Question about Z.vex Audio Players & Recorders
How to fix crackle - Z.vex Audio Players & Recorders
My camera's built in flash is not working and is making crackling sounds..... how do I fix it ?
When you say "crackling sounds" do you mean electrical sounding crackles or something like gears grinding? If it's the first and especially if you smell something electrical then immediately send it back to Canon for repairs. If there's a short in the wiring or capacitor it could melt or worse. If it's more of a mechanical sound it may be debris lodged in the release mechanisim.
Aug 01, 2014 | Canon EOS 1100D Rebel T3 Body Only Digital...
Crackling subs
After crackling sound they stop and the light on overoald
Dec 29, 2013 | Legacy 12 500 watt l series woofers,...
I have a Marantz 2275 receiver hooked to some JBL speakers. I noticed one of the speakers crackling. I swithched the speaker wires around and now the other speaker crackles so I'm guessing it is
Doesn't sound like it's a speaker - more likely a fried chip or transistor causing harmonic distortion.
It's usually more cost effective to replace modern audio components than to fix them.
Nov 21, 2017 | Audio Players & Recorders
Sound fluxuates,crackling sound samsungTX-R3079WH sound goes up and down automaticly
If the sound FLUCTUATES up & down, try turning off the AutoVolume in the sound menu. You didn't say if it's one or all speakers crackling. Crackling is either a speaker or circuitry issue. Adjust the balance away from the speaker that crackles, if it stops, that speaker is probably "fried". If it still crackles, I'd turn off the speakers and run the sound thru a stereo for the quick, cheap fix. My Samsung (10+ years old to be fair) crackles due to a circuit issue but if I SMACK the left side speaker (behind which is the sound board and side panel connectors) it stops for a while. Maddening. I think I broke it squeezing it into the furniture it's in, pressing on the protruding RCA plugs. Dumb design.
Aug 15, 2009 | Samsung SlimFit TX-S2783 TV
Environcare unit is not crackling.
Check the connections to the air cells (precipitators) and be sure you have a good connection - make sure none of the cell plates are touching each other
Mar 07, 2009 | Honeywell Air Purifiers
Crackling Sound
Hello there
The issue that you are descibing sound it a bad small signal board which needs to be taken to thr repair shop.
Jun 05, 2008 | Hitachi 55HDS69 55 in. Plasma Television
Stereo receiver crackling noise
open it up and spray it with contact spray. move left and right and then spray again. this will normally do the trick. the crackling noise comes from standing in the same position for to long.
Aug 13, 2017 | Audio Players & Recorders
91 people viewed this question
Top Z.vex Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Z.vex Audio Player and Recorder Expert? Answer questions, earn points and help others
