Question about Acer Computers & Internet
Acer doesn't start
There's power inside pc and in battery pack but it doesn't start.. maybe there's a motherboard problem?
  • 51 Answers
Coupld be motherboard, could be the power switch and it could be the power supply not putting enough power to the laptop. Hard to diagnose without seeing it, but those are the three main things that can cause this problem.
Posted on Jun 19, 2009
Acer aspire 5535 is dead no lights no power nothing
Try removing the battery and running just on mains power. If that doesn't work, it sounds like the motherboard has failed and will need replacing.
Mar 26, 2012 | Acer Aspire 5535-5050 Notebook
Not charging
try to have your power cable checked. maybe the power supply isnt working and/or defective. if this doesnt work, try to check your battery pack. you can also go to an ACER service center because technicians there are equipped with the proper tools to fix/check your cable nor the battery pack.
Nov 03, 2010 | Acer TravelMate 4010 Notebook
Acer Asipre 5315 laptop Battery A/C supply plugged in, hit power switch and the power light blinks 2 (maybe 1 time)times but the unit does not power on.
remove the battery and power cord then remove the battery on the mother board, hold down the power button for 60 seconds to drain the capacitors, if that doesn't work it's the motherboard that should be replaced.
Feb 19, 2010 | Acer Aspire 5315 Notebook
Wont charge
1. Check your Wall Jack! Is it working with other electric gadgets ? If it's not working, then problem is with the wall jack!
2. Check your Charger! Try another charger of same model to charge your laptop. If laptop is charging by another one, then replace your bad charger!
3. Check your Battery Pack! Is the battery in good condition... any type of smell or liquid coming out of battery ? If that's the case, replace the battery pack with a compatible one!
4. If none of the above steps helps, then the problem is with the power supply unit of the motherboard. Contact any authorised Acer Service Center for the repair / replacement of the Motherboard!
5. If your system is still under Warranty, you should opt for the replacement of motherboard !
please rate this advice if it helps...tc! :)
Jan 14, 2010 | Acer Aspire 4720 Notebook
Acer aspire 4520g cannot start
I am assuming it does this even if it is plugged into power supply. Try removing the battery and then re-installing it. Maybe it has come loose or has a bad connection. When the power supply is hooked up does it show that the laptop is charging? Have you left the charger on there overnight? Maybe the battery is really weak. It sounds like a bad battery to me but the only way to know for sure is to buy a new battery or test it with another good battery and see if it does the same thing.
Sep 11, 2009 | Acer Aspire 4520-5582 Notebook
Cmos battery location in my acer aspire 3690
its inside the laptop motherboard, the shape is SPHERE or CIRCLE, its a Lithium Battery (CR2032), only technical support are going to open, if you wanted to open it... its your own risk.. Good luck!
Jul 12, 2009 | Acer Aspire 3690-2196 Notebook
Computers & Internet Logo
46 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
