1100505_Y_-1
Posted on Aug 21, 2009
  • 110 Answers
SOURCE: Cub Cadet LT1042 PTO won't disengage
If its an electric PTO then the switch on the dash is bad, Its a lever type ungagement then the little break shoes that rub on the blade spindles are either worn out or mis adjusted.If it started when you changed the blade drive belt its possibly the wrong belt??
Posted on Nov 01, 2009
hunter19_46m
  • 7482 Answers
SOURCE: Cub Cadet 2166 won't start...........new
Sounds like your solinoid switch is bad, replace it
Posted on Oct 03, 2010
Model 2166. Where can I get diagram showing PTO belt installation?
http://www.cubcadet.com/webapp/wcs/stores/servlet/ARIPartFinderView?storeId=10051&catalogId=14101&langId=-1#/s/CUT/2166//1
Oct 07, 2015 | Cub Cadet Garden
I have a 2166 cub cadet and the pto belt keeps breaking why
Check that belt is mounted properly according to the diagram on the tractor. Frequently people put the belt on the wrong side of the steel guide springs so that the belt is abrading the springs instead of smoothly riding on the pulleys.
Jan 12, 2013 | Garden
Cub cadet 2166 dies when I engage PTO or let brake peddal all the way up
replace that safety switch there is two switches built into one
Jun 11, 2012 | Cub Cadet Garden
My son was mowing, with our cub cadet 2166, and ran the left front tire into a fence and now the steering wheel wont work. You can turn it and it feels really loose but it isn't connecting to the
Check the two main gears. One at the end of the steering shaft and the other that it contacts. Some brands are adjustable where the large gear is held on by a bolt and an excentric which allows you to move the large gear closer to the smaller gear. This may have been knocked out of place or the gear(s) stripped. Here is a basic diagram of the parts.
Cub Cadet 2166 steering parts
May 19, 2012 | Cub Cadet Garden
How do you change the battery out of a Cub Cadet 2166 mower?
disconnect the ground wire first then the pos one there should also be a few bolts that hold the battery down
Mar 29, 2012 | Garden
I have a cub cadet 2166. Blades are not kicking on when the pto switch is engaged
hello, the pto or belt is bad,for the pto repair see u tube,,
Feb 18, 2012 | John Deere Garden
Cub Cadet 2166 series. Mower will not engage.
Unfortunately, the circuit is a little complicated - it involves the "PTO switch" (the switch you pull on to engage the mower), a "reverse switch" that senses if you've put the mower in reverse, and a relay operated by the reverse switch. The reverse switch is there to disengage the blades if you try to reverse while mowing. A failure in any of those items, or the connectors and wiring between them, will prevent the blades from engaging. Unless you want to "shotgun it" and replace parts one-by-one on a guess (which many repairmen to do save time, but at your expense) you need to use an ohmmeter or test light to trace and isolate where the failure is.
Jul 10, 2010 | Cub Cadet Garden
Engine stalls when electric PTO clutch is engaged
Apr 11, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
139 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
