Question about Refrigerators
Model: EL88TRRWS how to unplug the drain - Refrigerators
I have a fisher pykel washing machine model WL80T65CW1 and it keeps coming up with a code 245
That is a water draining problem. From Sears: "Remove any clogs from the house drain for the washer. Remove any clogs or kinks from the washer drain hose. Unplug the washer and check the drain pump for a clog. If the drain pump is defective, replace it."
May 12, 2015 | Fisher Washing Machines
Why my fridge working all the time
Could be a number of reasons, the cooling coils at back clogged and not ventilating, a faulty thermostat, faulty control board, door not closing properly. Start by making sure the back is clean and ventilated, then look at the thermostat. Caution high voltages so unplug before checking.
May 12, 2014 | Whirlpool EL88TRRWS Refrigerator
EL88TRRWS is all fridge no freezer and it just doesnt seem to be cooling enough any idea's?
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 25, 2011 | Whirlpool EL88TRRWS Refrigerator
It has a f 09 code
Hi.If the overflow contact on the pressure switch is closed for more than 60 seconds, an Overflow Condition will occur. In an overflow condition, the door remains locked and the drain pump runs constantly, even if PAUSE/CANCEL is pressed twice and the display is cleared. Turn off hot and cold water faucets and unplug the unit before servicing the unit in this case.
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump, pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Check for drain pump failure.
6. Check the inlet valve for proper shut off.
7. Check the pressure switch for proper operation.
The culprit in this situation could be the inlet vale, drain pump or pressure switch. Check all points above to isolate the issue. If you require a service manual to guide you through the necessary inspections, I will need your entire model number to post it. Post the entire model number, asap. i will post the proper service manual after i receive your model number and brand.
F-09 - Overflow Condition
Aug 24, 2010 | Whirlpool Washing Machines
Model WTW6600SBO: Machine is stuck, won't spin
I'm having the exact same problem...did you ever find a solution?
Jun 16, 2010 | Whirlpool WTW6600SW Top Load
Freezer drain is plugged. How do I unplug it?
shut off unit. find drain hole. pour HOT(boiling hot) water about a cup. wait so it will melt the ice. now either use a air from air compressor, or a portable steamer to run air thru the hole, also can use a long flex bar(like cloths hanger) or a flex pvc hose.
U also have to make sure your condensor coil is clean. dust at bottom of the fridge usuallu cloggs the drain as it normally drains to the boottom tray located beneath the fridge.
Oct 31, 2009 | Refrigerators
Water in Bottom of Refrigerator/How disconnect icemaker
Hi, Remove the ice maker by loosening the screws that hold it to the wall. Once it is loose, there is enough wire that you can unplug the icemaker and set it aside. Now remove the rear panel and you can unplug the drain. Be sure and flush hot water through the drain to be sure it is oen.
I hope this helps you.
Please let me know if I can assist you further.
Vic
May 23, 2009 | Refrigerators
The washing machine will not drain.
Change the lid switch. take the two screws out of the front where the timer consol is. unplug machine. then you will see a plug on the top of the cabinet. unplug it and put a jumper wire in the two end terminals plug it in and you will see that you bipassed the lid switch and it will start to drain and spin. www.whirlpoolpartssurplus.com call with your model and you can get the part there really cheap.
May 06, 2009 | Kenmore Washing Machines
Will not drain/spin. Yesterday, the load was out of balance...
Try unplugging the washer and let the curcuit board reboot. Unplug for 5 min. Then try moving the selector to spin to drain the washer. Sometime selecting too many modes trying to get something working can confuse the electronics. Reboot the curcuit board and try just spin cycle.
Apr 29, 2009 | Washing Machines
Model WBVH5200JOWW: Locked up. Unplugged waited,
we had the same problem. I found a site that talked about the drain pump so my husband took the front panel off and found the drain plug. Have a bucket and some towels handy, unscrew the drain plug, ours is right there when take the cover off and its white. Unscrew it slowly, water will most likely start draining. Our drain trap was completely full of lint, a necklace, coins, and stuff! Once we cleaned it out, plugged it back in, it reset itself and works like a charm. Good Luck
Tandy
tjwtaz@hotmail.com
Feb 20, 2009 | GE WSXH208A Front Load Washer
Refrigerators Logo
24 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
