Question about GE Profile JB968 Electric Kitchen Range
Button lock-on on my GE profile
The button lock-on is powered on my GE PROFILE and I am not able to switch off.
what I am suppose to do?
I resolved the problem
thanks
Posted on Jun 20, 2009
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    Ge profile oven is in lock mode not able to turn it on , it says HOLD UNLOCK BUTTON FOR THREE SECONDS BUT THERE IS NO SUCH BUTTON, WHAT BUTTON SHOULD I HOLD DOWn?
    Hold the "lock" button for three seconds.
    This is the way mine works, yours is probably the same way.
    Holding the "lock" button for three seconds changes it from locked to unlocked and ALSO from locked to unlocked.
    Nov 16, 2009 | GE Profile JTP18 Electric Single Oven
    Hi, my GE Profile Mod# JBP90GV2BB S/N ZM223214G began beeping this morning and posted an F9 code in the display. The stove hasn't been used in 2 days. What does the F9 code indicate and what ccan I do to...
    F9-- Failed Lock switch detected.
    Check wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch.
    If the wires are ok and, the switch is not stuck, replace it asap.
    Jul 10, 2009 | GE Profile JTP18 Electric Single Oven
    UN LOCKING GE PROFILE OVEN
    pull the oven out away from cabinets and pull lever!
    May 24, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
    GE True Temp Profile Oven, Locked Door Light stuck on
    there should be some type of button that the door hits to turn it on and off
    Mar 24, 2009 | GE Profile JTP18 Electric Single Oven
    Ge Profile model jgb900 has error codes & oven doesn't work
    Hi, this is a lock switch malfunction and you may need to replace this.Check the wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch.
    Mar 06, 2009 | GE Profile JGB900 Gas Kitchen Range
    Ge profile dishwasher panel won't turn on
    out of the blue my GE Profile dishwasher would not turn on. I turned the circuit breaker off for 5 seconds then on and it worked! fixed! saved $200!!!
    Dec 31, 2008 | GE Profile PDW8000G Built-in Dishwasher
    Ge oven problem
    Look for a microswitch connected to the lock mechanism at the back of the stove. The switch is probably broken.
    Jun 07, 2007 | GE Profile JTP56 Electric Double Oven
    GE Profile JB968 Electric Kitchen Range Logo
    250 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Mike Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
