Question about Refrigerators
I am in Australia. I have an XRBR904BW, about five years old. It is a terrific fridge and we love it. Recently it has been acting up. It makes a buzzing noise when starting the compressor, and then clicks off. This will happen a couple of times and then the compressor starts, but now it is happening for long periods of time and the compressor doesn't seem to be working. The freezer melts and the fridge gets warm. We had a local repairman look at it, and he said that it needed a new compressor. As soon as he left it started to work again, and was okay for a week or two, and then it started buzzing again and eventually the compressor stopped completly. I turned the fridge off for 24 hours, and when I turned it on again, it worked perfectly. Now, about three or four days later it has started buzzing and clicking off again. Can you tell me if you are aware of similar problems? Can it be fixed without replacing the compressor? Help? Any assistance most appreciated. Bill Mellor, Brisbane, Queensland, Australia
  • 10,515 Answers
I am making an intelligent guess since I am not there....I think the start relay is going out and I would have this checked real soon. If you feel capable, remove the rear cover and check the connections at the compressor. Look for a burnt or discolored wire and let me know what you find.
More likely, It's due to start relay.
Other than this, It's compressor .
Note :- Make sure that the Fan is running to cool the compressor.
Important :- Compressors usually have 5 years warranty.
Thanks for using "Fixya".
Posted on Jun 19, 2009
Fridge stopped working both freezer and fridge, Here clicking at compressor, compressor not starting, cooling fan and everything else OK, could it be the compressor or is there a chance the thermal switch...
This is a bad compressor, or overload-relay kit. Disconnect the power, remove the overload-relay from the compressor, and test the three compressor terminals for continuity . You should have continuity between each terminal, and you should not have continuity between any terminal and ground. If this tests ok, then replace the overload-relay kit. This is a common repair for me, and it is very rare for us to find a bad compressor, so you should be ok. If it is a bad compressor, and it is less than five years old, you have a five year sealed system warrantee, that will cover the repair cost. If it is over five years old, it is not worth repair. When you are done with the repair, make sure you install a 2000 joule or higher, surge protector to protect your refrigerator from this type of repair in the future. Good Luck, Appliance Specialists
Mar 14, 2011 | KitchenAid Superba KSRG25FK Side by Side...
Do your refrigerators contain any Cfc gasses, the fridge is 3 years old and we need to move it back to Australia where they are not permitted entry Thank you
if your fridge is only 3 years old the refridgerant is probably 134a which contains non ozone depleting substances or cfc gasses but it is still wise to check with austrailian enviroment to see if it complies with theire standards regaurding theyre codes
Mar 01, 2011 | Daewoo FR640K
The strip down the middle between the the fidge and freezer doors is getting hot. So hot that it burns when you touch it. The sides of the fridge are also getting pretty not. I have just bought the fridge...
I have exactly the same problem with my Westinghouse side by side! And it only happens when it's hot in the house. Would love to hear what's wrong. And the fridge is 5 years old. Bought new.
Jan 12, 2011 | Westinghouse Refrigerators
Leaking water from below
May be the drip collector beneath your freezer is full causing the overflow. If it is, empty it. Else, the opening to the collector may be blocked due to ice. In that case clear the route.
Apr 20, 2010 | Refrigerators
I have a Frigidaire side by side. Probably about 7 or 8 years old. It cools and freezes fine. Recently it has been making a loud buzz for about 5 or 6 seconds at a time. It dosent do it all the time but...
Hi; Cory this sounds like a water solenoid letting in water to the ice machine. Sometimes the solenoid can loosen itself from the water valve. Pull the fridge. forward GENTLY.We dont know how much water line was left in the back of unit. Cory unplug fridge. Then remove the screws on the lower cover. Usually a 1/4 or 5/16 nut driver will do nicely. Then just follow water line to the water solenoid valve check for anything weird...Worst case scenerio the internal parts are starting to wear a bit.
If You find alot of dust please remove with vacume clnr.
This will help cooling operation and Your fridge will love You long time. let me know...alpharome416
Feb 23, 2010 | Frigidaire FRS26R4A Side by Side...
Terrific noise when defrosting cycle starts
check the back of the fridge, sounds like pipes are rubbing underneath, if you feel you are competent then follow the next steps, 1. Turn the fridge off and unplug it. 2. get to the back of the fridge with a good light or torch and inspect the pipe work, 3. make sure nothing is touching itself and be careful not to touch the black oval shape object as it may be hot (normal). if everything looks ok plug the fridge in and see if you can still hear it ,if the noise is anything other than pipe work , depending on the model you have , it could be either a fan bearing of the compressor is on its way out.
May 11, 2009 | Refrigerators
Gfi outlet keeps tripping
try running an extension cord to the old outlet and see if the fridge works then you'll know if it's the fridge or outlet. good luck
Dec 03, 2008 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
43 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
