Question about Oreck XL® Air Purifier
How to reset flashing red light on the oreck air purifier
SOURCE: Oreck XL air purifier problems
You probably have an open circuit in the high voltage circuit. Most likely cause is a broken or disconnected wire. The high voltage wires are very small diameter stainless steel and are connected to alternating aluminum plates by a crimp connection at the ends of the plated. If you insert an object like a brush or wood tongue depressor/popsickle stick in to scrub the plates during cleaning you run the risk of pulling the wires lose or worst case, breaking them. If you just pulled some loose they can be repaired ( I know because I have done it) but you have to partially disassemble the cleaner cartridge to get to the end of the plate(s) with the disconnected wire(s), open the tab that grips the wire, insert the wire in the tab, re-crimp it, and then re-assemble the cleaning unit. I would rate it as moderately difficult. Be careful in bending all the tabs as they are aluminum and will break if bent too much or too many times. Good luck.
Posted on Jul 04, 2008
SOURCE: red light wont change back to green after cleaning
I did the same thing and now I need to replace the cell collector. You need to replace it to if the wire is broken. Please let me know the outcome of your problem.
Where to find the part is hard to get.
animallover2
Posted on Nov 09, 2008
SOURCE: Oreck XL air purifier motor failure
My Orek was making such a bad noise that my wife was going to sell it at a garage sale, I'm glad she didn't. It takes about 20 minutes to fix. All you need is a phillips screw driver, can of compressed air (or air compressor) and a can of silicone spray.
Pull out the filters and turn the unit upside down. Using a phillips screw driver unscrew the 9 screws holding the bottom to the top. remove the bottom. Use care as to not damage the fan. The fan will stay attached to the motor , pull on it and use a good cleaner like 409, Simple Green or a similar product. Wash clean and dry. Next get out your air compressor and clean everywhere, see the silver bearing holders on the side of the motor? Get out your can of silicone spray and give a good squirt on both bearing (close to the shaft. also spin the motor with your hands. See the large thing attached to the shaft? Those are the windings. See the metal housing the winding spin close to? Spray the silicon in there, a good amount. Make sure you didn't get any silicone on the end of the motor shaft where the fan sits on. If you did get some nail polish remover or acetone and wipe clean a few times. Then reassemble.
My Orek was horribly noisy, now it's quiet. My wife says is beeter than new.....
Posted on Apr 17, 2009
  • 3 Answers
SOURCE: Cleaning the top of the oreck air purifier
what i normally do, is i take off the top of the and remove the filter, the metal dust catcher, and the back filter... i was the 2 filters and rub them down. then with the metal dust catcher i take a butter knife. wrap it in a clorox wipe (making sure that no metal is exposed to scratch) then i feed it through the metal dust catcher one at a time to clean it. It took me 5 wipes to clean the whole thing. when the wipe comes out black then i rotate it. As for the top of the machine. there are 2 screws that i removed to get to the fan. when they were out i used a can of air (like you would clean a computer with) and blew out the fan... it took care of all noise and it runs just like the day i got it.
Posted on Oct 13, 2009
SOURCE: I need a manual for the Oreck XL professional air
How do I open the Oreck XL to get the filter out to clean it?
Posted on Dec 05, 2009
My oreck cell does not collect dust, but the light is red are the wires broken?
Depending on what model , when my red light comes on and flashes it usually has something stuck in the cell it can be real small even or lots of build up on cells, when you pull out the cell you can determine if the wires are broken.
Mar 11, 2018 | Oreck Air Purifiers
I changed filter on oreck airstream purifier 2 days ago but light remains solid red.
you have to check OM. Usually you'd have tu push something 10 times to reset
Jan 22, 2018 | Oreck Air Purifiers
A red light flashing with clean filter
bad connection on plates or wires that run along the front of the plates in the cell. If you hear snapping or arcing then its the plates shorting out, look for bent plates and broken wires or loose sagging wires.
Aug 01, 2014 | Oreck XL Professional Air Purifier
Red light reset
you mus read your owner manual for reset the light. Normally you must disconnect the power cord from outlet, by 45 seconds, and connect again. or download the i.manual from www.manualslib.com
God bless you
Oct 08, 2013 | Oreck XL Professional Air Purifier
Reset oreck XML professional
The reset button is power button,look at what it says under cell check button, hold(symbol) button t reset.
Jan 27, 2013 | Oreck XL® Air Purifier
How do i stop the red lite for the collector cell to stop blinking ?
By changing the Collector Cell. The flashing light is an indication that it needs cleaning.
Here is a link to model you listed above. It has all the information you need, on how to clean the Collector Cell. You can download and print it for future reference.
http://www.oreck.com/PUG/3323-8889-Rev-K-AIR8.pdf
Hope this helps you solve the problem.
Mar 21, 2011 | Oreck XL Professional Air Purifier
Red light keeps blinking
I take mine apart when red light comes on and the filters and inside good. It goes off when the unit is screwed back in and turned back on
Nov 15, 2008 | Oreck XL Professional Air Purifier
Red light when swith on power button ?
cell is dirty, or you have a broken wire in the cell.
Dec 22, 2007 | Oreck XL® Air Purifier
Oreck XL® Air Purifier Logo
375 people viewed this question
Top Oreck Air Purifiers Experts
Jerry Greenberg
Jerry Greenberg
Are you an Oreck Air Purifier Expert? Answer questions, earn points and help others
