Question about Refrigerators
How to unplug the drain whirlpool sidekick refridgererator
Whirlpool Duet Sport won't work past the wash cycle. It's full of water and will not drain.
check the pump filter it could be blocked or the drain hose try blowing down the drain hose to see if its clear you should hear a bubbling sound if not its blocked
Nov 27, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
Whirlpool duet water pump leaking froze and busted
these drain pumps are $150 with tax remove bottom access panel and drain pump has 3 screws "BEWARE IF WATER IS STILL IN DRUMP IT WILL END UP ON YOUR FLOOR" On the back of the drain pump there is a plastic cover that kindof opens like a trunk lid, unplug and remove the bolts some have rubber grommets that hold the drain screen its is very easy.
Sep 23, 2011 | Whirlpool GHW9150 Front Load Washer
SPECIAL-CODE Q700 SIDEKICK
which code you are looking for ? if you want network unlock codes try here http://www.wickedunlock.com/sidekick/rs11wp8/
Feb 20, 2011 | Home
Our whirlpool washing machine wont drain and light for clean pump is on what do i do
Most likely your drain hose is clogged on the back end of the machine. With the appliance UNPLUGGED, a technician can get a wire of some sort to snake out the clog.
Nov 30, 2010 | Home
F21 Whirlpool duet washer, removed front panel unclogged restarted and still f21? Tech came in and had no idea said he smelled something burning, must of been his imagination.
ohh, duets are such a treat.
If the drain time exceeds eight minutes, “F21” will be displayed,
the water valves will turn off and the pump will stop running.
Press PAUSE/CANCEL to drain the machine. The display will be
cleared and the machine will turn off after a maximum of eight
minutes.
Possible Causes/Procedure
1. Check the drain hose and make sure it is not plugged or
kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure
the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
this is what Whirlpool says, but we have found that this doesnt always work.
Nov 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have the whirlpool sidekicks. There is frozen
shut off any water supply. remove ice/water,check 6 hours .if no water supply,check temperature,could be defrost timer/heater.u'll need to do this over 24 hour cycle..recording unit,or set ur alarm clock..if no unusual amount of heat (3-4 hrs) or the absence of ANY heat at any time(area where freezing, reset temperature up 5 degrees..
Aug 02, 2009 | Whirlpool GB2SHDXTS Stainless Steel
Whirlpool calypso model GVW9959K-0 leaking during rinse cycle
hi my name is joyce
Sounds like your pump is leaking. if it is leaking when you are on a spin cycle.
now if it is stuck on f1 cycle and wont drain unplug and let stay unpluged for 60 seconds and replug and see if you can restart on drain and spin cycle. let me know if I can help with any other problems.
thanks
joyce
Feb 06, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
My screen is black
the screen on my sidekick 2008 is cracked need to find a screen for so i can get it to work
Dec 10, 2008 | T-Mobile Sidekick
Whirlpool modle ET1CHMXKQO2
if you cant get to the back the only thing left to do is unplug fridge until drain line defrosts
Mar 21, 2007 | Whirlpool ET1FTKXK Top Freezer...
Refrigerators Logo
18 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
