Question about Vizio M420SL 42 in. HDTV
Power problem my tv started turning off by itself now it will turn on no pic. or sound just the vizio emblem
  • 10 Answers
SOURCE: Vizio won't turn off
This could be a mainboard problem. Sometimes one of the fuses may be bad and may freeze up causing the TV to not be able to power off.
Posted on May 23, 2009
  • 92 Answers
SOURCE: Vizio LCD 37 Inch Turns Off Randomly
This could be a main board or power board issue. replacing main board and/or power board should resolve this problem.
Posted on Jun 16, 2009
SOURCE: no picture or sound, light comes on in the front and have to unplug tv to turn it off.
I had this exact problem on my Vizio 47" HDTV. I removed the speakers and all the screws on the back cover. Took the cover off and located the fuses on the largest circuit board. The are in the upper right hand corner of the board. There are 3 of them in a row labeled LF 1.5, LF 3.0 and LF 3.0. The are white in color with copper ends. I took a volt meter and measured continuity across all fuses individually and found the LF 1.5 to be blown. The guy at the electronics store sold me a barrel 1.5A fuse and told me to soldier it across the top of the blown fuse. It took an extra set of hands but the TV works perfectly.
Posted on Jun 23, 2009
djchillsnyc
  • 151 Answers
SOURCE: Power is there, but TV won't turn on
stored voltages are high no touching these circuts becuase they hold charges and alot of screws.
fualty capacitors you say after a while it stays on theres a full charge in the unit theres some type of discharging effect on the set after its off for a while. voltage goes to low or unstable after it is off for a while. your better off getting the service docs for this set if you want to diy..other wise get a tv tech to check it for you. hope this helps
Posted on Jun 25, 2009
SOURCE: My Vizio 32 inch has a black screen. The Vizio
I have had the same problem. I called vizio they told me how to reset my tv. It did not help me, However, maybe it will help you. They said turn the power off, Unplug it hold in power button for 30 seconds then plug it back in and power it back up. My white light flickered and then nothing. So I am going to end up buying a new tv all together.
Posted on Oct 23, 2009
Vizio will not power on, vizio emblem is off.
Did you check the power cord of intermittent connection.
Mar 29, 2014 | Vizio E472VL 47 LCD HDTV - 1080p, 1920 x...
What is a tc83 part for a vizio
Power supply capacitor. Check power supply capacitors for short, burnout. You can tell if the caps are popped up. Cheap Chinese caps are the cause.
Feb 13, 2014 | Vizio L37 Television
No imaging, have sound, backlight, etc.
It may be an input cable problem. Check hdmi and or coax cables to make sure they are not damaged . If you have another tv hook cables up to it to make sure they are working. Hope this helps.
Dec 31, 2013 | Vizio M550SV 55 in. HDTV
Vizio tv has no power
When you plug in the set, does the Vizio emblem turn Orange?
Jun 09, 2013 | Vizio VX42L 42 in. LCD TV
No power, tried plugging in different outlet
When it's plugged in is there a light anywhere on the T.V. that is on?
May 04, 2011 | Vizio 42 in. LCD TV
My problem is at first when you turn it on it would keep turning itself off and now it is like there is no power to the tv. the emblem is not lit up at all and i have tried every possible troubleshooting...
Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.That the board,where the power a/c cord plug into it.That the power supply board.
Jun 07, 2010 | Vizio P4 46 in. HD-Ready Plasma Television
When I turn our tv off the vizio emplem stays orange
According to the manual. It says The Vizio lights white when powered on and orange when powered off.
Mar 03, 2010 | Vizio VW42LF 42 in. LCD HDTV
Vizio plasma tv turned off..won;t turn back on
This sounds like the main power board went bad. If this is still under warranty, contact 1-877-MYVIZIO and they will have it repaired for you. if not, let me know and I will guide you to the right part.
Jul 15, 2008 | Vizio P4 46 in. HD-Ready Plasma Television
Vizio M420SL 42 in. HDTV Logo
35 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
