Question about Garden
Pressure washer is getting water in the engine oil?
It Only gets water in the engine oil when water is connected to the pump. It does not get in there from rain or etc...
  • 30 Answers
SOURCE: I'm trying to find out how much oil should be in
it's an ex-cell pressure washer with a honda motor.
engine oil capicity: 0.61 qts(.58L)
view owner manual here:
http://www.excellpressurewasher.com/documents/pdf/a12338-e.pdf
Posted on Mar 11, 2009
  • 10 Answers
SOURCE: Oil leaking from pump
top is a breather you may be overfull of oil most pumps you can use engine oil .drain and put in half litre or if it has a sight glass top up to low side of glass and try it out.possible your seals on way out this usually then leaks at front or gets water in.if you still have good pressure oil seals easy to do.
Posted on Apr 21, 2009
  • 583 Answers
SOURCE: Type of oil for pressure washer pump.
any anti foaming oil ,you can use multi grade but it goes milky with minute air bubbles and gives the appearance of getting water in.most manufacturers recommend anti-foaming oil
Posted on Sep 05, 2009
  • 68 Answers
SOURCE: I want to remove the 4gpm pump on my pressure washer.
HI, It sounds like it is just stuck on the keyway as these can be very tight. You need to force the pump of evenly on either side and should come of if patient.
Posted on Feb 08, 2010
Testimonial: "I'm sure the answer is correct. Over time my use of harsh chemicals no doubt corroded the key-way."
SOURCE: My Troy Bilt power washer (using Honda GCV160
I had a similar problem. Turns out I had left the hose disconnected and some sort of wasp built a paper type nest inside the washer tube that the hose connects to. I had to take the pump off and take apart and then cleaned it out with a screw driver. Not too easy to do but finally got it clean. Same thing happened with the hose.
So, if you haven't used it for awhile, check that there is no blockage in the hose or pump tubes. You might be able to blow it out with an air compressor.
Posted on Feb 11, 2011
Milky engine oil
suspect water in oil... just change the oil and see if it returns. it's very rare that a pressure pump can get water into the engine
Nov 12, 2013 | Karcher G 2600 VH Gas Pressure Washer
The pump is leaking some gray fluid
Gray fluid is usually indicative of old oil with water mixed into it. First you have to determine if the fluid is coming out of the motor or pressure pump. Then change the oil in that, or both, and then watch the condition of the oil when you use the washer. With new oil, it won't turn gray but will get a milky coloration to it. There shouldn't be any way for water to get into the motor oil short of the engine being sprayed directly with high pressure water. If water is getting into the pump oil you'll have to check the seals inside the pump.
Feb 14, 2013 | Honda 5hp 5 Hp Engine Motor Xr2500 Xr 2600...
Water goes thru. have hydrulic oil to level. gun semas to stick on. NOT GETTING ANY PRESSURE AT NOSSEL.
Hydraulic oil?
Is this a pressure washer?
Pump should be half full of SAE20 or SAE30 non-detergent motor oil.
Engine should have 10W30 motor oil.
If you have a pressure washer ... and not water is coming out end of gun:
Take all hoses off machine.
Look at incoming water hose connection.
The should be a filter washer.
Clean or replace filter washer.
Hook up water and turn on water.
Water should come out other side of pump.
Turn on power washer and see if water coming out of pump is pressurized.
Now hook up pressure hose without gun.
Turn on pressure washer and see if water comes out of hose and is pressurized.
Finally, the gun may be bad.
We used to replace guns when they went bad.
Oct 24, 2010 | Dewalt 3800 PSI Pressure Washer
My pressure washer is a G 2500 oh n i have no pressure coming out, it turns on but no pressure.
Good news, your engine runs
But your pump may be bad
Here's how to test your pump
Check oil as outlined lower down
Disconnect the washer hose and gun
Connect water hose and turn on water and water should pass straight through the pump
Look for clogs in the hose-end where water hose connects to machine
Turn on machine and see if water shoots out pump
If water shoots out of pump, but no water shoots out of gun, then you may have a 'mud-dobber' wasp clog in your washer line or gun
Look for clogs in the end of each water connection.
Now connect washer hose without the gun, tun on the machine, and see if water shoots out of washer hose
Finally, the gun trigger mechanism may be bad
I don't know which gun you have ... but we replaced guns on our machine now-and-then ... google-search power washer guns for a replacement
Check your pump oil
Pump oil is SAE20 or SAE30 non-detergent motor oil
Pump should be no more than 1/2 full of oil
Use plastic hose to drain pump oil
Do not turn machine on its side or turn machine over or engine oil will run into carburetor
Oct 20, 2010 | Karcher 2500 PSI Pressure Washer
Pressure washer will not put out any pressure
Hi Ken and welcome to FixYa. I am Kelly.
These pumps are notorious for seasonal problems.
Tip the unit to the point you can pour engine oil into the water inlet connection. What your attempting to do is free up the ball seats in the pump. They get corroded when they sit and lock in place. Adding the oil or a vast amount of WD 40 to the water inlet often does the trick for loosening up the seat balls and springs.
After you add the oil (3 - 4 ounces) or WD 40 to the water inlet line just slowly pull the engine through with the ignition switch off. As the water inlet cavitates add more oil.
Let it sit over night and then take a block of wood and a hammer and tap on the power head. Don't over do it and do it in such a manner your not going to shear off any bolts or break anything. But... be serious with the hammer and block of wood.
Then connect inlet water hose, the pressure hose and test the unit. You may want to purge the oil lubricant into a bucket before you start the engine.
Give it a try and see what happens.
Thanks for using FixYa,
Kelly
Take some engine oil and
May 04, 2010 | Karcher 2500 PSI Pressure Washer
No high pressure
Kelly
Engine runs fine. no water pressure.
Kelly
Apr 16, 2010 | Devilbliss DeVILBISS Devap DVH2600...
Pressure washer does not have that much pressure any more 2years old use maybe twice a year
Kelly
Mar 30, 2010 | Psi Blue Max 2200 High Pressure Gas Power...
Engine appears locked up as it won't wind up to start
Try turning the water almost off at the faucet and then loosening the water feed hose connection where it attaches to the washer. Sometimes the pressure in the pump is so high that it will effectively lock the engine and you need to relieve the pressure to be able to restart it. Once it does restart, get the water flow back ASAP as the water is used for cooling and it needs to be there quickly.
Aug 16, 2009 | Karcher 2500 PSI Pressure Washer
Had the Northstar 3000 psi Pressure Washer for 2 months and it started leaking oil from the pump during use. Took it to Northern and they are replacing the pump under warranty but said it was likely...
It is easy to check if your hose and quick connects are supplying enough water to the pump. Your pressure washer gallon per minuite requirements are printed on the machine and also on the pressure tips in GPM. Your post indicates 2.5 gpm but check your documentation of GPM. Next remove the tip from the wand and connect your hose with current quick connects to the machine. Start engine and direct the pressure wand into a bucket for exactly one minute. Measure the amount of water in the bucket, it should be very close to stated gallons. Do the same test with tip installed and compare measurement. If pump is starving for water you will not get proper amount of water in the bucket and the water hose will collapse. Two to four gallons of water per minute is not very demanding and should be delivered even with very small opening. You can even just direct the hose into the bucket for one minute and check how much water your hose is capable of delivering. I believe that you will find no problem with water delivery to pump. I would certainly enlighten Northern with your findings and question their evaluation. When you start using your pressure washer again try using it at lowest pressure to get the job done. Lowering the pressure to about 75% of max will increase the life of the pump and engine. Good luck with you pump
May 08, 2009 | Northstar Pressure Washer 3000 PSI
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
